Unsolved ToolBoard: 2 wires fan, heater fault and how to extrude ?
@Pseud3mys
some fans do not work with pwm. -
@Veti I just see that is a 24v fan, I power the board with 12v. But if I power with 24v did the output will go up 24v as well ?
@Pseud3mys said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
no
see the wiring diagram.https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board
the out is 12v
ah yes, thank you
@Veti have you an idea for the heater fault or the cold extrusion ?
I send M302 P1 to allow cold extrusion, and I test if the command went good:
"Cold extrusion is allowed (use M302 P0 to forbid it)"but I still can't use it:
what is the error message in the console?
@Veti there are no error message. When I click on the "extrude" button nothing happen
@Pseud3mys
for the heating. how did you get the error?you still have not posted your config.g
@Veti for the heating a fault accure 2 or 3 sec after the start. But the temperature problem is good now.
here is my config..g:
config.g; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.9 on Wed Dec 02 2020 17:31:45 GMT+0100 (heure normale d’Europe centrale) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MultiTool Cartesian" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P1.0 S1 ; physical drive 1.0 goes forwards M569 P2.0 S1 ; physical drive 2.0 goes forwards M584 X0.0 Y0.1 Z0.2 E1.0:2.0 ; set drive mapping M350 X256 Y256 Z256 E256:256 I0 ; configure microstepping without interpolation M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X31800.00 Y31800.00 Z31800.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800:800 ; set motor currents (mA) M84 S0 ; Disable motor idle current reduction ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1000 Y1000 Z800 S0 ; set axis maxima ; Endstops ; WARNING: No endstops configured ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X20:980 Y20:980 S80 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"121.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M308 S2 P"122.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin 122.temp0 M950 H2 C"122.out0" T2 ; create nozzle heater output on 122.out0 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S280 ; set temperature limit for heater 2 to 280C ; Fans M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency M106 P0 S0 H1 T100 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"122.out2" Q500 ; create fan 1 on pin 122.out2 and set its frequency M106 P1 S0 H2 T100 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"Extrudeur 0" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Extrudeur 1" D1 H2 F1 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M563 P2 S"Spindle" F-1 ; define tool 2 G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory
what is the error message for that.
this will overload your cpu. switch back to x16 and interpolation.
are you sure thats the maximum speed you printer can achieve?
these values are most likely wrong. you need to enter 75% of the rated current for each motor.
you need to fix this
I allowed the cold extrusion. I can now extrude but when I do it nothing happen.
For the heating, the thermistor return the right temperature. But I still have "fault" few second after I turn ON the heater. -
we need to know what the error message is.
btw are you on firmware 3.1.1 ?
No, I didn't begin setting up this part. Now, I just try to set up the dual extrudeur and hotends.
@Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
yes
I understood, but I have no error message or I don't now where i can see it.
I click on "Heater 2". It turn active, and after fews seconds It turn "fault" as you can see on the picture. But I have no error (even in the consol) -
you can find the error messages in the console or in the popup at the bottom right when they occur.
I just tested but I don't have any error message (I checked the console and there is no pupop when it stop working)
are you on duet web control 3.1.1 as well?
I think yes, what is the command to check ?
