Duet2 WiFi Firmware on Raise 3d E2 ?
@Proschi78 yes
@jay_s_uk ok i will test it
you need to rename it to match the missing file
have you uploaded the file i sent you to the same place?
@jay_s_uk yes
@jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
iap4e.bin
did you rename it to Duet2combinesIAP.bin like the error message says?
where did you put the file on the sd card?
you are missing a 2 in the filename
@Veti yes
ok after restart it works
which firmware file did you use?
the files you send me
i did not send you any files
@Veti sorry I confused you with Jay
