    Duet 3 and PC local ethernet connection
    • kvi94
      kvi94 last edited by
      Can Duet 3 be connected to a PC via ethernet cable and using DWC as control interface? If yes, what are the required changes?
      Thank you.
      • alankilian
        alankilian last edited by alankilian
        Yes it's possible.
        Here's a thread that discusses this configuration.
        kvi94 1 Reply Last reply Reply Quote 0
          You would need to manually configure your PC and Duet to have unique IP addresses within the same Subnet.
          Ex: 192.168.0.2 and 192.168.0.3
          Manually configuring the IP address on your PC is pretty easy. Best to google if you're not sure.
          For the Duet, you can specify the IP address in your config.g by editing the M552 command.
          https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M552_Set_IP_address_enable_disable_network_interface
          ex M552 S1 P192.168.0.3
          Then you could access the web interface from the PC browser by using the IP address of the duet in the address bar.
          Also make sure you Duet 3 SD card has the /www folder with all the DWC files as well.
          • kvi94
            kvi94 @alankilian last edited by
            @alankilian said in Duet 3 and PC local ethernet connection:
            Yes it's possible.
            Thanks @alankilian for the link. I went through it before posting, hence I wanted to confirm that the feature would work on duet 3.
            @Phaedrux said in Duet 3 and PC local ethernet connection:
            Thanks @Phaedrux for the modifications and tips.
