Duet 2 Wifi Bad Drivers
Hi all,
I just recently installed a Duet 2 Wifi and Duex5 board on my Jubilee build. Both were purchased from Filastruder. The LDO motors initially had the incorrect coil pairing, (1+3, 2+4) but was corrected prior to install. Logging into the web control, the U motor moved just fine but no success on X or Y. Repeatedly got:
Warning: motor phase A may be disconnected reported by driver(s) 0 1
Warning: motor phase B may be disconnected reported by driver(s) 0 1I then turned off the machine, double checked all of the wiring, and plugged the X motor into the Z driver. Motor turned just fine. This was repeated with the Y motor and it also functioned as expected.
I think the drivers 0 and 1 are bad. My board was just purchased, and should still be under warranty I believe? How can I get it replaced? Is this the problem? Z.jpg
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DLM-996RU-N8PS4-7JKDD-3SD6R-KVAZN
Used output buffers: 3 of 24 (16 max)
Static ram: 25712
Dynamic ram: 93980 of which 108 recycled
Exception stack ram used: 352
Never used ram: 10920
Tasks: NETWORK(ready,756) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3760) IDLE(ready,160)
Owned mutexes:
Last reset 00:01:56 ago, cause: power up
Last software reset at 2020-08-13 16:15, reason: User, spinning module GCodes, available RAM 11000 bytes (slot 3)
Error status: 0
Free file entries: 9
MCU temperature: min 25.4, current 26.3, max 26.5
Supply voltage: min 24.4, current 24.6, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 25/372
Driver 1: standstill, SG min/max 25/173
Driver 2: standstill, SG min/max 0/0
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max 0/119
Driver 7: standstill, SG min/max 0/122
Driver 8: standstill, SG min/max 0/146
Driver 9: standstill, SG min/max not available
Date/time: 2020-08-13 16:26:58
Cache data hit count 344821897
Slowest loop: 2.07ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 85668ms
=== DDARing ===
Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 201.16ms; fastest: 0.08ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
Failed messages: pending 0, notready 0, noresp 2
WiFi firmware version 1.23
WiFi MAC address dc:4f:22:6e:6c:35
WiFi Vcc 3.33, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22816
WiFi IP address 192.168.1.26
WiFi signal strength -44dBm, reconnections 0, sleep mode modem
- WiFi -
For the sake of completeness can you post your config.g?
Of course
; Jubilee 2.0 Config File
; drawing inspiration from the Railcore 300ZL config file; Name and Identification
M550 P"Jubilee" ; Machine name and Netbios name; Networking
M552 S1 ; Start Wifi
M552 P192.168.1.26 ; Use Ethernet with a static IP
M554 192.168.1.3 ; Gateway
M553 P255.255.255.0 ; Netmask
M586 P2 S1 ; Enable Telnet; Debugging
M111 S0 ; Debug off
M929 P"eventlog.txt" S1 ; Start logging to file eventlog.txt; General Preferences
M555 P2 ; Set Marlin-style output
G21 ; Set dimensions to millimetres
M83 ; ...but relative extruder moves; Joints
M584 X0 Y1 Z6:7:8 E3:4:5:9 U2 ; Map Z to drivers 6, 7, 8. Map extruders to 3 and 4. Create Toolchanger Lock axis.M569 P0 S0 ; Drive 0 direction | X stepper
M569 P1 S0 ; Drive 1 direction | Y StepperM569 P6 S0 ; Drive 6 direction | Front Left Z
M569 P7 S0 ; Drive 7 direction | Front Right Z
M569 P8 S1 ; Drive 8 direction | Back ZM569 P2 S0 ; Drive 2 direction | Toolchanger Actuator
M569 P3 S0 ; Drive 3 direction | Extruder 0
M569 P4 S0 ; Drive 4 direction | Extruder 1; Joint Kinematics
M669 K1 ; CoreXY mode; Kinematic bed ball locations.
; Locations are extracted from CAD model assuming lower left build plate corner is (0, 0) on a 305x305mm plate.
;M671 X300:5:152.5 Y354:354:24 S10 ; Front Left: (300, 354) | Front Right: (5, 354) | Back: (152.5, 24)
M671 X297:2.5:150 Y313.5:313.5:-16.5 S10 ; Front Left: (297.5, 313.5) | Front Right: (2.5, 313.5) | Back: (150, -16.5); XYZ Motor Settings
M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping for xyz axes & extruder. Use interpolation.
M574 X1 Y1 Z1 S1 ; Set homing switch configuration x low-end, y low-end, z low-end, all active-high (NC)
M574 U1 S1 ; Set homing switch configuration for toolchange lock. Both switches should be wired NC and in series.
M906 X1950 Y1950 Z1750 E1250 ; Motor currents (mA)
M201 X1000 Y1000 Z20 E1300 U800 ; Accelerations (mm/s^2). Conservative. 1500+ may be possible.
M203 X13000 Y13000 Z800 E8000 U9000 ; Maximum speeds (mm/min). Conservative. Up to 20000 may be possible.
M566 X1000 Y1000 Z500 E3000 U50 ; Maximum jerk speeds mm/minute
M92 X200 Y200 ; Steps/mm for X,Y
M92 Z3200 ; Steps/mm for Z for a 2mm pitch leadscrew, 0.9mm stepper. (16 * 400)/2
M92 E830 ; Extruder - 0.9 deg/step; LDO Toolchanger Motor Settings
M350 U4 I1 ; Set 4x microstepping. Use interpolation.
M906 U670 I60 ; current and idle motor percentage.
M92 U30.578 ; Steps/deg for U from (200 * 4 * 13.76)/360; StepperOnline Toolchanger Motor Settings
;M350 U2 I1 ; Set 2x microstepping. Use interpolation.
;M906 U1000 I70 ; current and idle motor percentage
;M92 U5.7575 ; Steps/deg for U from (200 * 4 * 5.18181)/360; Set axis software limits and min/max switch-triggering positions.
; Adjusted such that (0,0) lies at the lower left corner of a 300x300mm square in the 305mmx305mm build plate.
M208 X-13.75:313.75 Y-44:341 Z-0.2:305
M208 U0:200 ; Set Elastic Lock (U axis) max rotation angle; Thermistors
M305 P0 S"Bed" R4700 T100000 B3950 ; USER set bed thermistor parameters
;M305 P0 S"Bed" T10000 B3435 H0 ; BOM-specified Terminal Lug Thermistor values.
;M305 P0 S"Bed" T10000 B3984 H0 L160 ; BOM-specified Terminal Lug Thermistor values.
;M305 P0 S"Bed" T100000 B3950 R4700 H0 L0 ; Built-in Keenovo Bed Thermistor values.
M305 P1 R4700 T100000 S"Extruder" B4725 C7.06e-8 ; Map Extruder 0 sensor to PT100 Channel 0
;M305 P2 X201 ; Map Extruder 1 sensor to PT100 Channel 1;Heaters
M570 S30 ; Print will be terminated if a heater fault is not reset within 30 minutes.
M143 H0 S100 ; Maximum H0 (Bed) heater temperature
;M143 H1 S260 ; Maximum H1 (Extruder) heater temperature; Default heater model
M307 H0 A270.7 C90.4 D6.7 B0 S1.0 ; Default Bed Heater Parameters, before tuning / if config-override.g is missing; Tool definitions
M563 P0 S"Extruder 0" D0 H1 F0 ; Define tool 0
G10 P0 X-4.5 Y44.02 Z-2.25 ; Set tool 0 offset from the bed
G10 P0 S190 R170 ; Set tool 0 operating and standby temperatures(-273 = "off")
M572 D0 S0.1 ; Set pressure advance on Extruder Drive 0M563 P1 S"Extruder 1" D1 H2 F2 ; Define tool 1
G10 P1 X-4.15 Y44.62 Z-2.45 ; Set tool 1 offset from the bed with tool-0 as a reference.
G10 P1 S190 R170 ; Set tool 1 operating and standby temperatures(-273 = "off")
M572 D1 S0.1 ; Set pressure advance on Extruder Drive 1; Fans
M106 P0 S0 ; Turn off fan 0
M106 P1 S0 ; Turn off fan 1;Mesh Bed Leveling Settings:
M557 X10:290 Y10:290 P6; Z probing settings
M558 P4 C2 H5 A1 T10000 S0.02
; P4 --> probe type: switch
; C2 --> endstop number
; H5 --> dive height
; A1 --> max number of times to probe
; T100000 --> travel speed between probe points
; S0.02 --> tolerance when probing multiple timesM98 P"config-user.g" ; Load custom user config
I don't suppose you could provide a photo of the back side of the board showing the driver socket pin soldering?
@Chris2010 there are glitches in your config, eg you use drive 5 and 9 for the extruder, but dont have a M569 definition for it. U uses 4 microstepping, but Duet doesnt support interpolation for it, only for 16.
Datasheet says 2.0 A maximum for the xy steppers 42sth60, so current setting is too high, should be 50-85% of it. At z position the current was set lower, this may explain why they work there.
I could if its necessary, but that would require removing the whole board from the machine. Would you like me to do that?
Well if the drivers are damaged you'll have to remove it from the machine to exchange it, so...
@JoergS5 Im planning on installing another extruder shortly. I can lower the current on the steppers but as its not moving at all, that seems like its not the issue? That should be a factor for overheating but as far as I can tell they aren't. Is that correct?
@Chris2010 i had too high current once at a stepper, they dont move then and heat up. its worth a try.
@Phaedrux Great point lol. And Ill give lowering the current a try. Thanks for the suggestion!
I don't think there is any extreme error in the config. At least none that should generate the problem observed.
Mainly you're missing M584 to create the U axis.
The current is high for X and Y, so worth a try reducing it, but I don't think it would generate the issue seen.
I might also suggest getting a fresh config from the web tool with just the basics. No Duex connected. Just the default drivers defined and test that.
@Phaedrux Thats a good Idea as well. Guess Ill try that next.
So XY currents were dropped to 1560 mA and retested. No luck. Still no movement. On to the new config test...
Ok, retested with fresh config, Z moves (connect to tool lock) X and Y do not. It looks like the drivers to me. Any other ideas?
Please contact filastruder and initiate a warranty exchange for the Duet Wifi. Link to this thread as authorization.
I'd still be curious to see photos front and back when you get it out.
When RRF reports both phases of a driver may be disconnected, it's rarely a driver issue.
Are you sure you have identified the driver numbers correctly? Your photo of the Duet WiFi shows a motor connected to the Z driver, which is driver 2, and nothing connected to driver 0 or driver 1.
