    ToolBoard: 2 wires fan, heater fault and how to extrude ?
    5.5k
    • Pseud3mysundefined
      Pseud3mys @Veti
      This post is deleted!
        Pseud3mys
        M122 B121 command (for the tool board):
        02/12/2020 à 19:29:11 M122 B121
        Diagnostics for board 121:
        Duet TOOL1LC firmware version 3.2-beta4 (2020-11-26)
        Bootloader ID: not available
        Never used RAM 4700, free system stack 96 words
        HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 64
        Last reset 00:03:22 ago, cause: software
        Last software reset data not available
        Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 35710, writes 9, timeouts 0, DMA errors 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0
        No step interrupt scheduled
        VIN: 12.2V
        MCU temperature: min 22.6C, current 25.2C, max 25.2C
        Ticks since heat task active 46, ADC conversions started 202540, completed 202539, timed out 0
        Last sensors broadcast 0x00000000 found 0 50 ticks ago, loop time 0
        CAN messages queued 16, send timeouts 0, received 1906, lost 0, free buffers 36
          Pseud3mys
          and for the mainboard:
          02/12/2020 à 19:34:16 M122
          RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (standalone mode)
          Board ID: 08DJM-956BA-NA3TJ-6J1D2-3SD6M-9B9LT
          Used output buffers: 1 of 40 (12 max)
          Static ram: 123212
          Dynamic ram: 168576 of which 752 recycled
          Never used RAM 99652, free system stack 200 words
          Tasks: NETWORK(ready,171) ETHERNET(blocked,110) HEAT(blocked,317) CanReceiv(blocked,852) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1127) IDLE(ready,19)
          Owned mutexes:
          Last reset 00:00:46 ago, cause: software
          Last software reset details not available
          Error status: 0x00
          MCU temperature: min 37.9, current 39.0, max 39.3
          Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 11.4, current 11.4, max 11.5, under voltage events: 0
          Driver 0: position 0, standstill, reads 35416, writes 14 timeouts 0, SG min/max 0/0
          Driver 1: position 0, standstill, reads 35417, writes 14 timeouts 0, SG min/max 0/0
          Driver 2: position 0, standstill, reads 35418, writes 14 timeouts 0, SG min/max 0/0
          Driver 3: position 0, standstill, reads 35422, writes 11 timeouts 0, SG min/max 0/0
          Driver 4: position 0, standstill, reads 35423, writes 11 timeouts 0, SG min/max 0/0
          Driver 5: position 0, standstill, reads 35424, writes 11 timeouts 0, SG min/max 0/0
          Date/time: 2020-12-02 19:34:15
          Slowest loop: 5.81ms; fastest: 0.15ms
          === Storage ===
          Free file entries: 10
          SD card 0 detected, interface speed: 25.0MBytes/sec
          SD card longest read time 2.4ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.69ms; fastest: 0.03ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • Ethernet -
            State: active
            Error counts: 0 0 0 0 0
            Socket states: 5 2 2 2 2 0 0 0
            === CAN ===
            Messages queued 171, send timeouts 0, received 896, lost 0, longest wait 2ms for reply type 6031, free buffers 47
          • Vetiundefined
            Veti
            duet 3 is also updated?
            any info on the heating now?
            Pseud3mysundefined 1 Reply Last reply Reply Quote 0
              Pseud3mys @Veti
              @Veti still no error, but now it show "fault" 1 second and after the web interface lost the board (2000°C and offline), but the M115 command still return that the can bus is connected
                Pseud3mys
                02/12/2020 à 19:42:27 M122 B122
                Diagnostics for board 122:
                HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 70
                Last reset 00:01:20 ago, cause: software
                Last software reset at 2020-12-02 19:41, reason: HardFault, available RAM 4360, slot 0
                Software reset code 0x0060 ICSR 0x00000003 SP 0x200011c0 Task
                Stack: 20001014 00000011 0001d3e3 00000000 20000928 0001757d 000184fe 01000000 000202a8 000203a2 20001210 200032d8 00000020 00017d11 20004668 00000000 20001300 000086e5 000202a8 20004678 000203a2 4200af00 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 40161, writes 9, timeouts 0, DMA errors 0
                VIN: 12.3V
                MCU temperature: min 30.8C, current 30.8C, max 30.9C
                Ticks since heat task active 127, ADC conversions started 80370, completed 80369, timed out 0
                Last sensors broadcast 0x00000000 found 0 131 ticks ago, loop time 0
                CAN messages queued 22, send timeouts 0, received 732, lost 0, free buffers 36
                it seem than the borad restart..
                • Vetiundefined
                  Veti
                  same thing happens on the first board?
                    Pseud3mys @Veti
                    @Veti yes, even with no heater connected
                    • Vetiundefined
                      Veti
                      ok this is one for dc42 what the hardfault means.
                        Pseud3mys
                        but when there are no target temperature this not happen.
                        I checked, the board reset.
                        I would also like to add than I didn't load filament, I put the temperature by hand.
                          Pseud3mys @Veti
                          @Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
                          sorry, I didn't understand ? what is dc42 ?
                          • Vetiundefined
                            Veti
                            just for testing execute
                            M307 H2 A597.2 C231.1 D12.5 S1.00 B0
                            and try heating again
                            Pseud3mysundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                              Pseud3mys @Veti
                              @Veti
                              raise this:
                              02/12/2020 à 19:50:36 M307 H1 A597.2 C231.1 D12.5 S1.00 B0
                              Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 622C
                              • Vetiundefined
                                Veti @Veti
                                the question would be. who is @dc42
                                https://forum.duet3d.com/user/dc42
                                but can you heat afterwards? i thought you are trying heater 2
                                  Pseud3mys @Veti
                                  @Veti ah okay.
                                  I tried, heater keep running a little bit longer but the same issues appear.
                                    Pseud3mys
                                    @dc42 Hello, I have a fault with my heater (on Tool 1LC), with no error message. After a fews seconds when I start to heat, the heater pass in fault statement and in beta4 the tool board reset one second after the fault statement.
                                    Can you help me ?
                                      What does your heater graph look like when you get the fault?
                                      What shows up in the gcode console?
                                      Pseud3mysundefined 2 Replies Last reply Reply Quote 0
                                        Pseud3mys @Phaedrux
                                        The graph start just ascend (like 10/20°c) and then the heater change to fault state and the graph start slowly getting down.
                                        And I have nothing on the console, no error just the heater with "fault" under it.
                                          Pseud3mys @Phaedrux
                                          @Phaedrux and with the beta4 the toolboard reboot when I get the error (so the temp is 2000°c for the graph)
                                            dc42 administrators @Pseud3mys
                                            @Pseud3mys said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
                                            R25 (kΩ): 500 ± 3%
                                            β25/85 (K): 3800 ± 2%
                                            I find this for the thermistor.
                                            M308 S1 P"121.temp0" Y"thermistor" T500000 B3800
                                            so I put this, the temp is 12°c when it must be ~19 I think. I have always the fault, do you now what I nead to change ?
                                            At low temperatures, high resistance thermistors like that one have poor resolution and accuracy. So your settings may well be correct. You may be able to reduce the displayed error by adjusting the H parameter in the M308 command for that sensor.
