    Question about bed probing
    636
    • User3Dundefined
      User3D
      Does OM store height error reported at each point after bed probing?
      • fcwiltundefined
        fcwilt
        I don't see anything like that.
          You mean like the heightmap.csv?
          User3Dundefined 1 Reply Last reply Reply Quote 0
          • User3Dundefined
            User3D @Phaedrux
            @Phaedrux Like height errors resulted at each point in array in Object model. I know result is store in heightmap , but I want to compare them once the whole process is completed.
            • fcwiltundefined
              fcwilt @User3D
              @User3D said in Question about bed probing:
              Compare them to what?
              • User3Dundefined
                User3D @fcwilt
                @fcwilt compare them with each other. 😅
                • fcwiltundefined
                  fcwilt @User3D
                  You mean two different height maps?
                  You can create a heightmap and save it using a unique name with G29 S3 P"filename".
                  The you can download the saved files and compare them.
                  While I don't compare them I use the feature to save/load low, medium and high point count height maps.
                  • User3Dundefined
                    User3D @fcwilt
                    @fcwilt said in Question about bed probing:
                    No
                    I still don't know if my bed is stable. So I want this feature where it will show me error dialogue telling me 'You need to level your bed' when bed is extremely titled. So basically I want to compare height errors with each other.
                    fcwiltundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @User3D
                      But to determine if the bed needed leveling it would perform all of the probing needed to level the bed - so why not just continue the process and level it?
                      How are you leveling you bed?
                      Thanks.
                      • DIY-O-Sphereundefined
                        DIY-O-Sphere @User3D
                        So the first thing to improve is the stabilty of the bed.
                        Otherwise you will compare one error to an other...
                        Or you have to mesh level before every print...
                        Had the same issue with my Hevo.
                        After modifying the bed frame, the thing is rock solid.
                        I mesh level the bed only for sanity 3-4 times a year..
                        (UTC+1)
                        oziundefined 1 Reply Last reply Reply Quote 0
                        • oziundefined
                          ozi @DIY-O-Sphere
                          @DIY-O-Sphere How you modified your HEVO Bed? 🙂
                          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                            DIY-O-Sphere @ozi
                            @ozi
                            Edit:
                            (UTC+1)
                            • User3Dundefined
                              User3D
                              wanted to make it less human dependent .
                              No biggie... I'll go with current method .
                              Thanks for the help 🙂
                              fcwiltundefined 1 Reply Last reply Reply Quote 1
                              • fcwiltundefined
                                fcwilt @User3D
                                I just run bed leveling twice at the start of a print. It only probes the bed at three points each time so it's not like it take a long time.
                                Can you clarify what you mean by "human dependent"?
                                Thanks.
                                • User3Dundefined
                                  User3D @fcwilt
                                  @fcwilt
                                  If error difference is greater than a value then I want it to tell me. So then I will level my bed manually. 😬
                                  • fcwiltundefined
                                    fcwilt @User3D
                                    @fcwilt
                                    Perhaps you and I are talking about different types of bed leveling?
                                    What do you do to manually level your bed?
                                    Thanks.
                                    • User3Dundefined
                                      User3D @fcwilt
                                      @fcwilt paper technique I am talking about here .
                                      • fcwiltundefined
                                        fcwilt @User3D
                                        So you don't have a Z probe?
                                        • User3Dundefined
                                          User3D @fcwilt
                                          @fcwilt I have
                                          • fcwiltundefined
                                            fcwilt @User3D
                                            @fcwilt I have
                                            If you have a z probe why would you be using paper to level the bed?
