Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
  • Just wired up the Duet 2 Wifi. I just went thru the config wizard online. I am very unsure on what I did. I have an Ender 5 Plus with the Micro Swiss all metal direct drive setup. Thats the only mod I have so far. I need someone that is familiar with an Ender 5 Plus and obviously the software to look at my config.g and whatever else. I am scared to power on the board and possibly blow up my living room. I need someone to dedicate 30 min or so to go over everything with me before I turn it on. The E5+ comes with the BL Touch. Using 3.11 FW. Also have a Paneldue 5i. Please PM me if interested. You will be compensated for your time!!!
  • there is a guide for the ender 3 pro
    the ender 5 pro is close enough that most of the guide still applies
    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
    the duet wifi uses R4700 for the thermistor instead of R2200
  • @Veti Wiring is done. I don't want to guess anymore. I just want someone to check it over and help me with issues I might have in the beginning. Its a 5 Plus.....not pro....Plus is 350x350x400.
  • @Veti I dont know what R4700 or R2200 is.
  • @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
    still a cartesian printer and just a bit bigger than the pro.
    post some photos of the wiring and your config.g
  • ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Nov 14 2020 01:05:16 GMT-0500 (Eastern Standard Time)
    M550 P"E5Plus" ; set printer name
    M551 P"xxxxx" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X80.00 Y80.00 Z400.00 E130.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X350 Y350 Z400 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P9 C"^!zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M143 H0 S110 ; set temperature limit for heater 0 to 110C
    M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
  • Also, what do you think about putting little heatsinks on the driver chips like the stock board has?
    zprobe in does not normally need to be inverted for the bltouch.
    the offset x and y is missing
    Then Beta value is incorrect, try the beta value from the guide, as creality tends to use the same thermistors
    you configured both fans to be Thermostatic controled. this way you have no part cooling fan that can be controlled.
    also add a T0 to the end of your config.
    do you have the motor specs for the ender 5 plus?
    but you could test these values and check the motor temperature by hand during printing.
    you might want to increase E800 to E900 as in the guide
    checking the marlin example config for the ender 5 plus
    https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Creality/Ender-5 Plus/Configuration.h
    #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 800, 93.02 }
    it seems you need Z800
  • Moderator
    Have you ever powered on the board with USB or anything yet?
    Part 3 of the guide veti linked above goes over initial commissioning. Moving motors safely to test, that sort of thing. Try taking a look at that.
    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
    The duet is pretty hard to kill, but there are a few wiring things you should absolutely double check.
    First is your motor phase pairings. Failure to get the pairs right would probably just lead to an error message and the motors not working, but it could also damage the drivers, so best to get it sorted first. Here's how.
    https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
    Second is the fan polarity. Positive and negative must be the right way round or you're likely to damage the fan or the fan mosfet on the board or both, so make sure you've got that sorted out before testing the fans.
  • @Phaedrux said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
    Yes
  • @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
    I will go back in the configurator and post my fixes. Thanks! Most of what u said is chinese to me but I will do some googling and try
  • None of these values will autopopulate after I turn it on and auto homes itself and tests itself out?
  • @shatty
    which part did you not understand? please be specific, then we can further elaborate.
    no.
  • @shatty
    Did you ever learn how to ride a bicycle?
    If so do you remember the leap of faith you had to make without the safety net of training wheels?
    Follow the steps to get the printer running, check your wiring multiple times, and trust yourself and take the leap, and flip the switch.
  • @CaLviNx said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
    @shatty
    LOL. I didnt think it would be this complicated before I installed it. I thought it would be a quick swap. Anyways theres no turning back now.
  • @Veti Hows this?
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
    M569 P3 S0 ; physical drive 3 goes backwards
    M92 X80.00 Y80.00 Z400.00 E412.60 ; set steps per mm
    M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
    M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
    M557 X15:190 Y15:190 S20 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 1 as thermistor on pin e0temp
    M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
    I dont see where the Heater for the hot end should max at 280. Also there are 2 fans on the hot end. Shouldnt the values be identical? I got a lot of the fixes from someones 5 Pro config
  • Moderator
    Add M143 H1 S280 at the end of the heater block under the M307.
    Otherwise I don't see any obvious issues.
    You can send M98 P"config.g" in the console to see if there are any syntax errors.
    Otherwise it's time to do some testing.
    as i posted earlier the Z steps according to marlin are Z800
    delete the C4700 thats not the resistance. you can leave R empty and the correct default is choosen.
    M143 H1 S280
    OK so I edited and turned on.
    Seems ok. Temps are hovering at 22 deg C with heaters off.
    Motors are F'ed up. Z looks good. Its the X and Y. I got some error codes.
    11/16/2020, 1:18:45 AM M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DLM-996RU-N8PS0-6J1DJ-3SD6K-KSSHN
    Used output buffers: 3 of 24 (11 max)
    Static ram: 27980
    Dynamic ram: 93672 of which 44 recycled
    Exception stack ram used: 264
    Never used ram: 9112
    Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:04:52 ago, cause: software
    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8240 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 24.7, current 25.6, max 26.1
    Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-11-16 01:18:41
    Cache data hit count 507426640
    Slowest loop: 6.91ms; fastest: 0.12ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 3.8ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.88ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address f4:cf:a2:66:99:4f
      WiFi Vcc 3.38, reset reason Unknown
      WiFi flash size 4194304, free heap 23640
      WiFi IP address 192.168.2.8
      WiFi signal strength -43dBm, reconnections 0, sleep mode modem
      11/16/2020, 1:17:30 AM M120 G91 G1 X-1 F6000 G90 M121
      Error: G0/G1: insufficient axes homed
      11/16/2020, 1:14:17 AM Connection established
      11/16/2020, 1:13:42 AM Connection interrupted, attempting to reconnect...
      11/16/2020, 1:13:32 AM Emergency Stop! Reset the controller to continue.
      11/16/2020, 1:13:32 AM Emergency stop, attemping to reconnect...
      11/16/2020, 1:13:31 AM Warning: motor phase B may be disconnected reported by driver(s) 2
      11/16/2020, 1:13:26 AM Warning: motor phase B may be disconnected reported by driver(s) 2
      11/16/2020, 1:13:22 AM Warning: motor phase B may be disconnected reported by driver(s) 2
      11/16/2020, 1:13:17 AM Warning: motor phase B may be disconnected reported by driver(s) 0 1 2
      11/16/2020, 1:13:16 AM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
      11/16/2020, 1:13:07 AM Connection established
      11/16/2020, 1:12:52 AM Connection interrupted, attempting to reconnect...
      HTTP request timed out
      11/16/2020, 1:12:40 AM Upload of config.g successful after 0s
      11/16/2020, 1:07:50 AM Connected to 192.168.2.8
    M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
    M143 H1 S280 ; 280 deg max on hot end
    M98 P"config.g"
    11/16/2020, 1:23:54 AM M98 P"config.g"
    HTTP is enabled on port 80
    FTP is disabled
    TELNET is disabled
    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
    I have that little daughter board connected for the bed heat. Looks like a relay board. Bed heat output on D3D connects to smaller board. Looks like the bed heat output triggers that smaller board. But if you think I should connect the bed straight to bed out on D3D I will
    this indicates that your wiring of the phases are incorrect.
    see
    https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
    see
    I triple checked them. I compared from the stock board to the D3D. I will check again
