    I can't print object sliced with Prusa Slicer...
    764
    • A Former User?
      A Former User
      Good afternoon, as told in the subject I can't print objects sliced with Prusa Slicer....If I slise with IdeaMaker it work all well bu with PS the extruder doesn't extrude materials almost at all...What am I doing wrong?
      Thanks
      Andrea
      • Torroundefined
        Torro
        Any error messages?
        My Problem was a missing "t0" in the Start Code
        • A Former User?
          A Former User
          No, no error messages simply the extruder moves soooooooooooooooooooooooooo slowly that the filament doesn't come out.....
          • botundefined
            bot
            PrusaSlicer has an autospeed feature. Are you using it? Perhaps you don't have it configured correctly.
            *not actually a robot
              Post some gcode examples otherwise we have no idea what's going on.
              • A Former User?
                A Former User
                It can't print every GCODE, it looks like the Extruder stepper spins with a low low low step/mm number....this is just a little example because only small files can be attached here....linked there are the extruder settings as well example.gcode
                matt3oundefined 1 Reply Last reply Reply Quote 0
                • matt3oundefined
                  matt3o @A Former User
                  @the_dragonlord have you tried disabling pressure advance?
                    @the_dragonlord, are you sure you have configured PrusaSlicer for the correct filament diameter, i.e. 1.75mm (assuming that is what you are using) and not 2.85mm?
                    • matt3oundefined
                      matt3o
                      also if you are using prusa's presets be sure to remove any printer specific config in the filament gcode
                      • A Former User?
                        A Former User @matt3o
                        @matt3o yes
                        • A Former User?
                          A Former User @dc42
                          @dc42 said in I can't print object sliced with Prusa Slicer...:
                          yes, it is 1,75
                          • A Former User?
                            @matt3o said in I can't print object sliced with Prusa Slicer...:
                            No specific config are present
                            matt3oundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
                            • matt3oundefined
                              @the_dragonlord I use absolute extrusion with Prusa, if that makes any difference
                              • A Former User?
                                I've tried both but none of them works.....
                                • engikeneerundefined
                                  engikeneer @A Former User
                                  @the_dragonlord have you set a max volumetric flow rate (in printer or filament settings)?
                                  What is your first layer speed set to?
                                  i3 clone with a bunch of mods
