    Setting up heater chamber - need help
    1.4k
    • felt342undefined
      felt342 @JoergS5
      @JoergS5
      Yeah, I really appreciate your help and digging in! What I am thinking is maybe better to move thermistor to the middle of the chamber, it will probably be the faster response until I have only one heater.
      Industrial 3D printing service in the Netherlands - gagatstudio.com
      JoergS5undefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @felt342
        @felt342 Now I know why I cannot find it. I search in the 3.1.1 code....
        => didn't find it in 2.05 code also. Will search and will tell you if I find something.
        felt342undefined 1 Reply Last reply Reply Quote 1
        • felt342undefined
          felt342 @JoergS5
          @JoergS5
          Happens 🙂
          Thank you!
          • JoergS5undefined
            JoergS5 @felt342
            @felt342 I found it in pid.cpp of 2.05 source:
            // Heating up
            const bool isBedOrChamberHeater = reprap.GetHeat().IsBedOrChamberHeater(heater);
            const uint32_t heatingTime = millis() - tuningPhaseStartTime;
            const float extraTimeAllowed = (isBedOrChamberHeater) ? 60.0 : 30.0;
            if (heatingTime > (uint32_t)((model.GetDeadTime() + extraTimeAllowed) * SecondsToMillis)
            && (temperature - tuningStartTemp) < 3.0)
            platform.Message(GenericMessage, "Auto tune cancelled because temperature is not increasing\n");
            break;
            So the error message is called and a break occurs, if the heating time is bigger than dead time + extraTimeAllowed.
            A low dead time helps in any case.
            extraTimeAllowed is defined by:
            so for Chamber it is 60.
            You could try setting D negative, say -59. Don't know whether it works.
            You're welcome and I wish you success with the heated chamber!
            felt342undefined 1 Reply Last reply Reply Quote 2
            • felt342undefined
              felt342 @JoergS5
              @JoergS5
              That seems working without error!
              I didn't try negative D, but I set D to 1 and kept C at 2000, waiting for autotune and values 🙂
              Thanks a lot again!
              JoergS5undefined 1 Reply Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @felt342
                @felt342 Nice to hear, thank you!
                See you.
                felt342undefined 1 Reply Last reply Reply Quote 0
                • felt342undefined
                  felt342 @JoergS5
                  @JoergS5
                  I must say it`s a nice way of solving the issue, digging the source code, will take it as a tip 🙂
