    AJAX timeout error during a print
    48
    8.5k
    • appjawsundefined
      appjaws
      Hi
      I am using wifi firmware 1.15c and web interface 1.12 and keep getting timeouts when the machine is idle and when printing.
      It appears random.
      I just reconnect again and the print progress is up to date, so it's not a big problem, just frustrating, after all it shouldn't happen.
      This is the error :-
      Communication Error
      An AJAX error has been reported, so the current session has been terminated.
      Please check if your printer is still on and try to connect again.
      Error reason: timeout
      What can I do to provide more information?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • DjDemonDundefined
        DjDemonD
        I've had lots of these too. I'm running windows 10 and using chrome. It doesn't cause any trouble I just hit reconnect but it is happening every 10-15 minutes.
        www.precisionpiezo.co.uk
          Can both of you confirm that the error reason given is always timeout, and that you are running DWC 1.12?
          • DjDemonDundefined
            DjDemonD
            Firmware Version: 1.15c (2016-09-05)
            WiFi Server Version: 1.02
            Web Interface Version: 1.12
            Communication Error
            • appjawsundefined
              appjaws
              Yes the reason is always timeout and I am using DWC1.12
              Simplify3D 5.1.2
              • DjDemonDundefined
                DjDemonD
                I have only used Chrome for windows 10 so far. I will try other browsers as I read in another thread it might be the browser ending the session.
                  I suspect it's caused by an unreliable WiFi connection, for example due to temporary interference. I've asked chrishamm if he can change DWC to do a configurable number of retries instead of just one.
                  • W3DRKundefined
                    W3DRK
                    For what it's worth I have yet to experience this with my Duet WiFi. I use both Chrome and Firefox on Linux…no issues at all.
                    On the other hand, with my Duet 0.6-which is obviously wired- I receive the AJAX timeout error like clockwork. It's not running the latest firmware though and I can't recall off hand what version it is...maybe 1.12 I believe...
                    • appjawsundefined
                      appjaws
                      @dc42:
                      I have a pre-production duet wifi board.
                      Nothing else is on my network wirelessly so any hints as to what could be causing interference?
                      Simplify3D 5.1.2
                      • appjawsundefined
                        appjaws
                        @dc42:
                        Simplify3D 5.1.2
                        • W3DRKundefined
                          W3DRK
                          I think the ESP8266 is limited to 2.4GHz which can get really crowded these days. It may be nothing particular to your network but rather any number of wireless devices in your vicinity that share the same RF spectrum.
                          Most wireless routers or access points give you ability to manually choose a particular "channel" to use, you may want to try arbitrarily changing that to a few different ones and see if that makes a difference.
                          • appjawsundefined
                            appjaws
                            @W3DRK I'll look into that, thanks for the info
                            Simplify3D 5.1.2
                            • T3P3Tonyundefined
                              T3P3Tony administrators
                              I am on my phone right now so can't check but I thought the latest version of DWC has the ability to set the number of AJAX timeout retries…
                              www.duet3d.com
                              • appjawsundefined
                                appjaws
                                Yes you are right, I've just set it to 3 so I will see how that performs.
                                Simplify3D 5.1.2
                                • botundefined
                                  bot
                                  In regards to the WIFI channel selection, there are free programs available that detect and list all SSIDs in range, their strength, and the channel they are broadcasting on. This is really useful information for selecting a channel to use for your own SSID.
                                  Microwave ovens can disturb wifi signals at 2.4Ghz. As can wireless landline telephones.
                                  *not actually a robot
                                  • DjDemonDundefined
                                    DjDemonD
                                    I'll try independently testing the increase retries for dwc (how do I set this?) and installing a WiFi access point in the room near to the printer.
                                    • DjDemonDundefined
                                      DjDemonD
                                      Definitely fewer disconnects with a router in the room with the printer in it, on a clear channel and fairly close by.
                                      • DjDemonDundefined
                                        DjDemonD
                                        Switched to Chrome Canary and had even fewer but still maybe 2 today in about 3-4 hours. This is not really a problem. Still unsure why these are happening though.
                                        • Russ Griesundefined
                                          Russ Gries
                                          also for me i get a lot of timeouts.
                                          it dose seem to be when its trying to do something, like download a file or during printing.
                                          some times when i go to the G code tab it starts lagging and will not display stuff, or just time out.
                                          I think part of this is the connection for me ( but I'm not sure of that yet) , but i though i would post for more feed back!
                                          ~Russ
                                          One Day At A Time…
                                          My Main Research Page:
                                          http://rwgresearch.com/open-projects/3d-printing-research/
                                            FWIW the WiFi received signal strength is reported to the USB port when you enable WiFi. This might help diagnose connection issues. I'll make it easier to retrieve this information in a future firmware release.
