Duet 3 SBC Prints small
  • So my Duet 3 using SBC prints about 25% smaller than it should be. I wasn't really paying attention as the things I was printing didn't really matter size wise. I printed a couple of printer parts and thats when I realized it.
  • @mrenz999
    I would say your steps per mm are wrong ?.
    Is it 25% on 1 axis or all the axis ? ,
    make a cube and see what happens .
  • @peter247 It's a on all axis's. It's overall 25%
  • @mrenz999
    What type of printer is it ?
  • @peter247
    It's a BLV Mgn Cube
    M584 X0.0 Y0.1 Z0.2:3:4 E0.5 ; set drive mapping
    M92 X80.00 Y80.00 Z400.00 E408 ; set steps per mm
    M566 X600.00 Y600.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X20000 Y20000 Z600 E2000.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z600.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M671 X-40:460:460 Y150:310:50 S9 ; leadscrews at rear left, front middle and rear right
  • @mrenz999 said in Duet 3 SBC Prints small:
    I lost on that, external driver ? why the 0.x
    I've read up on it , I get it.
    2mm belts and 8mm lead screw , can't see a problem.
  • @peter247 Same. Can't see an issue. Hmmm
  • Are you sure it's not a slicer issue? Which slicer are you using? Have you tried a different one?
  • @jay_s_uk Tried SuperSlicer and Cura 4.7.1. Not sure what is causing it. I have a 410x410 bed. Have that set in the slicer and in my config.g file
  • Can you post your complete config file please? As well as your config-override
  • @jay_s_uk
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time)
    G21 ; Set units to MM
    M550 P"Duet 3" ; set printer name
    M669 K1 ; select CoreXY mode
    ;Network
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0.1 S0 ; physical drive 0.1 goes backwards
    M569 P0.2 S1 ; physical drive 0.2 goes forwards
    M569 P0.3 S1 ; physical drive 0.3 goes forwards
    M569 P0.4 S0 ; physical drive 0.4 goes backwards
    M569 P0.5 S1 ; physical drive 0.3 goes forwards
    M208 X-20 Y-10 Z0 S1 ; set axis minima
    M208 X410 Y410 Z465 S0 ; set axis maxima
    M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
    M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    ;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
    ;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
    ;G31 P500 X-40 Y-10 Z6 ; set Z probe trigger value, offset and trigger height
    M557 X20:430 Y15:410 S20 ; define mesh grid
    Z-Probe
    M558 P8 C"^io7.out"
    G31 P500 X-20 Y-15 Z1.1
    M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
    M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M143 H1 S300
    M307 H0 A188.5 C683.1 D0.2 S1.0 V24.1 B0
    M307 H1 A351.2 C120.5 D7.2 S1.0 V24.1 B0
    M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
    M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
    M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
    M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
    T0
    M501
    ; config-override.g file generated in response to M500 at 2020-09-18 22:07
    ; Heater model parameters
    ; Workplace coordinates
    G10 L2 P1 X0.00 Y0.00 Z0.00
    G10 L2 P2 X0.00 Y0.00 Z0.00
    G10 L2 P3 X0.00 Y0.00 Z0.00
    G10 L2 P4 X0.00 Y0.00 Z0.00
    G10 L2 P5 X0.00 Y0.00 Z0.00
    G10 L2 P6 X0.00 Y0.00 Z0.00
    G10 L2 P7 X0.00 Y0.00 Z0.00
    G10 L2 P8 X0.00 Y0.00 Z0.00
    G10 L2 P9 X0.00 Y0.00 Z0.00
  • @mrenz999
    a blv uses 16 tooth pulleys. so that should be
    M92 X100.00 Y100.00 Z400.00 E408 ; set steps per mm
    there is your 25%
  • @Veti You are correct 🙂 Giving it a try now. Thank you for your help
