    All 5 Stepper Motors Grinding/Stalling
    434
    • yogibearundefined
      yogibear
      Hey Guys,
      I have setup my printer with new Duet Wifi board. After setting it up, the first thing I did was clicked on the default macro "Test Motor" that came with the board pre-installed. When I test, the motor starts stalling without any moment. I updated the config.h file & tried to home the axis and still had the same stalling issue.
      Please help me in this regard. I have attached the pictures & my config.h file details below. I still need to update heater section in config.h file once this issue is resolved.
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Sat Jan 02 2021 10:29:10 GMT-0500 (Eastern Standard Time)
      M111 S0 ; Debug off
      M555 P2 ; Set output to look like marlin
      G21 ; mm
      M550 P"BD Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M350 Z16 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y400.00 Z400.00 E404.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z20.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X900 Y2000 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S50 ; Set idle timeout
      M208 X250 Y250 Z250 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X55 Y5 Z2 ; set Z probe trigger value, offset and trigger height
      M557 X55:200 Y55:200 S20 ; define mesh grid
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on
      M563 P1 D0 H1 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      T1 ; select first tool
        droftarts administrators @yogibear
        @yogibear DON'T use the test macros; they're for factory testing, and change the motor settings. Reset your Duet and follow the documentation for testing.
        Edit: longer explanation: Did you run '04-Test_motors' macro from the SD card? The macros on the SD card are for testing the Duet at the factory, not for testing your machine. It sets the motor to 2A, as well as trying to move the axes at high speed, and for 2 metres! In the test rig at the factory, it is just a motor, not connected. So please DO NOT USE the macros on the SD card for testing your machine. Follow the commissioning advice here: https://duet3d.dozuki.com/Wiki/Step_by_step_guide#Section_Commissioning_tests
        If you have these macros on the SD card, this also means you have an older board, as we changed the SD card contents to remove these macros quite a while ago.
        A Former User? 1 Reply Last reply Reply Quote 1
        • deckingmanundefined
          deckingman
          I could think of a dozen reasons off hand but the most likely ones in no particular order are
          1. Power supply issue. After trying to move the motors send M122 and look at the minimum voltage and any under voltage events.
          2. X Y and Z won't move unless they have been homed. Use M564 H0 to alow moves prior to homing.
          3. The stepper motor wiring is incorrect. Have you identified the motor phases and connected the wire accordingly? Scroll down this link to find out how https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
          yogibearundefined 1 Reply Last reply Reply Quote 1
          • RandyL00123undefined
            RandyL00123
            @droftarts said in All 5 Stepper Motors Grinding/Stalling:
            ger explanatio
            I would check your stepper motor wiring. Did you do the connections yourself? They are tricky and either don't go all the way down, don't lock into place or the wire can have a faulty connection...ie did you clamp onto the insulation properly and not the bare wire? Also, I notice you have your wire colouring codes backards as to the duet wifi wiring diagram. It may be nothing but make sure that your 1A and 1B go to one coil on the stepper motor and 2A+2B go to the other.
            • A Former User?
              A Former User @droftarts
              Could they be either removed before shipping (lot´s of extra work I guess nobody want´s to pay for) OR - maybe better - have the stuff updated:
              • the folder they sit in renamed to something like ("stand-alone factory test without any sensor, effector, motor etc. connected connected")
              • or
              • a default
              M291 R"FACTORY TEST!" P"ONLY USE IF NOTHING IS CONNECTED" S3
              or similar included in the files?
              Because I´ve seen quite a few of these posts in the forum, and it seems it is not yet clear to everybody...
              Cheers & best regards
              Lucas
              droftartsundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
                droftarts administrators @A Former User
                @LB the factory tests were removed from the shipping SD cards about a year ago. Not sure why some people are still receiving them; maybe still some old stock in channel with some resellers.
                • engikeneerundefined
                  engikeneer @A Former User
                  @LB as Ian said, they've already done that!
                  i3 clone with a bunch of mods
                  • A Former User?
                    A Former User @engikeneer
                    @engikeneer
                    @droftarts
                    Thanks for getting me up to date!
                    • yogibearundefined
                      yogibear @deckingman
                      @deckingman Thanks for the suggestions, the stepper wiring was incorrect, now it's working.
