    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • shattyundefined
      shatty @Veti
      @Veti Hows the bed leveling?
      • Vetiundefined
        Veti
        looks good, just dont printer on the borders of the bed, continue on.
        • shattyundefined
          shatty
          Getting error on bed heat....saying its not rising fast enuf...1.7c a sec. I also have the bed connected to the mosfet that came with the stock setup.
          shattyundefined 1 Reply Last reply Reply Quote 0
          • shattyundefined
            shatty @shatty
            @shatty Should I do the auto tune?
            • Vetiundefined
              Veti @Veti
              @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
              yes calibrate the z probe.
              https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
              then do a mesh bed leveling and look at the bed. (post a picture)
              then calibrate your e steps
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
              then pid tune your bed and hotend.
              https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
              then print a benchy and asses.
              refer to the list i previously posted
              • shattyundefined
                shatty
                This post is deleted!
                • shattyundefined
                  shatty @Veti
                  @Veti
                  Ok so I got it to start printing benchy. I couldnt do the esteps measurement because it looks like I cant with the DD extruder I have. Anyways, its extruding too much. The nozzle is pushing the extruded filament around. So how do I cut it in half. I will play around with it till its perfect. Im using PLA that came with the printer. Printing at 220 with bed at 65. I have steel nozzle and I read that I should print 5-10 degrees hotter than normal.
                  Vetiundefined 1 Reply Last reply Reply Quote 0
                  • Vetiundefined
                    Veti @shatty
                    @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                    steel nozzles are very bad for pla printing.
                    what direct extruder have you got?
                    • shattyundefined
                      shatty @Veti
                      @Veti Microswiss direct drive all metal extruder/hotend. I lowered the e-steps/mm down to 130 as recommended by Microswiss. So far so good! I will post pics of benchy when its done. Im also going to be printing carbon fiber which i picked up already. Im sure Im going to be using other materials. It came with PLA so Im using it for now
                      https://store.micro-swiss.com/products/micro-swiss-direct-drive-extruder-for-creality-ender-5
                      • Vetiundefined
                        Veti
                        i would recommend that you get a plated Copper nozzle. it can print pla and carbon fiber as well.
                        https://www.aliexpress.com/item/4000007458595.html
                        shattyundefined 2 Replies Last reply Reply Quote 0
                        • shattyundefined
                          shatty
                          Any prebuilt filament files I can download anywhere? I might have a brass nozzle somewhere. Im not going to use PLA after this. I have PETG as well as the CF.
                          • shattyundefined
                            shatty @Veti
                            • shattyundefined
                              shatty @Veti
                              @Veti IMG_2609.HEIC IMG_2610.HEIC IMG_2611.HEIC IMG_2612.HEIC IMG_2613.HEIC IMG_2616.HEIC IMG_2617.HEIC IMG_2618.HEIC
                              • Vetiundefined
                                Veti @shatty
                                @shatty
                                i cant view those images. can you post normal jpgs?
                                  It looks like it was printed too hot. So dial it back to 200 and see how it goes.
                                  • shattyundefined
                                    shatty @Phaedrux
                                    • shattyundefined
                                      shatty
                                      Not bad for a first print! LOL I was at 220. Where can I set my bed temps and extruder temps during printing? In the filament config.g?
                                        Phaedrux Moderator @shatty
                                        You set them in the slicer. Then during a print if you want to change them, you can use the web interface to entire a new temperature.
                                        • shattyundefined
                                          shatty @Phaedrux
                                          @Phaedrux TY. During heat up if i were to set in the UI, it would always revert. I had to wait until pre-heat was done
                                          • shattyundefined
                                            shatty
                                            Also, Im using Creality Slicer. What is a good nonbranded software? Like top-notch. And how do I earn 1 reputation? This 60 sec post thing is annoying
