    Mini 5 (with toolboard) and leveling using X2 Motors
    969
    • JayJayundefined
      JayJay @Phaedrux
      @Phaedrux said in Mini 5 (with toolboard) and leveling using X2 Motors:
      @JayJay said in Mini 5 (with toolboard) and leveling using X2 Motors:
      the mini-5 runs fine in there, so im not sure why it doesnt like being in my hacked up i3
      That is confusing. An intermittent short in something connected?
      its the exact same wiring between the mini-5 and the Duet-2 and i thought about that and have been probing for shorts and found nothing
        Some thoughts:
        • Is the tool board definitely running 3.2RC2 as well?
        • Try adding a settling delay parameter (R) to the M558 command, e.g. R0.2 or R0.5
        • You said the probe doesn't register as triggered, yet you don't get a head crash. That means either the dive height is too low to probe deep enough, or the probe trigger is being registered for the purpose of stopping the Z move but not for the purpose of recording the stop height. So try increasing the dive height - very carefully!
        • JayJayundefined
          JayJay
          @Phaedrux
          @Veti
          Well I finally fixed it....
          My homeall.g had G30 S-3 in the script.
          I removed that and changed it to single G30 command on its own and now it completes the G32 action with no errors, I dont know why it works fine on my Duet-2 with the S-3 switch in my homeall but the mini 5 doesnt like it
          dc42undefined 1 Reply Last reply Reply Quote 1
            dc42 administrators @JayJay
            @Phaedrux
            @Veti
            Perhaps your Duet 2 is running old firmware that doesn't support the S3 parameter?
            JayJayundefined 1 Reply Last reply Reply Quote 0
            • JayJayundefined
              JayJay @dc42
              @dc42 said in Mini 5 (with toolboard) and leveling using X2 Motors:
              @Phaedrux
              @Veti
              The Duet-2 was/is on Release 3.2-RC1
              And to confirm
              Duet-2 WOULD complete the action with G30 S-3
              Duet-3 Mini-5+ WOULD NOT complete the action G30 S-3
              The Mini-5+ would only complete after i removed the S-3 switch
