    Random Smart Effector flashes
    1.9k
    • sankafolaundefined
      sankafola
      31.5 ohms and 34 ohms
        sankafola @A Former User
        @bearer R 11 red to black R 14 is 31.5 and red to R13 is 34 ohms
        • A Former User?
          A Former User @sankafola
          @sankafola said in Random Smart Effector flashes:
          to the top strain gauge is 31.5 and the bottom is 34; not convinced the traces in that strain gauge are broken - but probably best to see if the Duet people has something to say about it before drawing conclusions
          (I'm usually in the "know enough to be dangerous" category..:)
          • T3P3Tonyundefined
            T3P3Tony administrators
            Tf the top and bottom traces compete read ~30Ohms each then the score has not gone through them completely.
            Have you tried adjusting the sensitivity down to see if you can get a range that it triggers reliably when it taps on the bed (be careful, maybe hold a hard surface higher for initial tests and be prepared to cut power).
            https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
            www.duet3d.com
            sankafolaundefined 1 Reply Last reply Reply Quote 0
              sankafola
              it is working but sometimes it just flash by itself and i dont think any traces of touch on these gauge is doing it because if it is why its not doing it all the time ??!!
                sankafola @T3P3Tony
                @T3P3Tony am using SKR 1.4 Turbo not duet , so my MOD pin is not connected to anything right now ,
                let me just explain what is the issue i see , the smart effector works fine and do auto claib and all is good but all of sudden it start to flash even if its not doing anything , if i reboot the printer and it become normal again
                  @bearer that is exact what i messuered i wish you put that first lool but i found it with my cheap microscope 🙂
                  • A Former User?
                    shouldn't listen to random strangers on the internet; btw I've got candy!
                    (sorry, I just randombly stumped onto the post where it was assumed damaged, and worked back to look at a way to verify as repairs seemed unlikely)
                      sankafola
                      @T3P3Tony so what do you think it is ?
                        Does it make any difference (to the random flashes) whether the motors are energised or not?
                        Does it make any difference whether the heated bed is on or off, or how close to the bed the effector is?
                        If you remove the effector from the printer, apply 3.3V or 5V to the Vcc and ground connections of the white 8-pin connector with nothing else connected, does the green LED still flash randomly when the effector is still?
                          sankafola
                          @dc42 i tried that and no flashing , i just did now auto delta calibration and went fine
                          G32
                          Calibrated 8 factors using 16 points, (mean, deviation) before (-0.174, 0.045) after (-0.000, 0.021)
                          Auto calibration successful, deviation 0.021mm
                          then did mesh level and it stopped saying
                          G29
                          Error: Z probe already triggered before probing move started
                          then i just reboot the printer then i did G32
                          G32
                          Calibrated 8 factors using 16 points, (mean, deviation) before (-0.212, 0.042) after (0.000, 0.019)
                          Auto calibration successful, deviation 0.019mm
                          and then mesh 170/30
                          G29
                          101 points probed, min error -0.571, max error 0.685, mean 0.033, deviation 0.242
                          Height map saved to file heightmap.csv
                          so it does it every 2nd time i ask for mesh g29
                          its random
                            dc42 administrators @sankafola
                            I presume you mean that when the effector is connected to 5V or 3.3V only, the random flashing ceases. That suggests that the problem is either mechanical interference (i.e. vibration - which is why I asked if turning the motors off made a difference) or electrical interference (most likely from stray magnetic fields - hence my question about the bed heater).
                            Do you have an extruder mounted on the effector, or is it a bowden system?
                              sankafola
                              @dc42 its flaying extruder with 20 cm tube , the thing is if its the bed electromagnet it should affect it all the time not just random , here is my setup 53014114-37A0-4C43-A876-13321CB3C327_1_105_c.jpeg
                                Does the random flashing stop when you raise the effector well above the bed?
                                sankafolaundefined 2 Replies Last reply Reply Quote 0
                                  sankafola
                                  @dc42 no the random can happen also while its home which is very far from the bed
                                  • A Former User?
                                    A Former User
                                    the light shown is that led's on/near the effector? does it help to turn lights off?
                                      sankafola
                                      these lights of the smart effector why turn off? you think its related to the random flash ?
                                      • A Former User?
                                        was just thinking if they were external leds and you're looking for a source of noise, it'd be worth looking into.
                                          sankafola
                                          its built in LED in the smart effector and i dont think its related because they are on while its working normal too its built that way
                                            sankafola @dc42
                                            @dc42 just to be sure the LED which flash random is the same LED which flashes 2 times when it turn on the printer
