Gpio pins duet wifi
Is there any way to use the pins on the expansion header to control a 3 volt relay without using an expansion board. I basically need a fan to turn on and off it doesnt need pwm. If it is possible is there an ideal pin to use ?
Yes, you can use any of the 5 heater pins on the expansion connector.
would i need to put use M307 H4 A-1 C-1 D-1 to make heater 4 pin available first then reassign it to a fan? sorry this is all very new to me.
@davidvh86 said in Gpio pins duet wifi:
Yes if using RRF 2.05.1. No if using RRF 3.1.1.
So no need for an m307
M950 F3 C"heater4" Q500
So would putting this code turn heater 4 pin into a fan?
Yes.
awesome thanks for your help.
In case it wasn't clear, the pins can only sink it source a tiny current. So you'll most likely need to buffer it with a transistor of sorts of you want to control a relay (unless it's a ssr with a turn on current of about 2mA or less). Some pins may be able to do a little more, ref datasheet page 1350++ or so.
@bearer
well thats gonna be an issue lol. So it only has approx 2 ma of current?
I got a Optocoupler Relay that has the has a separate power and signal input. hopefully it triggers properly.
you might be okay if its a darlington optocoupler, otherwise 2ma might be pushing limits. i'd either look up specs or measure the input current at 3.3v supply and add a series resistor to get below 2ma and see if it still works if needed.
