    touch screen and virtual keyboard
    503
    • Tinchusundefined
      Tinchus
      I have this setup: duet3 + raspberry and now Im switching from octopi towards the duet control interface. So I downloaded the duet raspbian image and duet3 is now connected through SPI to the raspberry board.
      And I connected a 7'' touch screen. Everything looks ok, but in the fields where I should input data, the virtual keyboard just doesnt popup and I have to connect a real USB keyboard, somehting I wich to avoid. Do you have information on what I need to install in your software in order to have the virtual keyboard to pop up (if this is possible)
      Thanks in advance
      dhusoloundefined 1 Reply Last reply Reply Quote 0
      • dhusoloundefined
        dhusolo @Tinchus
        @Tinchus Why don't you have the Duet 3 connected through SPI?
        Tinchusundefined 1 Reply Last reply Reply Quote 0
          Did you download DuetPi from here?
          https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3#Section_Step_1_Flash_the_image_file
          Have you updated the pi with sudo apt update sudo apt upgrade yet?
          When it boots up does it connect to the duet web interface?
          How do you have the duet and pi connected?
          • Tinchusundefined
            Tinchus @Phaedrux
            @Phaedrux Yes, following your previous recomendations, I decided to give it a try and downloaded the the duetPi image, and connected the duet3 and raspberry using the SPI connection. I did the upgrade later in the console. When it boots it connects, I can see the duet panel on the touch screen, the touchscreen is working, the only thing not working is the virtual keyboard.
            • Tinchusundefined
              Tinchus @dhusolo
              @dhusolo sorry, my bad, a typo mistake. I meant to writ "is NOW connected"
                jay_s_uk @Tinchus
                @Tinchus which version are you running of RRF?
                Have you enable the on screen keyboard plugin?
                Tinchusundefined 2 Replies Last reply Reply Quote 0
                • Tinchusundefined
                  Tinchus @jay_s_uk
                  @jay_s_uk 3.1.1
                  No, I didnt activated that plugin, how do I activate it?
                    jay_s_uk @Tinchus
                    @Tinchus general settings on the left hand side and then there should be a tab called plugins.
                    Can't remember whether the onscreen keyboard is part of 3.1.1 or is only part of the 3.2 betas
                    • Tinchusundefined
                      Tinchus @jay_s_uk
                      @jay_s_uk As I can see, it says it requires DWC 3.2 beta 3
