New to the duet COMPLETE NEWBIE
5.6k
  • undefined
    gabrealek
    Ive been trying to update the config for my duet via RRF config and I am just having the harderst two days of my life. I know some people this may be very simple and are able to grasp this quickly but im just constantly FAILING and im getting frustrated at this point, i dont understand anything and the more that i study the more i find myself getting things wrong, could someone please help me with this config. . i have no more tools to display after this config. i dont know what more to do rather than take a hammer and trash this whole printer. im So frustated, ive cried for the third time today. everyone i ask for help on other sites are quite mean and very passive when asking for information. i am a visual learner and I am trying to balance fixing this with dealing with my two children under 7.. please help
    at this point i dont know what anything is anymore, i GIVE UP as of NOW, until i get help that is.
    ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 18 2021 16:53:55 GMT-0500 (Eastern Standard Time)
    M550 P"Creola" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z400 S0 ; set axis maxima
    M574 X1 Y1 S1 ; set active high endstops
    M574 Z1 S2 ; set endstops controlled by probe
    M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M305 P0 T1 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M143 H0 S90 ; set temperature limit for heater 0 to 90C
    M305 P1 T1 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"Extruder" D0 H1 F0 ; define tool 0
    M563 P1 S"Bed" F-1 ; define tool 1
    G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
    G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
    undefined 1 Reply Last reply 18 Jan 2021, 22:41 Reply Quote 0
    • undefined
      jay_s_uk
      If you're setting up a new 3D printer and you're just getting into RRF, I definitely advise upgrading to RRF3.2
      If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each.
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
      That will get your firmware and DWC up to date.
      https://configtool.reprapfirmware.org/Start
      For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
      undefined 1 Reply Last reply 18 Jan 2021, 22:29 Reply Quote 0
      • undefined
        gabrealek @jay_s_uk
        @jay_s_uk thank you, Im about to now.
        • undefined
          jay_s_uk
          once you've regenerated your firmware, repost your config and we can help you out.
          Also, if its an off the shelf printer, tell it what it is so we can have a bit more info.
          If you had it running under marlin, make sure you have your previous config available so we can ask questions
          undefined 2 Replies Last reply 18 Jan 2021, 22:37 Reply Quote 0
          • undefined
            gabrealek @jay_s_uk
            @jay_s_uk I went into cura and found this config for my printer, idk if this is the old config for it. I have a CR-10 . .
            M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
            M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
            M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
            M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
            M220 S100 ;Reset Feedrate
            M221 S100 ;Reset Flowrate
            G28 ;Home
            G92 E0 ;Reset Extruder
            G1 Z2.0 F3000 ;Move Z Axis up
            G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
            G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
            G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
            G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
            END GCODE
            G91 ;Relative positioning
            G1 E-2 F2700 ;Retract a bit
            G1 E-2 Z0.2 F2400 ;Retract and raise Z
            G1 X5 Y5 F3000 ;Wipe out
            G1 Z10 ;Raise Z more
            G90 ;Absolute positionning
            G1 X0 Y{machine_depth} ;Present print
            M106 S0 ;Turn-off fan
            M104 S0 ;Turn-off hotend
            M140 S0 ;Turn-off bed
            M84 X Y E ;Disable all steppers but Z
            Idk if this is exactly what you need, i still dont know how to find my old config . .
            undefined undefined 2 Replies Last reply 18 Jan 2021, 22:38 Reply Quote 0
            • undefined
              gabrealek @gabrealek
              @gabrealek this is from when i printer from the stock CR-10 motherboard V1.1.4
              • undefined
                Phaedrux Moderator @gabrealek
                @gabrealek said in New to the duet COMPLETE NEWBIE:
                Remove that from the cura start gcode for starters.
                • undefined
                  Don't despair. You've come to the right place. We can't help you with your children, but I'm quite confident we can get your printer sorted. Then maybe print them some toys.
                  • undefined
                    What state are you currently at? I mean with the printer, not mentally.
                    Is it all wired up? Do you have the Duet Web Control interface up?
                    Assuming you do, please send M122 in the console tab and post the results. Assuming the firmware updates worked you should be running 3.2
                    The format of your config.g is for RRF2 though, so you'll need to generate a fresh config file set using the online tool.
                    Enter the information as best you can and then download the resulting zip file and upload that to the system tab in DWC.
                    Then post your config.g, homeall, homex, homey, homez here.
                    undefined 1 Reply Last reply 18 Jan 2021, 22:49 Reply Quote 0
                    • undefined
                      gabrealek @Phaedrux
                      @Phaedrux Okay, So im wired up and in the DWC interface. I just updated
                      "FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-01-05"
                      Im in the RRF config now. . You guys have already made me feel so much better and secure. . i was loosing my marbles!! 😞
                      • undefined
                        gabrealek @jay_s_uk
                        @jay_s_uk @Phaedrux
                        Okay so for everything i was unsure about, I left it at default.
                        Here is the config i just finished
                        ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 18 2021 18:02:52 GMT-0500 (Eastern Standard Time)
                        M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                        M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp
                        M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
                        M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                        M143 H0 S245 ; set temperature limit for heater 0 to 245C
                        M308 S1 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin bedtemp
                        M950 H1 C"bedheat" T1 ; create bed heater output on bedheat and map it to sensor 1
                        M307 H1 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
                        M140 H1 ; map heated bed to heater 1
                        M143 H1 S80 ; set temperature limit for heater 1 to 80C
                        M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
                        M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                        M563 P0 S"Extruder" D0 H1 F0:1 ; define tool 0
                        M563 P1 S"Bed" F0 ; define tool 1
                        My printer model is a stock CR-10. no modifications. .
                        • undefined
                          Maybe take a look at this guide series that goes through the whole process. Might give you some ideas. It's for an ender 3 and RRF2, which is pretty similar to the CR-10 actually. All Creality printers are similar.
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
                          The RRF3 version is started here, but still working on it.
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87
                          • undefined
                            gabrealek
                            ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:22:13 GMT-0500 (Eastern Standard Time)
                            M569 P0 S0 ; physical drive 0 goes backwards
                            M569 P3 S0 ; physical drive 3 goes backwards
                            M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
                            M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
                            M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
                            M557 X10:220 Y10:220 S20 ; define mesh grid
                            M308 S0 P"e0temp" Y"thermistor" T9880 B4185 ; configure sensor 0 as thermistor on pin e0temp
                            M143 H0 S250 ; set temperature limit for heater 0 to 250C
                            M308 S1 P"bedtemp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin bedtemp
                            M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                            M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
                            M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
                            M563 P0 S"Extruder" D0 F0:1 ; define tool 0
                            M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                            ; homeall.g
                            ; called to home all axes
                            ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:30:54 GMT-0500 (Eastern Standard Time)
                            G91 ; relative positioning
                            G1 H2 Z18 F480000 ; lift Z relative to current position
                            G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                            G1 H2 X5 Y5 F480000 ; go back a few mm
                            G1 H1 X-305 Y-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
                            G1 H1 Z-405 F3600 ; move Z down stopping at the endstop
                            G90 ; absolute positioning
                            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                            ;G91 ; relative positioning
                            ;G1 Z18 F8000 ; lift Z relative to current position
                            ;G90 ; absolute positioning
                            ; homex.g
                            ; called to home the X axis
                            ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:31:40 GMT-0500 (Eastern Standard Time)
                            G1 H1 X-305 F3000 ; move quickly to X axis endstop and stop there (first pass)
                            G1 H2 X5 F480000 ; go back a few mm
                            G1 H1 X-305 F3600 ; move slowly to X axis endstop once more (second pass)
                            G1 H2 Z-18 F480000 ; lower Z again
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:31:58 GMT-0500 (Eastern Standard Time)
                            G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered
                            Ive checked my wiring and it all seems correct.
                            @Phaedrux
                            undefined 1 Reply Last reply 19 Jan 2021, 20:36 Reply Quote 0
                            • undefined
                              It would be more traditional for heater0 to be the bed heater and for heater1 to be the first tool heater. I don't think that's strictly enforced now with RRF3 being more flexible about it, but still not a bad idea to conform to the standard.
                              Also, your tool definition is lacking a heater.
                              Maybe take another crack at the config tool. https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
                              undefined 1 Reply Last reply 19 Jan 2021, 20:41 Reply Quote 0
                              • undefined
                                gabrealek @Phaedrux
                                @Phaedrux Okay, back into the studio I go. Thank you for helping me!!!!
                                • undefined
                                  Double check your heater and thermistor connections as well. Hopefully that will resolve the odd heater reporting in DWC.
                                  Otherwise the config looks ok so far.
                                  After the heaters are sorted you'd want to carefully check the motor directions are correct and endstops are working and then test homing. And then test and tune the heaters and calibrate the extruder.
                                  follow along
                                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                                  undefined 1 Reply Last reply 19 Jan 2021, 23:39 Reply Quote 0
                                  • undefined
                                    gabrealek @Phaedrux
                                    @Phaedrux thanks. Ive checked the connections and redid them as the ender tutorial and now i am having a fault in the hotend and also the bed when i try to heat it as well.
                                    Here is my new config . . ive been trying to get it right all day. ive done it exactly as the tutorial as well.
                                    ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)
                                    M950 H0 C"e0heat" T0 ; create bed heater output on e0heat and map it to sensor 0
                                    M308 S1 P"e1temp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin e1temp
                                    M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
                                    M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                                    M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on
                                    M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
                                    T0 ; select first tool
                                    undefined 1 Reply Last reply 20 Jan 2021, 00:10 Reply Quote 0
                                    • undefined
                                      T9880
                                      I think you're missing a digit in your T values.
                                      undefined 1 Reply Last reply 20 Jan 2021, 01:33 Reply Quote 0
                                      • undefined
                                        gabrealek @Phaedrux
                                        @Phaedrux I dont understand how i would correct that. . its in there twice. . Ive tried to look up what a T9880 is . . i cant find anything .. Is it a problem with the setting i put in the config?
                                        • undefined
                                          The correct values are T98801
                                          undefined 1 Reply Last reply 20 Jan 2021, 13:15 Reply Quote 0
                                          6 out of 101
