    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • Vetiundefined
      Veti @shatty
      @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
      Anyways....hitting any positive value will move each toward the endstop switch...
      that would indicate that your motors are turning in the wrong direction.
      shattyundefined 1 Reply Last reply Reply Quote 0
      • shattyundefined
        shatty @Veti
        @Veti
        OK Let me fix that.
        • Vetiundefined
          Veti @shatty
          The Z axis motors are fighting each other.
          that means on of your motors is wired in the opposite direction
          • Vetiundefined
            Veti @shatty
            TS is fine.
            i beg to differ. The bad command 55 at the end is an indication.
            • shattyundefined
              shatty @Veti
              @Veti Thats because I hit stop
              Not the motors are moving away from endstops with hitting the positive values. Z still fighting each other. They are in series config because there are 2 on 1 driver
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • shattyundefined
                shatty
                Paneldue5i is connected with ribbon cable only. How can it be wrong?
                • Vetiundefined
                  Veti @shatty
                  that mean you have to reverse the wiring of one of your stepper motors
                  • shattyundefined
                    shatty @Veti
                    @Veti
                    OK. TY. Hopefully I can gain progress now.
                    • shattyundefined
                      shatty @shatty
                      @shatty
                      Z wired right. Only thing is...small little problem....THE WIRE IS CUT!!! THRU 3 OF THE 4 WIRES ON ONE OF THE Z STEPPERS!!!!!
                      • shattyundefined
                        shatty
                        Luckily MicroCenter doesnt sell them. F me. They sell a bunch of Creality replacement parts. 10 min from me. Amazon it is. Ugh
                        I could repair it but its a new machine and i dont want to.
                        • Vetiundefined
                          Veti @shatty
                          @shatty
                          where is the wire cut?
                          • shattyundefined
                            shatty @Veti
                            @Veti Dead center LOL.
                            I wish they has a motor upgrade pack for this printer instead of buying them individually. I want .9 motors
                            I can have the new wires here by tomorrow, Sunday
                            • shattyundefined
                              shatty
                              Also, anyway of using the stock screen with the new Beta RR firmware? I saw it now supports 2 other screens. I dont know what chipset the stock screen has
                              • Vetiundefined
                                Veti
                                do you have Heat-shrink tubing? or a solder iron.
                                fixing cut wiring is not that difficult
                                • shattyundefined
                                  shatty @Veti
                                  @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                                  Yes of course....Im in IT.
                                  I would rather buy new cables with the 4 pin already on them.
                                  • shattyundefined
                                    shatty
                                    They also have jacketed wire but not terminated. Better protection.
                                    • shattyundefined
                                      shatty
                                      Im just gunna repair it. Not in the mood to change shit around. Let u know what happens tom night. Thanks for the help
                                      • shattyundefined
                                        shatty
                                        Well guess what...............HOMING WORKS!!!! Went to the endstops and stopped! Question...Z axis...positive value is up or down? Z positive and the bed moves down. I have a feeling its supposed to be reversed. I repaired the wire on one of the Z stepper wires.
                                        • shattyundefined
                                          shatty
                                          And the BLT is making the bed stop moving up so that works. Now I guess I have to do a test print and adjust the distance from the nozzle to the bed, make sure the BLT is working on leveling, extruder speed, and manual bed leveling before I use the BLT
                                          • Vetiundefined
                                            Veti @shatty
                                            when the bed is at the bltouch trigger that is z=0 the further the bed moves away from the bltouch, z increases.
                                            so for the ender 5 plus i think going down is positive
