Help me get connected to my Duet2Wifi
What URL are you using to try and reach the Duet?
@Phaedrux 192.168.1.3
@Phaedrux I connected to YAT and went through the steps in the guide and confirmed the URL
Have you tried a new SD card yet in case the /www folder has been corrupted?
@Phaedrux I also turned off all other wifi devices and deleted them from my router for now untill I get the duet connected
Just copy to a new card?
Yes you can copy to a new card, but I would manually replace the contents of the /www folder with a known good download of the DWc files just in case.
Assuming you're on 3.2, you should replace the contents of /www with the contents of this zip file.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
If you're still getting the error after replacing the SD card, please open up the developer console of your browser so we can see exactly where the error is being thrown.
Yea same message. whats the developer console?
Assuming you're using chrome: https://developers.google.com/web/tools/chrome-devtools/open
control-shift-J
@Phaedrux Ok I think I got it. There is a side bar now
@Phaedrux let me know how to proceed
Try to go to the DWC and see what errors come up in the side bar. Take a screen shot and post it here.
Can you try access the DWC ip address from an incognito chrome window?
@Phaedrux Ok for some reason it connected to the board with the incognito window
I think you have a browser extension blocking the connection or somehow modifying it.
@Phaedrux yea has to be something like that. At least now I have the URL reserved on the router. I can get by on the incognito window until I figure out what is interrupting the connection
So I ended up moving my operation into a commercial building and I need assistance getting the Duet connected to the new network. I installed YAT but M552 came back with "BAD Command"
screen shot?
