rrf3 trigger g30 s-1 problem
  • Hello everyone I wish you happy holidays and to not let you get bored during Christmas I ask you my problem
    I went from release 2.05 to 3.1.1 in release 2.05 the commands to calibrate the Z 0 with my bltouch thinking it was child's play having already run it a thousand times.
    then I turn on the printer
    I launch the commands:
    g92 z0
    g1 z10
    g30 s-1
    as part of doing the check the error comes out
    G30 S-1
    Error: Z probe was not triggered during probing move
    cosa sto sbagliando?
    allego config.g
    config.g
  • post you config.g
  • è allegato
    eccolo comunque
    ; Configuration file for Duet Maestro (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.10 on Thu Dec 24 2020 09:57:02 GMT+0100 (Ora standard dell’Europa centrale)
    M550 P"draw2-200" ; set printer name
    M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P3 S0 ; physical drive 3 goes backwards
    M569 P4 S1 ; physical drive 4 goes forwards
    M584 X0 Y1 Z2 E3:4 ; set drive mapping
    M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
    M92 X100.00 Y100.00 Z400.00 E120.20:120.20 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1400 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X220 Y220 Z200 S0 ; set axis maxima
    M574 X1 S1 P"!^xstop" ; configure active-high endstop for low end on X via pin !^xstop
    M574 Y1 S1 P"!^ystop" ; configure active-high endstop for low end on Y via pin !^ystop
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
    G31 P500 X-28 Y-39.5 Z0.842 ; set Z probe trigger value, offset and trigger height
    M557 X20:200 Y20:200 S45 ; define mesh grid
    M143 H0 S100 ; set temperature limit for heater 0 to 100C
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
    M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
    M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H2 S280 ; set temperature limit for heater 2 to 280C
    M950 F0 C"!fan0" Q500 ; create fan 0 on pin !fan0 and set its frequency
    M106 P0 S0 H0 T35 ; set fan 0 value. Thermostatic control is turned on
    M106 P1 S1 H1:2 T30 ; set fan 1 value. Thermostatic control is turned on
    M106 P2 S1 H2:1 T30 ; set fan 2 value. Thermostatic control is turned on
    M563 P0 S"anteriore" D0 H1 F0:1 ; define tool 0
    M563 P1 S"posteriore" D1 H2 F0:2 ; define tool 1
    G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
    G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
    ; Custom settings
    ; DISPLAY
    M575 P1 S1 B57600
    ; config override.g
    M501
  • NO ONE HAS UNDERSTOOD WHERE WRONG
  • Moderator
    @luca-f13 said in rrf3 trigger g30 s-1 problem:
    G30 S-1
    Does it trigger with a G30?
    Can you send M122 and M98 P"config.g" and post the results?
    Does the bltouch pin deploy when you send M401 and retract when you send M402 ?
