    "Z" axis problems CNC
    My Duet controlled machine
    987
    • onescentproundefined
      onescentpro
      I am working with a Duet 2 controller on my Workbee CNC. Everything use to work fine but lately it doesn't home properly. When I try to home all, the "Z" axis just grinds and slowly moves down causing me to hit the emergency stop. I have gone thru all the settings in the system file and everything looks good as far as bed size goes. I have changed Duet boards thinking it may be the board and it does the same thing. I also changed the Z axis servo motor and that wasn't it either. Please let me know if anyone has had a similar problem and let me know how I may correct this. Thanks in advance to anyone who responds.
      • A Former User?
        A Former User
        More info needed. It moves down, is that the correct direction?
        Servo? External driver?
        Are the endstops working?
        Config and homing files attaches would certainly help others understand whats going on.
          onescentpro
          Yes, the Z axis should go up and trip the relay but instead just grinds and slowly moves down toward the bed. I will try to send more info.
          2020-11-25.png 2020-11-25 (5).png 2020-11-25 (4).png 2020-11-25 (3).png 2020-11-25 (2).png 2020-11-25 (1).png
          engikeneerundefined 1 Reply Last reply Reply Quote 0
          • A Former User?
            A Former User
            Please copy and paste the text instead of screenshots.
            you can also use the code formatting to make it more readable
              onescentpro
              Sorry but I'm not sure I understand what you mean by text.
                onescentpro
                ; generated by RepRapFirmware Configuration Tool v3.1.8 on Tue Nov 24 2020 10:04:16 GMT-0600 (Central Standard Time)
                M550 P"My Workbee CNC" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X230 Y210 Z200 S0 ; set axis maxima
                M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                M557 X15:215 Y15:195 S20 ; define mesh grid
                homeall
                ; homeall.g
                ; called to home all axes
                G91 ; relative positioning
                G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000 ; go back a few mm
                G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G90 ; absolute positioning
                G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                ;G91 ; relative positioning
                ;G1 Z5 F100 ; lift Z relative to current position
                ;G90 ; absolute positioning
                • A Former User?
                  A Former User @onescentpro
                  @onescentpro said in "Z" axis problems CNC:
                  I take it you're using stepper motors with the built in drivers and not servo motors?
                  If z is going the wrong way the simple explanation is perhaps to have plugged it the wrong way around (although if using the supplied connectors that's not something you do by accident)
                  if you've tried another motor and another board then you're left with the wiring, one of the conductors coming loose sounds like it could be a good fit, but the duet normally alerts to a disconnected phase.
                  onescentproundefined 2 Replies Last reply Reply Quote 0
                  • engikeneerundefined
                    engikeneer @onescentpro
                    @onescentpro might be a result of the issue rather than the cause, but given your screenshot show an error message 'Z probe already triggered at start of homing move' I'd start there. What type of probe are you using? What value does the probe show in DWC normally/when you tap it by hand?
                    Maybe try using the R parameter in your M558 so there is a pause for it to settle?
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                    I'd also double check the wiring to it
                    RE Bearer's posting comment, there is a formatting option on the forum when putting your coding which puts it in nice boxes etc to make it easier to read (like the line of text he put). The option is two over from bullet points at the top (you can see in his screenshot).
                    i3 clone with a bunch of mods
                    onescentproundefined 1 Reply Last reply Reply Quote 0
                      onescentpro @A Former User
                      @bearer , Good morning, I saw and old post from you that mentioned you could log into my computer and take a look. Is that a possibility for you?
                        onescentpro @engikeneer
                        @engikeneer Thanks for the reply. I am using the endstops supplied by Ooznest. I have checked the wiring to the stepper motor and its fine. The endstop appears to working fine when I manually close it the light comes on on the Duet so I think it's fine.
                          @bearer I am using everything that was supplied for the Workbee from Ooznest. Yes, I am using steppers controlled by the Duet
                            Phaedrux Moderator @onescentpro
                            So no Z probe at all?
                            Your config.g and homing files are setup as if you had a Z probe. Please let me know if that is the case or not.
                              onescentpro
                              Thanks for all the input. I got everything up and running. So thanks to all who helped me with this problem.
