    massive overextrusion, E-Steps are calibrated
    82
    6.4k
    • Enpixaundefined
      Enpixa
      Hello all,
      After several days of suffering i am writing here. I read in several threads about it. Maybe there is meanwhile a solution or someone knows what i am doing wrong.
      I converted my Wanhao 6plus to a Duet Wifi 1.04 Setup on RRF3.
      Everything works fine ( All axis are moving smoothly (after completely disassembling and reassembling), Height-Sensor is working properly, Fans are working nicely, heaters are PID tuned etc. )
      I use a nice flexible metalsheet-bed, included a bondtech extruder, switched to microswiss all-metal hotend. so, everything should be some kind of top-notch at least ok.
      E-steps are calibrated. When i do a G92 E0 and G1 E100 F60 it moves the filament 100mm without any problems, to double check i did the same with the WebInterface. Same result. Filament moves 10cm. Perfect so far.
      But now when starting to print, there is a massive overextrusion.
      I have to pull down the flow rate to about 50-60% to get a result which looks like a proper first layer.
      Also checked in the slicers that nozzle is set to 0.4 and filament to 1.75.
      I tried different slicers ( Cura, Superslicer, Simplify3D ), all the same result - massive overextrusion . In each slicer i tried it with relative and absolute retraction.
      (accordingly used M82 or M83 in config-file ) Also tried using the M82/M83 in slicers starting script.
      There is no M572 in my config or starting scripts.
      Also tried to use different Firmware Flavors ( Reprap and Marlin)
      Didnt help. Also tried M555 P2 in config , as i read somewhere he had luck with Marlin-Interpretation.
      Is there maybe a solution ? Here is my configfile. Maybe i miss something. Asmentioned before i tried M82 or M83 on config and set relative or absolute retraction in slicer accordingly.
      G90                                            ; send absolute coordinates...
      M82											; ...absoulte extruder moves
      M550 P"Wanhao Duplicator 6 Plus"               ; set printer name
      M551 P"notvisible"                               ; set password
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S0                                     ; physical drive 0 = X goes reverse
      M569 P1 S1                                     ; physical drive 1 = Y goes forward
      M569 P2 S0                                     ; physical drive 2 = Z goes reverse
      M569 P3 S0                                     ; physical drive 3 = E0 goes reverse
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M92 X80.04 Y80.04 Z800.96 E415.80              ; set steps per mm  //  von Phil: M92 X80.04 Y80.04 Z800.96 E433.80
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping without interpolation
      M566 X600.00 Y600.00 Z24.00 E20.00            ; set jerk/maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z120.00 E3000.00      ; set maximum speeds (mm/min)
      M201 X600.00 Y600.00 Z200.00 E2000.00       ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1200 E1200 I50               ; set motor currents (mA) and motor idle factor in per cent
      M84 S10                                        ; Set idle timeout
      ;M593 F32.50                                   ; enable Dynamic Acceleration Adjustment with its frequency
                                                     ; to make this work, you also have to set a high acc value (like M201 X10000.00 Y10000.00) and jerk value (like M566 ;X1800.00 Y1800.00
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X190 Y180 Z170 S0                         ; set axis maxima
      M574 X1 S1 P"!^xstop"                          ; configure active-low endstop for low end on X via pin !^xstop
      M574 Y1 S1 P"!^ystop"                          ; configure active-low endstop for low end on Y via pin !^ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M558 P5 C"^!zprobe.in" H2 F60 T6000 A1         ; set Z probe type to switch and the dive height + speeds
      G31 P1000 X-2 Y50 Z2.3                    ; Z-WERT GRÖSSER=Näher am bett; set Z probe trigger value, offset and trigger height
      M557 X0:190 Y50:200 S60:50                     ; define mesh grid
      M376 H1                                        ; Set compensation taper to 5mm
      ; Heated Bed
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 A52.2 C59.4 D1.1 V23.9 B0 S1.00        ; disable bang-bang mode (turn on PID mode) for bed heater, set PWM limit and the PID settings
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      ; Hotend
      M308 S1 P"spi.cs1" Y"rtd-max31865"             ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      ;M307 H1 A398.4 C224.6 D7.5 V24.0 B0 S1.00      ; disable bang-bang mode (turn on PID mode) for nozzle heater, set PWM limit and the PID settings
      ;M307 H1 A261.2 C161.4 D4.3 S1.00 V24.1 B0
      ;M307 H0 A52.2 C59.4 D1.1 S1.00 V23.9 B0
      M307 H1 A448.4 C273.6 D9.6 S1.00 V24.0 B0
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      ; LED
      M950 F2 C"fan2" Q500                           ; create LED on pin fan2 so that the brightness can be controlled via the dashboard and set its frequency
      M106 P2 S255 H-1                               ; turn LED on (Thermostatic control is turned off)
      M563 P0 S"Hotend" D0 H1 F0                     ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      Thank you for your help,
      Johannes
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        from https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Wanhao/Duplicator 6/Configuration.h
        #define DEFAULT_AXIS_STEPS_PER_UNIT { 80.0395, 80.0395, 400.48, 99.1 }
        is your z step correct? it differs from the default marlin config
        • deckingmanundefined
          deckingman @Veti
          @Veti He said he was using a Bondtech extruder - quote...
          415 steps per mm is about right for a BMG
          Vetiundefined 1 Reply Last reply Reply Quote 1
          • Vetiundefined
            Veti @deckingman
            @deckingman
            z steps not e steps
            • Enpixaundefined
              Enpixa
              Yes, looks right. G92 Z0 and then G1 Z100 is moving 100mm on Z-Axis. Just double-checked.
              • Vetiundefined
                Veti
                how sure are you that you have a 0.4mm nozzle?
                • Enpixaundefined
                  Enpixa
                  I replaced my old nozzle 2 days ago (Where i also had the same problems ) with a completely new 0.4 Microswiss nozzle. Which should be ok.
                  • Vetiundefined
                    Veti
                    measure the weight of 100mm filament
                    then extrude 100mm filament through the hotend and weight that.
                    if its the same, the problem must be in the slicer.
                    • Enpixaundefined
                      Enpixa
                      Veti, thx for the hint! Dont have that precise scales here atm. Will do it these days. But...my guess is, that there are some Issues with my config / Firmware. I have 3 different printers (not running with duet Wifi) where i dont have these issues. As mentioned i tried 3 different slicers (Cura, superslicer, simplify3d). The phenomen with the overextrusion is there, regardless which slicer i am using. Which makes me wonder that it is not only a few percentage... its like 50%
                      Also using Highquality filaments ( Filamentum, Extrudr, etc) so there shouldnt be that variance.
                      • Enpixaundefined
                        Enpixa
                        @deckingman thx for taking part in the discussion. I saw an old thread from you where there was quite a similar problem which suddenly disappeared. I love your great multicolor Printer !
                          deckingman @Enpixa
                          @Enpixa said in massive overextrusion, E-Steps are calibrated:
                          Thanks. But due to various firmware issues, it's currently just a useless pile of extrusion and motors.
                            Can you post your config.g?
                            Can you post your homeall.g?
                            Can you post the entire gcode file or at least the first 50 or so lines of it?
                            Can you send M122 and post the results?
                            Can you send M98 P"config.g" and post the results?
                            Is this just the first layer that is over extruded or are you letting the print progress to higher layers to allow for any incorrect Z0 position to be overcome?
                            Might be worth going through this complete calibration? https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                            • OwenDundefined
                              OwenD
                              Is your slicer set for volumetric extrusion?
                              Enpixaundefined 1 Reply Last reply Reply Quote 0
                              • Enpixaundefined
                                Enpixa
                                @Phaedrux : thx for your reply, here it comes
                                config.g:
                                ;M555 P2    ; emulate Marlin
                                M551 P"*hidden*"                               ; set password
                                ; Heated Bed
                                ; Hotend
                                ; LED
                                M575 P1 S1 B57600                              ; enable support for PanelDue
                                T0                                             ; select first tool
                                M501
                                config-overwrite.g:
                                ; config-override.g file generated in response to M500 at 2021-01-22 02:51
                                ; Heater model parameters
                                ; Workplace coordinates
                                G10 L2 P1 X0.00 Y0.00 Z0.00
                                G10 L2 P2 X0.00 Y0.00 Z0.00
                                G10 L2 P3 X0.00 Y0.00 Z0.00
                                G10 L2 P4 X0.00 Y0.00 Z0.00
                                G10 L2 P5 X0.00 Y0.00 Z0.00
                                G10 L2 P6 X0.00 Y0.00 Z0.00
                                G10 L2 P7 X0.00 Y0.00 Z0.00
                                G10 L2 P8 X0.00 Y0.00 Z0.00
                                G10 L2 P9 X0.00 Y0.00 Z0.00
                                1st Lines of Gcode of the File:, atm in Cura set to Marlin-Style, but same issue with Reprap-Style.
                                ;FLAVOR:Marlin
                                ;TIME:22400
                                ;Filament used: 14.1189m
                                ;Layer height: 0.1
                                ;MINX:25.453
                                ;MINY:6.229
                                ;MINZ:0.3
                                ;MAXX:112.584
                                ;MAXY:176.376
                                ;MAXZ:7
                                ;Generated with Cura_SteamEngine 4.8.0
                                M140 S60
                                M105
                                M190 S60
                                M104 S205
                                M105
                                M109 S205
                                M82 ;absolute extrusion mode
                                G21 ;metric values
                                G90 ;absolute positioning
                                M82 ;set extruder to absolute mode
                                M107 ;start with the fan off
                                G28 X0 Y0 ;move X/Y to min endstops
                                G28 Z0 ;move Z to min endstops
                                G29
                                G1 Z15.0 F100 ;move the platform down 15mm
                                G92 E0 ;zero the extruded length
                                G1 F200 E6 ;extrude 6 mm of feed stock
                                G92 E0 ;zero the extruded length again
                                G1 F100
                                ;Put printing message on LCD screen
                                M117 Printing...
                                G92 E0
                                G92 E0
                                G1 F1500 E-3
                                ;LAYER_COUNT:68
                                ;LAYER:0
                                M107
                                G0 F2400 X40.217 Y24.157 Z0.3
                                ;TYPE:SKIRT
                                G1 F1500 E1.24726
                                G1 F1800 X41.609 Y21.834 E1.38236
                                G1 X42.958 Y19.433 E1.51976
                                G1 X44.245 Y16.98 E1.65796
                                G1 X45.453 Y14.513 E1.79501
                                G1 X45.734 Y13.901 E1.8286
                                G1 X45.881 Y13.596 E1.8455
                                G1 X46.139 Y13.091 E1.87379
                                G1 X46.215 Y12.953 E1.88165
                                G1 X46.472 Y12.509 E1.90724
                                G1 X46.781 Y12.022 E1.93602
                                G1 X46.872 Y11.888 E1.9441
                                G1 X47.216 Y11.411 E1.97344
                                G1 X47.579 Y10.951 E2.00267
                                M98 :
                                24.1.2021, 14:00:54	M98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 473C
                                M122:
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                                Board ID: *hidden*
                                Used output buffers: 3 of 24 (12 max)
                                Static ram: 27980
                                Dynamic ram: 93888 of which 20 recycled
                                Exception stack ram used: 264
                                Never used ram: 8920
                                Tasks: NETWORK(blocked,368) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:02:47 ago, cause: power up
                                Last software reset at 2021-01-23 14:38, reason: User, spinning module GCodes, available RAM 8672 bytes (slot 2)
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                Error status: 0
                                MCU temperature: min 15.9, current 23.1, max 23.3
                                Supply voltage: min 23.8, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                Date/time: 2021-01-24 13:57:47
                                Cache data hit count 292974609
                                Slowest loop: 3.30ms; fastest: 0.12ms
                                === Storage ===
                                Free file entries: 10
                                SD card 0 detected, interface speed: 12.0MBytes/sec
                                SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                === MainDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                === AuxDDARing ===
                                Heater 1 is on, I-accum = 0.0
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 15.78ms; fastest: 0.00ms
                                Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                HTTP sessions: 1 of 8
                                - WiFi -
                                Network state is active
                                WiFi firmware version 1.23
                                WiFi MAC address 24:62:ab:15:71:3c
                                WiFi Vcc 3.37, reset reason Unknown
                                WiFi flash size 4194304, free heap 20968
                                WiFi IP address 192.168.0.133
                                WiFi signal strength -76dBm, reconnections 0, sleep mode modem
                                Socket states: 0 4 0 0 0 0 0 0
                                Sometimes i let it run higher, but only possible, when i set to 50-60% flow. otherwise there are huge blobs etc on first layer.
                                • Enpixaundefined
                                  Enpixa @OwenD
                                  @OwenD said in massive overextrusion, E-Steps are calibrated:
                                  No, not set to volumetric
                                  • Vetiundefined
                                    Veti @Enpixa
                                    which motor is on your bondtech?
                                    • Enpixaundefined
                                      Enpixa @Veti
                                      @Veti said in massive overextrusion, E-Steps are calibrated:
                                      Veti, it is the original Wanhao motor. But it is not getting hot when printing. it seems ok.
                                      • Enpixaundefined
                                        Enpixa
                                        Here are some Photos with 100% flow. Retraction: tried everything between 2-8mm, makes a difference, but doesnt avoid overextrusion.
                                        and some settings screenshot:
                                        as mentioned before the "Marlin-Style" Favor was only a test, made no difference compared to "reprap-style"
                                        • fcwiltundefined
                                          fcwilt
                                          Is the slicer set to use absolute or relative extrusion mode?
                                          Enpixaundefined 2 Replies Last reply Reply Quote 0
                                          • Enpixaundefined
                                            Enpixa @fcwilt
                                            This post is deleted!
