    Is this a genuine Duet 2 Wifi?
    408
    • Blacksheep99undefined
      Blacksheep99
      I bought this 2nd hand from ebay. I believe it to be genuine but having been told the PanelDue that came with it to be a clone I want to be sure. Thanks.
      • Vetiundefined
        Veti
        post a picture of the back. but it looks good.
        Blacksheep99undefined 1 Reply Last reply Reply Quote 0
          Blacksheep99 @Veti
          @Veti added to first post. Thanks
          • Vetiundefined
            Veti
            that looks like a genuine board.
            clones are not allowed to use the logos on the back.
              Blacksheep99 @Veti
              @Veti Good to know. Having got to grips with the Maestro I plan to upgrade my other printer with this. Is it possible to buy the connectors etc separately? Assume they're a standard?
              • Vetiundefined
                Veti
                https://www.filastruder.com/products/duet-connector-kit-1
                  Blacksheep99
                  Thanks. Any UK suppliers?
                  • Vetiundefined
                    Veti
                    https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers
                    there are the parts
                    and you can get the connectors here
                    https://www.digikey.co.uk/products/en?keywords=22-01-3027
                    • alankilianundefined
                      alankilian
                      Just one unrelated comment: I get worried when there's a metal bolt running through a PCB with a metal nut on the other side.
                      That is an invitation to short from the front layer to the back over time as they wear through the solder mask. Sometimes that's no big deal, and sometimes it's an invitation to cause real problems.
                      Nylon washers can help, but I personally prefer using full nylon bolts and nuts for mounting.
                      Just something to think about.
                      Blacksheep99undefined 1 Reply Last reply Reply Quote 1
                        Blacksheep99 @alankilian
                        @alankilian I noted the lack of nylon washers but I appreciate your comment. I'll definitely have it in mind.
