    Did my board jist fry?!!! All lights work...but no movement?
    non-responsive please help troubleshooting
    723
    • skunkworksundefined
      skunkworks
      I'm so bummed out right now if this is true.
      Worked fine after wiring. Over night nothing changed or even moved in the slightest position wise of the board on the "anti static bag"
      It stopped wotking.. Please help!?
      Ive been banging my head against the wall
      Thank you so much in advance!
      I had another stepper driver burn from a 4th axis module..
      Is my board fried?!! All lights work though.??!!
      It stopped working.. Please help!?
      Ive been banging my head against the wall pretty much.
      I had another stepper driver burn from a 4th axis module.. But all the lights look right?
      • A Former User?
        A Former User
        one post is enough btw
        check your fuse and tell us which board it is etc etc ref https://forum.duet3d.com/topic/5910/guide-for-posting-requests-for-help
        skunkworksundefined 1 Reply Last reply Reply Quote 0
          skunkworks @A Former User
          @bearer thank you! My board is thr Ethernet 2 maestro.
          I just replaced power supply. I noticed this when I did switch to 24v from 12v. Thats another possibility to look at?
          All lights and correct and voltages have been doublw checked
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @skunkworks
            @skunkworks said in Did my board jist fry?!!! All lights work...but no movement?:
            did you switch the heater cartridge and the bed?
            if not do not turn on your printer.
              What exactly stopped working?
              Can you still access the web interface?
                See https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond.
                  skunkworks @dc42
                  @dc42 Thank you so much for responding quickly!
                  https://youtu.be/V-bLzPDEdcE
                  Here is a video showing everything going on.
                  It has the right green lights. 23.9 v to the board. And the short happened After a wire came loose.
                  I saw it burn and give off a small amount of smoke to% my drivers. But signal chain wise the short must have come after the board? Is that true? I waz plugged from the duet the e0 to 4th axis module.
                  Thank you again
                    Phaedrux Moderator @skunkworks
                    4th axis module.
                    What is this?
                    • elmoretundefined
                      elmoret
                      Where did you buy the board from?
                        skunkworks @Phaedrux
                        @Phaedrux 4th axis cnc that I will send gcode to from the gorgeous duet browser gui.
                        Duet browser connects great, but when yoy try and jog the machine manually . whar used to work the night before perfectly... Stopped working the next day?
                        Can you see Or catch anything wrong with this video?
                        If there are diodes in the board after the stepper driver on the maestro 2, wouldn't they limit any current coming back up to the board?
                          skunkworks @elmoret
                          @elmoret Thank you. I bought it online years ago. Not sure I can remember. Why do ask?
                            Pull the board from the nest, disconnect any wiring, pull the SD card, and connect it to USB on your PC and see if anything shows up in device manager.
                            What LEDs light up when connected to USB?
                            Does anything get hot when connected to USB?
                            If it does show up in device manager, what does it show up as?
                            If it does show up as a Duet, can you connect to it via YAT terminal software?
                            • j3dundefined
                              j3d
                              Is it possible that the anti-static bag is conductive? Do what Phaedrux recommended and pull it out of the printer and place it on a non-conductive surface.
                              • A Former User?
                                A Former User
                                (Everything that is ESD had to be conductive to some degree in order for it to dissipate the static charge to ground (when connected to ground))
                                • j3dundefined
                                  j3d
                                  Yep, so my thought was that if the board was placed on an ESD bag while it was powered, the slight conductivity could have shorted some near-by pins on the back of the board.
