    Problem with rear side of Test Cube
    2.0k
    • dmbgoundefined
      dmbgo
      The probing issue that I recently posted about was my penultimate issue, this is my ultimate one 🙂 .
      When I print a Test Cube, the lower half of the cube is distorted, curved and in places missing altogether. The upper part is much better.
      I have tried the following solutions, but none of them seem to really address the problem:
      1/ Lowered extrusion amounts from 100% down to 50% in 10% increments, (best results seemed to be at 100% extrusion).
      2/ Altered printing speed, I have tried 60mm/s, 30mm/s and 15mm/s, (I definiftely noticed an improvement when I changed from 60mm/s to 30mm/s, but not much change going to lower speeds).
      It may be an issue with the slicer settings, I am using Simplify3d ver 4.1.2.
      Here are some photos of the issue:
      20210117_085437.jpg 20210117_085657.jpg 20210117_085621.jpg 20210117_085528.jpg
      Regards David Maher
      • alankilianundefined
        alankilian
        Wow, that really IS terrible.
        Can you save your factory file and post it here so I can load it and take a look?
        What filament are you using and what temperature are you setting the bed and extruder to?
        • dmbgoundefined
          dmbgo
          Thank you for agreeing with me about the quality @alankilian 🙂
          Here is the *.gcode file xyzCalibration_cube-brim-100%-opt-start.gcode
          Regards David Maher
          alankilianundefined 1 Reply Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt
            I don't think you can attribute that to the slicer settings.
            I think you have extruder hardware problems.
            Have you calibrated the extruder multiple times to see if it remains consistent.
            Have you watched the extruder temperature readout during printing to see if it is remain consistent.
            Printers: A FT-5 with the 713 upgrade bits, a custom MarkForged style, a small Utilmaker style, a small CoreXY from kit and a E3D MS/TC setup. Various hotends. Using Duets (2 and 3) running 3.4.6
            • dmbgoundefined
              dmbgo
              The extruder temp is 235C and I have experimented with bed temps from 80C to 120C. I didn't really notice much change, except that with a bed of 80C, adhesion was deteriorating.
              Regards David Maher
              • dmbgoundefined
                dmbgo
                I haven't recalibrated the extruder, but I think my temperature is consistent. The window in the browser that shows the temp is consistent. I'm just running the cube now, so that I can post the temp readouts.
                Regards David Maher
                • fcwiltundefined
                  fcwilt @dmbgo
                  @dmbgo said in Problem with rear side of Test Cube:
                  I didn't see that you mentioned the kind of filament you are using.
                  For PLA I use 200 for the extruder and 60 for the bed but keep in mind my 200/60 may not match you 200/60 - it all depends on the thermistors and how correct the thermistor configuration values are.
                  For speed I use 60 mm/s to 90 mm/s depending on desired quality with the first layer at 15 mm/s.
                    alankilian @dmbgo
                    @dmbgo Can you File->Save Factory File as... and post it?
                    That way I can see your slicer settings and all that.
                    • dmbgoundefined
                      dmbgo
                      Thanks Fredrick, I am using ABS.
                      Regards David Maher
                      • dmbgoundefined
                        dmbgo
                        No worries @alankilian here it is:
                        [0_1610836772941_xyzCalibration_cube.factory](Uploading 100%)
                        Regards David Maher
                          alankilian @dmbgo
                          @dmbgo Try that upload again please.
                          Also, what filament are you using?
                            alankilian
                            I print PLA at 60C bed and 205C extruder, so you're significantly hotter than I am.
                            • dmbgoundefined
                              dmbgo
                              I'll try renaming it to *.txt, you'll have to change it to *.factory:
                              xyzCalibration_cube.factory.txt
                              Regards David Maher
                              • dmbgoundefined
                                dmbgo
                                I am using ABS filament.
                                Regards David Maher
                                • dmbgoundefined
                                  dmbgo
                                  On the filament roll, it recommends Extruder 220 to 260C Bed 100 to 110C
                                  Regards David Maher
                                  • dmbgoundefined
                                    dmbgo
                                    Regards David Maher
                                    • fcwiltundefined
                                      fcwilt @dmbgo
                                      Do you have a heated enclosure?
                                        alankilian
                                        I'm afraid I'm out of my experience zone with ABS.
                                        I have read not to use fans for the first 3 layers, but that's not your problem.
                                        Do you see filament extruding on the back cornets?
                                        Do you hear your extruder struggling/clicking when that happens?
                                        Can you rotate the cube 180-degrees to see if it then happens on the front?
                                        Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
                                        Do you have an enclosure?
                                        My only ABS experience is using a Stratasys where everything is controlled for me and it works perfectly.
                                        Someone with more ABS experience will probably jump in next and hopefully be able to help you more than I can.
                                        • dmbgoundefined
                                          dmbgo
                                          I do have, but the printer isn't in it at present while I'm working on it. I usually drop the bed temp down when the printer's in there.
                                          Regards David Maher
                                          • fcwiltundefined
                                            fcwilt
                                            From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem.
