Smart effector first layer issues
@Lakeman said in Smart effector first layer issues:
;M501 ;should save my data after calibration without homing.
you disabled the overwrite loading
also see
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printerwhat the different factor calibration do. 7 adjusts arm length
Yes, as in the post above
have you tried a print with mesh bed leveling disabled?
G29 S2 -
Height map looks fine
G29 S1 good
Its 440.5 above..So Height!
heat bed to 60c nozzle hot or not G28, M208 Z-5 slowly lower nozzle to sheet of paper or 0.1mm feeler gauge if you have one don't delta calibrate the Z height should be at Z0.1 if not adjust M665 H so it is Z0.1 remember to add the 0.1 of the gauge/paper to the height for Z0Also just post you M122 please and M115 for firmware version
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F23T0-6JKFD-3S86S-9ZB0D
Used output buffers: 3 of 24 (11 max)
Static ram: 27980
Dynamic ram: 92980 of which 60 recycled
Exception stack ram used: 472
Never used ram: 9580
Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
Owned mutexes:
Last reset 00:00:36 ago, cause: software
Last software reset at 2020-08-25 17:01, reason: User, spinning module GCodes, available RAM 9372 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 34.5, current 35.1, max 35.5
Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 14/124
Driver 1: standstill, SG min/max 34/152
Driver 2: standstill, SG min/max 0/140
Date/time: 2020-08-25 17:01:57
Cache data hit count 57819496
Slowest loop: 6.62ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.4ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 166, MaxWait: 17282ms
=== MainDDARing ===
Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.71ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address ec:fa:bc:02:17:f8
WiFi Vcc 3.46, reset reason Unknown
WiFi flash size 4194304, free heap 24608
WiFi IP address 192.168.2.101
WiFi signal strength -71dBm, reconnections 0, sleep mode modem
- WiFi -
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2 -
Nice one
@Carlo M665 R227.9 L440.48 B185 H418.879 X0.217 Y0.125 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height
@Lakeman
Remember it should only just touch the gauge/paper not grip it. -
Ok, adjusted the Z height, now it just grips the paper @ Z0.1
@Lakeman
Cool so when you G28 ,G1 Z0.1 at 60c bed temp it goes to Z0.1 ? just touches the paper not grip it -
Good stuff was it off ? if so by how much ? just good to know..
Copy below to new macro, so macros, new macro ...good to keep
call it probe offset and run it its safe given to me by another user on this forum; Heat bed to 60C & nozzle to 130C
M104 S130 T0
M190 S60 T0
M109 S130 T0
M106 P2 S0
G31 P100 X0 Y0 Z0 ; Reset Z trigger height to 0mm
M290 R0 S0 ; Reset babystepping
G29 S2 ; Clear bed mesh
G28 ; Home the effector
G1 X0 Y0 Z20 F6000 ; Move close to the bed
G30 ; Probe to find a rough Z 0mmG1 X0 Y0 Z1 F3000 ; Move the nozzle to Z 1mm slowly
G92 Z3.0 ; Set the Z height to 3mm, allowing moves below 0
M291 P"Lower the nozzle to until it touches a 0.10mm shim. Click to continue." S2 Z1
G92 Z0 ; Define this point as 0mm
G1 X0 Y0 Z20 ; Move the probe to Z 20mm
G30 S-3 ; Probe and set the trigger height
G1 Z20 ; Raise Z to 20mm -
About 1.5mm out
That's a lot mate
Oke, I ran the macro. This time it touched the paper @Z2.1... But before was a cold nozzle
Nozzle won't make that much difference ...what was the offset ?
touching the paper at Z2.15
M292
Z probe trigger height set to -0.241 mm
