How to wait for bed to heat up?
I have a heat bed that's an aluminum bed with a borosilicate glass bed on top. It works great but the thermistor is under the aluminum bed and so it hits temperature way before the glass bed has heated up (about 4 minutes).
What's the right way to have my printer wait for the bed to heat up? I'm fine with a 4 minute delay between bed/extruder but don't know how to do that.
I'm using Simplify3d as the slicer and I'd rather not have to hand-edit the produced gcode files. I know I could just manually place a wait after the bed temp command.
Thanks.
@markz you could put a
G4 S240
In your start gcode from your slicer. That would put a 4 min delay in
Won't that keep the hot end cooking for 4 minutes with no filament? That seems like a bad thing to me but maybe it isn't?
Then heat up the hotend after the wait for the bed to come to temperature.
@markz said in How to wait for bed to heat up?:
Could you inject "G4 S240" after the bed temperature is commanded, but before the hotend temperature command is read?
M140 S110
M190 S110 ;wait for bed temp
G4 S240 ;wait 4mins to heat bed fully before activating T0
M104 S240 T0
M109 S240 T0
