UNSOLVED Lost connection to Duet3 SBC
I upgraded from Duet 2 Wifi and DueX2 to a Duet 3 with Raspberry Pi.
Since I upgraded I will randomly get this error:Randomly I get this error and my machine will stop responding to the web interface:
Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)Board: Duet 3 MB6HC (MB6HC)
DSF Version: 3.1.1
Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)Before this happened I was loading the hotend using the interface to extrude the filament. Other times this has happened was when I was running bed leveling.
Seems like when it does happen it's when I'm selecting a gcode file to print. It doesn't automatically reconnect unless I manually restart the board by hitting stop on the Panel Due or reset on the motherboard.
8/13/2020, 2:34:16 PM Connection established 8/13/2020, 2:33:42 PM Connection interrupted, attempting to reconnect... 8/13/2020, 2:33:42 PM Connection to Duet established 8/13/2020, 2:33:41 PM Warning: Firmware reset imminent 8/13/2020, 2:33:41 PM Emergency stop, attemping to reconnect... 8/13/2020, 2:33:41 PM Connection to Duet established 8/13/2020, 2:33:29 PM Warning: Firmware halted 8/13/2020, 2:33:24 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin) 8/13/2020, 2:33:21 PM M32 "0:/gcodes/2020 Dial Indicator X Carriage Mount.gcode" File 0:/gcodes/2020 Dial Indicator X Carriage Mount.gcode selected for printing 8/13/2020, 2:33:07 PM TELNET is disabled 8/13/2020, 2:33:07 PM FTP is disabled 8/13/2020, 2:33:07 PM HTTP is enabled on port 80 8/13/2020, 2:33:07 PM Warning: Controller has been reset 8/13/2020, 2:33:07 PM Connection to Duet established 8/13/2020, 2:33:07 PM Warning: Lost connection to Duet (Board is not available (no header)) 8/13/2020, 2:33:06 PM M32 "0:/gcodes/2020 Dial Indicator X Carriage Mount.gcode" File 0:/gcodes/2020 Dial Indicator X Carriage Mount.gcode selected for printing
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 154604 Dynamic ram: 163392 of which 64 recycled Exception stack ram used: 536 Never used ram: 74620 Tasks: ETHERNET(blocked,824) NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,60) MAIN(running,2868) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:10:35 ago, cause: power up Last software reset time unknown, reason: User, spinning module LinuxInterface, available RAM 77216 bytes (slot 2) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 33.5, current 37.5, max 37.7 Supply voltage: min 24.2, current 24.6, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0 Driver 0: ok, reads 8566, writes 17 timeouts 0, SG min/max 0/191 Driver 1: ok, reads 8563, writes 21 timeouts 0, SG min/max 0/1000 Driver 2: ok, reads 8563, writes 21 timeouts 0, SG min/max 0/188 Driver 3: ok, reads 8564, writes 21 timeouts 0, SG min/max 0/1023 Driver 4: ok, reads 8564, writes 21 timeouts 0, SG min/max 0/1023 Driver 5: ok, reads 8565, writes 21 timeouts 0, SG min/max 0/922 Date/time: 2020-08-13 14:44:20 Slowest loop: 9.24ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 362, MinFreeDm: 356, MaxWait: 288392ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 393, completed moves: 379, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.3 === GCodes === Segments left: 1 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 E-0.100000 F5100" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1.02ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: establishingLink Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok === CAN === Messages sent 2475, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 21ms ago RX/TX seq numbers: 19446/19447 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 3704/1080-4080 === Duet Control Server === Duet Control Server v3.1.1 File: Buffered code: G1 E-0.1000 F5100 Buffered code: G92 E0.0000 Buffered code: G1 X142.453 Y151.100 E0.5814 F866 Buffered code: G1 X148.447 Y151.100 E0.8227 Buffered code: G1 X148.532 Y149.363 E0.8927 Buffered code: G1 X148.626 Y148.732 E0.9183 Buffered code: G1 X148.781 Y148.114 E0.9440 Buffered code: G1 X148.996 Y147.513 E0.9697 Buffered code: G1 X149.268 Y146.936 E0.9953 Buffered code: G1 X149.596 Y146.389 E1.0210 Buffered code: G1 X149.976 Y145.877 E1.0467 Buffered code: G1 X150.404 Y145.404 E1.0723 Buffered code: G1 X150.877 Y144.976 E1.0980 Buffered code: G1 X151.389 Y144.596 E1.1237 Buffered code: G1 X151.936 Y144.268 E1.1493 Buffered code: G1 X152.513 Y143.996 E1.1750 Buffered code: G1 X153.114 Y143.781 E1.2007 Buffered code: G1 X153.732 Y143.626 E1.2263 Buffered code: G1 X154.363 Y143.532 E1.2520 Buffered code: G1 X155.000 Y143.501 E1.2777 Buffered code: G1 X155.637 Y143.532 E1.3033 Buffered code: G1 X156.268 Y143.626 E1.3290 Buffered code: G1 X156.886 Y143.781 E1.3547 Buffered code: G1 X157.487 Y143.996 E1.3803 Buffered code: G1 X158.064 Y144.268 E1.4060 Buffered code: G1 X158.611 Y144.596 E1.4317 Buffered code: G1 X159.123 Y144.976 E1.4573 Buffered code: G1 X159.596 Y145.404 E1.4830 Buffered code: G1 X160.024 Y145.877 E1.5087 Buffered code: G1 X160.404 Y146.389 E1.5343 Buffered code: G1 X160.732 Y146.936 E1.5600 Buffered code: G1 X161.004 Y147.513 E1.5857 ==> 1508 bytes Code buffer space: 2576 Configured SPI speed: 8000000 Hz Full transfers per second: 18.47 File /opt/dsf/sd/gcodes/2020 Dial Indicator X Carriage Mount.gcode is selected, processing
Can you try putting it in debug mode to gather some additional info?
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
Will have to see what @chrishamm has to say about the error.
@Phaedrux Thanks. I will try that and see if I can get any more information. it's not consistent. I can go days without it happening.
@Phaedrux I’m still getting that error too. It usually happens after a print or two when I try to submit a new print. Any update on a fix for this?
I changed my hostname on the Pi not realizing i had invalid characters. I changed it to The_Demon where capital and "_" are not allowed. when i changed it to the-demon it seems my problems went away. at least it hasn't happened since
@baird1fa Have you started a thread for your issue and provide some debug info as linked above?
@dhusolo said in Lost connection to Duet3 SBC:
capitals isn't (shouldn't be?) a problem, it just isn't case sensitve.
_
isn't a valid hostname character indeed, more details in link
@bearer I know with Linux if you don't have the correct case it sometimes it'll say the command is invalid. So to eliminate any issues i made it all lowercase LOL
for commands and filenames yes, dns and hostnames doesn't matter. in general you'll have less issues avoiding mixed case and special characters (incl spaces) on linux indeed
bearer@rama:~$ dig +noall +answer gatebear.lan gatebear.lan. 0 IN A 10.10.0.1 bearer@rama:~$ dig +noall +answer GATEBEAR.LAN GATEBEAR.LAN. 0 IN A 10.10.0.1 bearer@rama:~$ DIG +noall +answer gatebear.lan DIG: command not found
