    Printing
    Example setups and prints
    730
    • Vetiundefined
      Veti
      @Dodger said in Printing:
      confConfiguration file for Duet 0.6 (firmware version 1.21)
      what duet do you have?
      apparently you selected duet 1 in the config tool, yet you write you have a duet 2.
      what firmware version are you running?
      if you are starting new and you have a duet 2 you should update to firmware 3.11.
      see https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
      do not forget to update the wifi firmware and the duet web control.
      easiest is to update using bossa if you have a very old version.
      then go through these steps.
      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
      Dodgerundefined 1 Reply Last reply Reply Quote 0
        Phaedrux Moderator @Dodger
        I cannot open the web page
        How are you trying to connect?
        What IP address does the Duet have?
        As this is a wifi, how have you added the SSID and password?
        • Dodgerundefined
          Dodger @Veti
          @Veti the config may say it is for a duet o.6 but has been heavily modified. My firmware is 2.05
          • Dodgerundefined
            Dodger @Phaedrux
            @Phaedrux Long, rather weary, story. I thought I had fried my ethernet duet 2 so bought a wifi one. After a while I got a config file that appeared to do what it should so put it back in the ethernet board. I connected through YAT and for the first time got an IP address, I have now connected direct to my router and the USB cable and the web console actually opens but there is an error message. "Failed to get file list"" directory 0:/macros not found
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti @Dodger
              directory 0:/macros
              just create that folder on the sd card
              see
              https://duet3d.dozuki.com/Wiki/SD_Card
                When you have a USB terminal up please send M122 and M98 P"config.g" and post the results.
                What do you have on your SD card? It sounds like you're missing the directory structure. Are you perhaps also missing the web interface files as well?
                https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                • Dodgerundefined
                  Dodger @Phaedrux
                  @Phaedrux Yes I am probably missing something . I have inputted 'Duet2CombinedFirmware.bin' and confirmed that I have 2.05.1 entered. I have also loaded 'iap4e.bin'but I think need a web control input.
                  I suspect that my sys file is in a bit of a mess so will start from the beginning
                  • Dodgerundefined
                    Dodger @Veti
                    @Veti OK so I create a folder but where do the files for that folder come from,?
                    • Vetiundefined
                      Veti @Dodger
                      @Dodger
                      thats where your macros go
                      • Dodgerundefined
                        Dodger @Veti
                        @Veti thanks that seems to have done it
