    Duet 3 Mini 5+ unable to connect via browser
    Firmware installation
    10
    27
    1.7k
    • pkosundefined
      pkos
      Not to necro the thread too much, but is there anything a person with a hot air soldering station can do?
      It seems like the stock for those minis won't be available again for another month or so.
      Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
      dc42undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @pkos
        @pkos said in Duet 3 Mini 5+ unable to connect via browser:
        Our assemblers are currently building and testing a large batch of Duet 3 Minis. Deliveries to our resellers should be in full flow next week. They have been using our second-generation CAN-based Automatic Test equipment since the start of this week to speed up testing. This is the prototype:
        The lid on the top right holds the Duet 3 Mini under test down to make contact with the pogo pins. The power resistors at the top provide loads for the heater/fan outputs, and the bank of inductors on the left simulate stepper motors without producing noise. The Duet 3 Mini at front centre runs the tests. At the back (not visible) are CAN-connected boards that measure motor currents and I/O voltages. Ignore the MB6HC board at the front, I was using it to adapt the ATE firmware to test MB6HC boards too.
          Yes, all it needs is a no-clean flux pen and hot air equipment. If you were in the UK, I would have volunteered to repair your board already. I have repaired about ten pre-production boards in this way.
          • pkosundefined
            pkos
            Well, if it's next week, I'll wait patiently 😉 Don't want to mess the board up even more before I have the replacement. I mean it does turn on once every 10 times or so and even allows me to print something as long as I have cooling fans cooling the board.
            EDIT: Sweet rig by the way.
            • lodgerundefined
              lodger
              Would this problem still be a issue if your running the board off a SBC. Was just thinking folks waiting for replacement stock may be able to run off a Pi ??
              Just a idea !
              pkosundefined 1 Reply Last reply Reply Quote 0
              • pkosundefined
                pkos @lodger
                @lodger That would work 🙂
                I never think about adding an SBC to the Duet, since the main reason I use a duet is the standalone mode. I like the simplicity of it so much, it would feel weird to tarnish the Duet with a pi 😉
                But yes, if I won't hear from E3D anytime soon, I will either ask what should be resoldered exactly (I have all I need I believe) or add an SBC.
                For now, I keep playing with the board when it actually boots up to test 3.3b1 - and I am seeing some issues there (like the 12864 screen doesn't work with 3.2.2 config anymore with an error saying X2 is too low a value).
                • oc_geekundefined
                  oc_geek @Phaedrux
                  @Phaedrux It happened again -> opened a thread on it
                  https://forum.duet3d.com/topic/22116/duet-mini-5-non-responsive-and-files-missing
                  • incurioundefined incurio referenced this topic
