    can't go past 13mm/s
    120
    • aprz
      aprz last edited by aprz
      I'm trying to figure out why the max speed is 13mm/s and I have the speed in the slicer set to 25mm/s. I checked and made sure the extruder instantaneous speed isn't too low. what's limiting the speed. Using duet 3, cartesian printer, 0.9 motors, lead screws. I had the microsteps at 16x but tried 4x because I thought it might help with the speed.
      G90                                                     ; send absolute coordinates...
      M83                                                     ; ...but relative extruder moves
      M550 P"Duet 3"                                          ; set printer name
      M569 P0.1 S1                                             ; physical drive 0.1 goes forwards
      M569 P0.0 S0                                             ; physical drive 0.0 goes forwards
      M569 P0.2 S0                                             ; physical drive 0.2 goes forwards
      M569 P0.3 S0                                             ; physical drive 0.3 goes forwards
      M569 P0.4 S0                                             ; physical drive 0.3 goes forwards
      M569 P20.0 S1                                            ; physical drive 0.3 goes forwards
      M584 X0.1 Y0:4 Z2:3 E20.0                                ; set drive mapping
      M350 X4 Y4 Z4 E16 I1                                  ; configure microstepping with interpolation
      M92 X800.00 Y800.00 Z800.00 E873.00                   ; set steps per mm
      M566 X1000.00 Y1000.00 Z100.00 E5000.00                      ; set maximum instantaneous speed changes (mm/min)
      M203 X1650.00 Y1650.00 Z220.00 E7000.00                   ; set maximum speeds (mm/min)
      M201 X550.00 Y550.00 Z80.00 E6000.00                      ; set accelerations (mm/s^2)
      M906 X4100 Y4100 Z2800 E1300 I30                         ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                  ; Set idle timeout
      M208 X0 Y0 Z0 S1                                        ; s9t axis minima
      M208 X890 Y925 Z780 S0                                  ; set axis maxima
      M574 X1 S1 P"io0.in"                                   ; configure active-high endstop for low end on X via pin !io8.in
      M574 Y1 S1 P"io1.in"                                   ; configure active-high endstop for low end on Y via pin !io2.in
      M574 Z0 S1                                             ; configure Z-probe endstop for low end on Z
      M558 P8 C"20.io0.in" H5 F90 T100000                       ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z0.1                                    ; set Z probe trigger value, offset and trigger height
      M557 X0:885 Y0:985 S80                                 ; define mesh grid
      M308 S0 P"20.temp0" Y"pt1000"                               ; configure sensor 0 as thermistor on pin 20.temp0
      M950 H0 C"20.out0" T0                                       ; create nozzle heater output on 20.out0 and map it to sensor 0
      M307 H0 R1.555 C397.7 D6.96 S1.00 V24.1 B0               ; PID auto tune results
      ;M308 S1 P"temp0" Y"thermistor" T100000 B3950            ; configure sensor 1 as thermistor on pin temp0
      ;M950 H1 C"out0" T1                                      ; create bed heater output on out0 and map it to sensor 1
      ;M307 H1 B1 S1.00                                        ; enable bang-bang mode for the bed heater and set PWM limit
      ;M140 H1                                                 ; map heated bed to heater 1
      ;M143 H1 S280                                            ; set temperature limit for heater 1 to 280C
      M950 F0 C"out8" Q500                                    ; create fan 0 on pin out8 and set its frequency
      M106 P0 S0 H0 T45                                       ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out9" Q500                                    ; create fan 1 on pin out9 and set its frequency
      M106 P1 S0 H0 T45                                       ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"Titan Aqua 1.75" D0 H0 F0                     ; define tool 0
      G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
      G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
      M501
      o_lampe 1 Reply Last reply Reply Quote 0
        Do you happen to be using Cura? Check your start gcode for any speed limits being set.
        • CCS86
          CCS86 last edited by
          Also check the gcode your are printing with and make sure it is even trying to command a speed higher than 13 mm/s
          There are a number of things on the slicer side that can cap the max speed, like minimum layer time.
          • o_lampe
            o_lampe @aprz last edited by o_lampe
            @1997alex said in can't go past 13mm/s:
            There's a typo in the drive-mapping. Maybe not....? Sorry
            Phaedrux 1 Reply Last reply Reply Quote 1
              Phaedrux Moderator @o_lampe last edited by Phaedrux
              @o_lampe said in can't go past 13mm/s:
              On setups with expansion boards the leading digit refers to the board. So 0.1 would be driver 1 on board 0, ie, the mainboard. 1.2 would be driver 2 on the first expansion board.
              In setups with only a single board the leading 0 can be left off entirely as it's implied by the firmware.
              Though I'm not sure what happens when mixing and matching, so might be a good idea to try cleaning that up.
              • aprz
                I have two motors running on the z and y axis. I think your referring to the E20.0? The suggested can address for the tool board is to start at 20 and thats why im using E20.0. If i missed something you said or misinterpreted please let me know. I dont have an expansion board yet but will in the future.
                  E20.0 is fine if your tool board address is 20.
                  What I was referring to for maybe cleaning up is that you have no board address for Y and Z, but like I said, that shouldn't really matter.
                  aprz 1 Reply Last reply Reply Quote 0
                  • aprz
                    aprz last edited by
                    ok so the issue I found was that cura had a setting for initial layer speed at 12.5mm/s. After raising the speed to 25mm/s I was able to fix the problem. From what I have read is that slower speeds for the initial layer are best for adhesion. That makes sense but I now can print at 30mm/s and its still adheres to the bed. thanks for the help i assumed it had something to do with the acceleration and jerk but that was incorrect.
                    • aprz
                      aprz @Phaedrux last edited by
                      @Phaedrux ok should i change it to M584 X0.1 Y0.0:4 Z0.2:3 E20.0
                        More like
                        M584 X0.1 Y0.0:0.4 Z0.2:0.3 E20.0
                        • aprz
                          @Phaedrux awesome! figuring out the correct way to write the code is what i'm trying to learn. thanks.
