    PanelDueFirmware 3.2-RC2 released
    PanelDue
    paneldue
    883
    • wilrikerundefined
      wilriker
      I am pleased to announce the second release candidate for PanelDueFirmware 3.2. This release contains primarily bug fixes and one small change in behavior. See below for details.
      Version 3.2-RC2
      Upgrade Notes:
      • This release is compatible with RepRapFirmware 3.2-beta1 or later. It will partially work with RepRapFirmware 3.1.1 but not with any older version.
      Limitations
      Due to the lack of RAM this build will not run on version 1 or early version 2 PanelDue boards that use the ATSAM3S2B chip.
      • Version 1.0, 1.1 and earlier v2 PanelDue: ATSAM3S2B processor (64MHz, 32kb RAM, 128kB flash) - these are the ones that the new firmware probably won't run on.
      • Version 2 PanelDue manufactured from August 2016: ATSAM3S4B processor (64MHz, 48kb RAM, 256kb flash). Will run the new firmware, but not as fast as version 3 will.
      • Version 3 PanelDue, including all 5i and 7i: ATSAM4S4B processor, 120MHz, 64kB RAM, 256kb flash. Will run the new firmware.
      Changes since RC1:
      • Status colors of tools were confusing (because a tool can never go to "off" after being active once) so it only shows "active" or "anything else"
      Bug fixes since RC1:
      • In some cases setting a tool's heater would instead the heatbed temperature
      • Chamber and heatbed icons did not change colors according to their state
      • It was not possible to disable the chamber heater by tapping the chamber button
      • Move popup buttons were none-functional
      • Commands entered via on-screen-keyboard were not echoed into the text field
      Known Issues:
      • While a heater is heating and it is being waited for it to reach target temperature PanelDue will see no updates from RepRapFirmware - this is an issue in RepRapFirmware and will be fixed in the next release
      • Screensaver delay select popup does only hide when clicking on a tab button - this will be fixed in the next release
      RC1
      https://forum.duet3d.com/topic/18716/panelduefirmware-3-2-rc1-released/
      Downloads and Instructions
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2-RC2
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      oozeBotundefined 1 Reply Last reply Reply Quote 1
      • oozeBotundefined
        oozeBot @wilriker
        @wilriker
        This release uses the RepRapFirmware ObjectModel instead of limited status responses
        Would you mind expanding on this? Is the intent to make the PanelDue an object that can be referenced through conditional gcode? Or is this just a rewrite of how the PanelDue communicates with RRF?
        Thanks
        jay_s_ukundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @oozeBot
          @oozeBot it's a communication rewrite to move from M408 to M409
          • wilrikerundefined
            wilriker @oozeBot
            @oozeBot As @jay_s_uk already said this moves the status requests that PanelDue sends towards RRF from M408 to M409, i.e. PanelDue itself requests updates of the ObjectModel. Advantage is that the responses contain all necessary information to also represent complex configurations on PanelDue.
            Manuel
            My Tool Collection
            • KipKundefined
              KipK
              I get an error modifying the extrusion % from paneldue with 3.2-RC2
              "M221 D parameter to high"
              Reprap fw 3.2 b1
              https://github.com/Duet3D/PanelDueFirmware/issues/75
              KipK created this issue in Duet3D/PanelDueFirmware
              closed 3.2 RC2 changing extrusion % gives M221 D parameter to high #75
              • wilrikerundefined
                wilriker @KipK
                @KipK Can you give some more information, please? I cannot reproduce the issue, yet.
                First of all: to which value do you want to set your extruder? config.g might be helpful. In case there are multiple extruders please state which one. Most helpful would be a step-by-step list of instructions to reproduce your issue.
                Manuel
                My Tool Collection
                • KipKundefined
                  KipK
                  @wilriker , sure
                  I only have one extruder.
                  I was about to get 97%. Then got back in the web panel and saw it was still 100%.
                  Than saw the error in panel console.
                  I could eproduce it at each try then.
                  I'll investigate further.
                  here is config.g
                  G90                                                         ; send absolute coordinates...
                  M83                                                         ; ...but relative extruder moves
                  M550 P"BLV MGN cube"                                        ; set printer name
                  M669 K1                                                     ; select CoreXY mode
                  M575 P1 B57600 S0										    ; set serial port fur paneldue
                  M552 S1                                                     ; enable network
                  M586 P0 S1                                                  ; enable HTTP
                  M586 P1 S0                                                  ; disable FTP
                  M586 P2 S1                                                  ; enable Telnet
                  M569 P0 S1                                                  ; physical drive 0 goes forwards
                  M569 P1 S1                                                  ; physical drive 1 goes forwards
                  M569 P4 S0                                                  ; physical drive 2 goes backward
                  M569 P6 S1                                                  ; physical drive 3 goes forward
                  M569 P7 S1
                  M569 P8 S1
                  ;M584 X1 Y0 Z6:8:7 E4; three Z motors connected to driver outputs 6, 8, 7
                  M584 X1 Y0 Z6:7:8 U7 V8 P3 E4; three Z motors connected to driver outputs 6, 8, 7
                  M350 X16 Y16 Z16 U16 V16 E16 I1                                     ; configure microstepping with interpolation
                  M92 X200.00 Y200.00 Z1600.00 U1600 V1600 E416.62                         ; set steps per mm
                  M566 X600.00 Y600.00 Z50.00 U50 V50 E2000.00                       ; set maximum instantaneous speed changes (mm/min)
                  M203 X15000.00 Y15000.00 Z400.00 U400 V400 E3600.00                   ; set maximum speeds (mm/min)
                  M201 X1200.00 Y1200.00 Z200.00 U200 V200 E2000.00                      ; set accelerations (mm/s^2)
                  M906 X1500 Y1500 Z1200 U1200 V1200 E700 I30                             ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                                     ; Set idle timeout
                  M208 X-173 Y-157 Z0 U0 V0 S1                             ; set axis minima
                  M208 X173 Y174 Z343.88 U343.88 V343.88 S0                   ; set axis maxima
                  M574 X1 S1 P"xstop"                                         ; configure active-high endstop for low end on X via pin xstop
                  M574 Y1 S1 P"ystop"                                         ; configure active-high endstop for low end on Y via pin ystop
                  ;M574 Z2 S1 P"duex.e2stop+duex.e6stop+duex.e5stop"           ; configure active-low endstop for high end on Z via pin zstop
                  M574 Z2 S1 P"duex.e2stop";	set endstops for Z
                  M574 U2 S1 P"duex.e6stop";	set endstops for U
                  M574 V2 S1 P"duex.e5stop";	set endstops for V
                  M558 P9 C"^zprobe.in" H15 F200 T25000 R0.4 A4 S0.03 B1        ; set Z probe type to bltouch and the dive height + speeds
                  M950 S0 C"duex.pwm5"                                        ; create servo pin 0 for BLTouch
                  G31 P25 X36.47 Y-4 Z1.95                                    ; set Z probe trigger value, offset and trigger height
                  M557 X-135:135 Y-135:135 P5:5                               ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138              ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                                       ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00                                            ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                     ; map heated bed to heater 0
                  M143 H0 S130                                                ; set temperature limit for heater 0 to 130C
                  ;M308 S1 P"e1temp" Y"thermistor" T4606017 B5848 C5.548428e-8 H0 L0 ; configure sensor 1 as thermistor on pin e0temp
                  M308 S1 P"spi.cs1" Y"rtd-max31865" R380 ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
                  M950 H1 C"e1heat" T1                                        ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                                            ; disable bang-bang mode for heater  and set PWM limit
                  M143 H1 S300												; set temperature limit for heater 0 to 130C
                  M950 F0 C"fan1" Q500                                        ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                              ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"duex.fan5" Q500                                        ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 H1 T45 S1                                       ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"duex.fan7" Q500
                  M106 P2 S115 H-1
                  M950 F3 C"duex.fan6" Q500
                  M106 P3 S115 H-1
                  M563 P0 D0 H1 F0                                            ; define tool 0
                  G10 P0 X0 Y0 Z0                                             ; set tool 0 axis offsets
                  G10 P0 R0 S0                                                ; set initial tool 0 active and standby temperatures to 0C
                  ; Leadscrews
                  M671 X-214:214:214 Y0:118:-121 S20 						    ; leadscrews at middle left, front right, and rear right
                  T0                                                          ; select first tool
                  M81 														; trick to enable ATX button on web interface
                  ;M572 D0 S0.035												; enable pressure advance ( ABS )
                  M572 D0 S0.028												; enable pressure advance ( PLA )
                  M593 F27.84 											    ; dynamic acceleration ( cancel ringing at 53.33hz)
                  M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z5 E-1 F1000" 		; pause print when power fail
                  M80															; power on 24v
                  M376 H10													; tapper mesh bed leveling to 10mm
                  M950 J2 C"!^duex.e3stop";									; set e3stop trigger
                  M581 P2 T2 S1 C0											; trigger T2 when duex.e3stop is rising
                  M501                                                        ; load saved parameters from non-volatile memory
                  • wilrikerundefined
                    wilriker @KipK
                    @KipK I will most likely only get to this on Tuesday.
                    If you are willing to further investigate: You can see what the PanelDue is sending back to RRF by connecting e.g. your PC by USB to your Duet, open a terminal (https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7) and send
                    M111 P3 S1
                    after that you see every GCode command processed by RRF (tip: close every DWC session to avoid seeing tons of commands from channel HTTP). The channel you are looking for is Aux.
                    Then command your extrusion factor change and see what PanelDue sends back to RRF. It should look like
                    M221 Dn Snnn
                    Manuel
                    My Tool Collection
                    • wilrikerundefined
                      wilriker @KipK
                      @KipK As stated on GitHub already: I found and fixed the issue. Thanks for reporting - this also revealed some minor UI issues as a side-effect.
                      This will be fixed in the 3.2-RC3 release I plan to release this week.
                      Manuel
                      My Tool Collection
                      • KipKundefined
                        KipK
                        Great. Thanks. I'll test this thereafter
                        • wilrikerundefined
                          wilriker
                          3.2-RC3 has been released. See https://forum.duet3d.com/topic/18952/panelduefirmware-3-2-rc3-released
                          Manuel
                          My Tool Collection
