    Ender 5 Plus with dual z calibration
    3.1k
    • nightmare90gtundefined
      nightmare90gt
      I am trying to setup for the two z motors to align the bed but can't figure out how to make it happen. The left lead screw does just fine but the right one the dashboard shows that its at -27 and y at 135.xx. It only probes once and that's it doesn't make adjustments to the bed at all. My setup is the Duet 2 Wifi and duex 5 the left z motor is connected to z on the duet and the right motor is connected to D5 on the Duex. Any help is appreciated.
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 16:34:31 GMT+0200 (Central European Summer Time)
      M550 P"Ender 5 Plus CoreXY" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M671 X-20:370 150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to D5) of X axis
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M569 P5 S0 ; physical drive 5 goes backwards
      M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and D5
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X313 Y350 Z400 S0 ; set axis maxima
      M208 X0:313 Y0:350 Z400 ; X carriage moves from 0 to 313, Y axis goes from 0 to 350
      M574 Z1 S2 P"zstop+D5stop" ; configure Z-probe endstop for low end on Z
      M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
      G31 P500 X30.814 Y17.505 Z-0.425 ; set Z probe trigger value, offset and trigger height
      M557 X50:313 Y15:350 S50 ; define mesh grid
      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
      M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
      M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"E0" D0 H1 F0 ; define tool 0
      M563 P1 S"E1" D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      T0 ; select first tool
      ; bed.g
      ; M561 ; clear any bed transform
      ; G29 ; probe the bed and enable compensation
      G28 ; home
      G30 P0 X313 Y150 Z-99999 ; probe near left leadscrew
      G30 P1 X3 Y150 Z-99999 ; probe near rear right leadscrew
      • Vetiundefined
        Veti
        @nightmare90gt said in Ender 5 Plus with dual z calibration:
        ; bed.g
        G28 ; home
        you are missing S2 ; probe near a leadscrew and calibrate 2 motors
        in the last command
        see https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          nightmare90gt
          Added the s2. Still have the extruder setup trying to go past the endstop to probe.
          • Vetiundefined
            Veti
            can you post the messages from the console.
              nightmare90gt
              Error: Probe points P0 to P1 must be in clockwise order starting near minimum X and Y
              left leadscrew probed at Y132.5 and X 282.2
              right leadscrew probed at Y 132.5 and x -27.8
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti @nightmare90gt
                adjust the probing points with your offset in mind
                if you want to probe at x0 that would mean the nozzle has to move to -30.814, which it obviously cant
                so choose probing points that are reachable.
                if you then still get the error message about the order, swap the probing points.
                nightmare90gtundefined 1 Reply Last reply Reply Quote 0
                  nightmare90gt @Veti
                  @Veti I have it in bed g its suppose to probe at 3 for x. Could it be adding the offset of the probe to were it probes?
                  • Vetiundefined
                    Veti
                    @Veti said in Ender 5 Plus with dual z calibration:
                    X3 Y150
                    to probe this point, your nozzle would be at x-27 z 133
                    the console even tells you that
                      nightmare90gt @Veti
                      @Veti right so its adding the offset of the probe so I would need to set the probe point at x30 for the probe to be at x0
                      Vetiundefined peter247undefined 2 Replies Last reply Reply Quote 0
                      • Vetiundefined
                        Veti @nightmare90gt
                        @nightmare90gt
                        for the nozzle to be at x0 yes
                        • peter247undefined
                          peter247 @nightmare90gt
                          @nightmare90gt
                          Are you using the default hotend and bltouch locations ?
                          Because G31 P500 X30.814 Y17.505 Z-0.425 would put your bltouch on the right of the nozzle / hotend .
                          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                            nightmare90gt
                            No i have a bmg-x2-m setup.
                              nightmare90gt
                              I also have a quick question related to problems I am having. What would cause a motor to stutter? When I home the x axis the whole gantry studders. It is a corexy setup so I am new to this.
                              • Vetiundefined
                                Veti @nightmare90gt
                                @nightmare90gt
                                the ender 5 is not a corexy printer
                                  nightmare90gt
                                  mine is I have install a Kay3d corexy kit. the stuttering only seems to happen when you homeall but not if you home them individually.
                                  • Vetiundefined
                                    Veti
                                    can you post a video of it? showing both stuttering and not stuttering
                                      nightmare90gt
                                      https://www.youtube.com/watch?v=tcf_zB_B2GU
                                        nightmare90gt
                                        new config.g file because i have added a few things throughout the day.
                                        M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
                                        M671 X-20:370 150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to P5) of X axis
                                        M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                                        M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                                        M591 D1 P5 C"e1_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 1, connected to endstop input 4 (E1), tolerance 40 to 120%, 3mm comparison length, disabled
                                        • Vetiundefined
                                          Veti
                                          can you post your home scripts?
                                            nightmare90gt
                                            @Veti ; homeall.g
                                            ; called to home all axes
                                            G91 ; relative positioning
                                            G1 H1 X-325 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                            G1 H1 X-325 ; home X axis
                                            G1 H1 Y-355 ; home Y axis
                                            G1 X5 Y5 F6000 ; go back a few mm
                                            G1 H1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
                                            G1 H1 Y-355 ; then move slowly to Y-axis endstop
                                            G90 ; absolute positioning
                                            G1 X150 Y150 F6000 ; go to the middle of the bed and home Z
                                            ;G91 ; relative positioning
                                            ;G1 Z5 F100 ; lift Z relative to current position
                                            ;G90 ; absolute positioning
                                            ; homex.g
                                            ; called to home the X axis
                                            G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                            G1 X5 F6000 ; go back a few mm
                                            G1 H2 Z-5 F6000 ; lower Z again
                                            ; homey.g
                                            ; called to home the Y axis
                                            G1 H1 Y-355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                            G1 Y5 F6000 ; go back a few mm
                                            G1 H1 Y-355 F360 ; move slowly to Y axis endstop once more (second pass)
                                            ; homey.g
                                            ; homez.g
                                            ; called to home the Z axis
                                            G1 X19.186 Y-2.504999999999999 F6000 ; go to first probe point
