Servo deployed probe on Duet Maestro
@Phaedrux Thanks, it's now showing as 0!
So I'm following the test guidance. To manually test. I've just ran G30 and the probe deploys and Z starts to move up but then an error is triggered.
G30
Error: Z probe was not triggered during probing moveIt may be one for the morning.... a clear head and do some more reading.
@Blacksheep99 said in Servo deployed probe on Duet Maestro:
Z starts to move up
This is ambiguous. Do you mean the probe and the bed are getting closer together?
G31 Z15 means the nozzle is 15mm above the bed when the probe triggers? Is that correct? Yet your dive height is only 5mm M558 H5.
@Phaedrux said in Servo deployed probe on Duet Maestro:
Z starts to move up
Sorry, I'll try be more clear. The bed starts to move up towards the nozzle which is on a fixed XY. The probe deploys immediately.
No the nozzle is close to the max 150mm build height. I've clearly misunderstood that part of the code.
Now that you have it working give this a shot
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
Your dive height should be slightly higher than your trigger height.
@Veti said in Servo deployed probe on Duet Maestro:
i am using this
https://www.thingiverse.com/thing:3303618
and it works on the maestro.
all the connections are going to the z probe header.
gnd is combined and 5v is combined in this case.
So I've ditched my old probe and made one of these today. I've connected it up and it seems to be working as it should. I just can't get my head around what I need to get this to work with my printer. By that I mean bring the bed up, probe deploy and then bed probed.
I'd appreciate some guidance, just to help my understanding.
its pretty close to bltouch. just select P8 instead of p9.
same retract and deploy scripts (might have to adjust the angles slightly)
although you need to add a M401 if you want to deploy it before and M402 when you want to retract.example homeall
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Jan 01 2021 18:39:48 GMT+0100 (Central European Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-240 Y-240 F240 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X10 Y10 F6000 ; go to first bed probe point and home Z M401 G30 ; home Z by probing the bed M402 ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
@Veti Thanks, I'll give this a try when I finish work. What about my config.g file? or does this replace what's currently in there?
So taking your example I modified my home all to try this. I changed the X and X to my bed size. Sending just the M401 command deploys the probe fine, the M402 retracts it.
This is my config.g code.
M574 Z1 S1 ; Set endstops controlled by probe M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch M558 P8 C"^!zprobe.in" H2 F900 T6000 ; Set Z probe type to switch and the dive height + speeds G31 P50 X50 Y-8 Z2.43 ; Set Z probe trigger value, offset and trigger height
When I home all the head moves out as expected, the bed starts to raise, probe deploys and the immediately retracts and the z stops.
My probe in the dashboard shows 0 when retracted and 1000 when deployed. Is the inverted pin causing an issue?
This is the bed and head setup. Excuse the chaos behind it!
Could be. Your description makes it sound like it assumes that it's triggered as soon as it deploys? Correct?
What happens if you don't invert the pin? Does probing work then?
yes it needs to be inverted
change to C"^zprobe.in"
Ok, I've changed this. The probe itself is off the bed. Do I need to add a move command for X and Y to move the head over the bed?
I current have the mesh compensation commented out in the config.g not sure if that should be active?
Probe now shows 1000 when retracted.
To test the probe is working I moved X and Y over the bed and tried to run G30. It doesn't run as it says probe is already deployed.
yes.
what exactly do you have commented out?
In your homing files you may want to add a M401 at the start to ensure that the probe is retracted and so that the firmware is aware it's retracted.
Then try again.
;M557 X15:265 Y15:135 S20 ; define mesh grid
Yes you should uncomment that line out. It tells the firmware where to probe when doing a G29.
Then try again.
Do you mean M402?
