    Can't get part cooling fans running :(
    339
    • holco62
      holco62 last edited by holco62
      Hi guys & girls,
      Made the entry into the 3D printer world two months ago, was the first to buy a FLSun QQ-S Pro and 3 weeks later purchased an Anycubic Predator with the idea to make a top 3D printer, the first to replace the hotend with a Maxiwatt and later also replaced the extruder with a BMG dual drive Redrex clone.
      Now a week ago I took the plunge by purchasing an original Duet 2 wifi controller including the 5 "PanelDue.
      After a lot of messing around, I was finally able to make my first print 🙂
      But one thing I can't do, I can't get the two part cooling fans running, they are connected to the FAN-0 connector, and when I plug the ALWAYS ON FANS they just run.
      Below my config.g file hoping someone will look at it to find a solution.
      Thanks in advance,
      Mario
      The Netherlands
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Sep 18 2020 09:00:56 GMT-0500 (Central Daylight Time)
      M575 P1 S1 B19200
      M550 P"Predator" ; set printer name
      ; Delta Settings
      M665 R185 L440.49 B175 H436.71 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      ;M551 P"tiCipp!50" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z80.00 E430.0 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P8 C"zprobe.in" R0.4 H30 F1200 T5000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z13.90 ; set Z probe trigger value, offset and trigger height
      M557 R175 S20 ; define mesh grid
      ; Filament Sensor
      M591 D0 P2 C"e1_stop" S1 ;activate Filament Sensor
      M308 S0 A"Heated Bed" P"bedtemp" Y"thermistor" T100000 B4300 C0 R4700 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" Q100 T0 ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 A137.8 B0 C533.3 D1.5 ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0 P0 ; map heated bed to heater 0
      M308 S1 A"Maxiwatt" P"e0temp" Y"thermistor" T100000 B4300 C0 R4700 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S280 A0
      M950 F0 C"fan0" Q24000 ;CPAP create fan 0 on pin fan0 and set its frequency !fan2+exp.pb6 with RPM readout on PB6
      M106 C"PartCoolingFan" F65535 P0 S0 H-1 L0.1 ; set fan 0 value. Thermostatic control is turned off L0.3 X1
      M950 F1 C"fan1" Q100 ;HOTEND FAN create fan 1 on pin fan1 and set its frequency
      M106 C"HotendFAN" P1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      T0 ; select first tool
      Anycubic Predator - Duet-2 wifi PanelDue - Smart effector
        Can you post the results of M122 and M98 P"config.g" please?
        You say you have 2 part cooling fans? Are they both wired to the Fan0 connector? In series or parallel?
        Are the fans 12v or 24v? Is the PSU 12v or 24v?
        For fan0 you've set a PWM frequency of Q24000, did the default 500 not work?
        M106 F65535 is not valid. The F parameter is not used in RRF3, and in RRF2 the limit for PWM frequency is below that I believe. So delete that.
        holco62 1 Reply Last reply Reply Quote 0
        • holco62
          holco62 @Phaedrux last edited by
          @Phaedrux
          Yes 2 cooling fans (original Predator) in parallel connected to the FAN-0 connector, fans and the PSU are 24V.
          Don't know about PWM frequency of Q24000, I copied the setup from someone on this forum (honestly doesn't know who anymore), maybe he didn't use the original fans.
          Deleted M106
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 538C
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N8PS4-6J9F4-3S46T-1UVVN
          Used output buffers: 3 of 24 (11 max)
          Static ram: 27980
          Dynamic ram: 93212 of which 60 recycled
          Exception stack ram used: 264
          Never used ram: 9556
          Tasks: NETWORK(ready,404) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:01:24 ago, cause: power up
          Last software reset at 2020-10-12 21:12, reason: User, spinning module GCodes, available RAM 9316 bytes (slot 1)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 29.4, current 34.6, max 34.7
          Supply voltage: min 24.7, current 24.9, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2020-10-13 00:29:14
          Cache data hit count 137051482
          Slowest loop: 6.77ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.9ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.91ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.23
            WiFi MAC address f4:cf:a2:6e:87:5c
            WiFi Vcc 3.36, reset reason Unknown
            WiFi flash size 4194304, free heap 25192
            WiFi IP address 192.168.1.20
            WiFi signal strength -71dBm, reconnections 0, sleep mode modem
            Socket states: 4 0 0 0 0 0 0 0
            === Filament sensors ===
            Extruder 0 sensor: ok
          • holco62
            I changed M950 to Q500, fans still not spinning.
            M950 F0 C"fan0" Q500
            fcwilt 1 Reply Last reply Reply Quote 0
            • fcwilt
              fcwilt @holco62 last edited by
              @holco62 said in Can't get part cooling fans running 😞:
              How did you test the fans? What command did you issue?
              Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
                Phaedrux Moderator @holco62 last edited by
                Deleted M106
                Don't delete the whole M106, just the F65535 part.
                Try this:
                M106 C"PartCoolingFan" P0 S0 H-1 B1 ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan1" Q500 ;HOTEND FAN create fan 1 on pin fan1 and set its frequency
                holco62 2 Replies Last reply Reply Quote 0
                • holco62
                  @Phaedrux Thanks, I will try it this evening.
                  Btw, all the lines 1>5
                  • holco62
                    @Phaedrux said in Can't get part cooling fans running 😞:
                    Deleted M106
                    Try this:
                    @Phaedrux
                    It's working now, many thanks for your help 👍 👍 👍
                    Is it also possible to start the cold-end fan at a nozzle temp of 50 degrees on the fan01 connector?
                    • holco62
                      I see it now 😊 line 4 and 5 is for the hotend fan that triggers on 45 degree, I only have to put the connector on the FAN1 output which is now connected on a always on output 🙄
                      Have a lot to learn about G-code 😀
                      • holco62
                        Still needed some tuning, but a week ago I did not expect to have a working printer already 😎
                        https://youtu.be/CeavMw9Q42I
                        • holco62
                          With a Z axis calibration I sometimes see the number 1000 in red in the status box at sensors Z-probe, but usually it stays at 0 (not in red).
                          What does that mean?
                            It's showing that the probe is triggered. What it shows and how long it shows it will depend on the type of probe.
                            • holco62
                              @PhaedruxOk, but why don't I see the number 1000 in red every time the probe triggers during a calibration?
                                What probe do you have?
                                • holco62
                                  The stock Predator probe with a micro switch
                                  • holco62
                                    • holco62
                                      I changed M558 H30 to H35 in the config.g, but that hasn't changed anything, but the calibration is going damn slow now 🤔
                                        Well the switch is only going to show triggered when it's depressed, so in normal use it would be very brief.
                                        M558 H is the dive height.
                                        You should consider posting a new thread with your probing issues as it's not related to your initial problem which was solved.
                                        • holco62
                                          Ok thanks, I will create a new topic.
