    duet3d sd not detected, rejects http, com5 denied
    2.6k
    • radcadundefined
      radcad
      I called the cable company and complained about my connection and they did some reset test that took several minutes, after that i was able to upload the 3rd file with no issue at all.
      so what do i do next
        Ok, so now you have reliable access to the web interface of the Duet?
        You're now on 3.2?
        You'll need a config file set to get going now.
        https://configtool.reprapfirmware.org/Start
        Try and fill out the pages to the best of your knowledge. Ask if you have any questions.
        At the end you'll be able to download a zip file with all of the config files. Do that and then upload that zip file to the system tab as well. After it reboots you can do some careful testing for motor movement, homing, heaters, fans, etc.
        radcadundefined 1 Reply Last reply Reply Quote 0
        • radcadundefined
          radcad
          yes 3.2 is installed
          • radcadundefined
            radcad @Phaedrux
            @Phaedrux I have a ender 3 pro but I put a dual z motor on it. is there anything special i need to set up on the config?
            I also have a upgraded heated-bed and use a 500c Nova hotend.
            it came with a daughter board RTD 100 but im not sure how to hook it up. or what options to select in the config.
              Dual Z motors can either be used with the existing dual connector on the board with no special config needed, or if you want to use two separate drivers for each Z motor for lead screw leveling you can do that too, but will need to be added manually. See here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
              @radcad said in duet3d sd not detected, rejects http, com5 denied:
              500c Nova hotend.
              I'm not sure what that is. Do you have any documentation for it? Or a link to it? Photo?
              • radcadundefined
                radcad @Phaedrux
                @Phaedrux
                This is the hotend 500 C capable and claims to be unclogging
                https://3dpassion.com/nova
                I currently have the second Z plugged into the second port. I don't need any special z movements.
                This is the daughter board for the hotend that is 500c
                https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
                  Then you don't need to do anything special for the Z axis. Just treat it as a single motor z axis.
                  For the PT100 you can choose the PT100 sensor in the config tool. (bottom of the sensor dropdown list)
                  • radcadundefined
                    radcad
                    the guy the makes the hot end said i need to but the safety shutoff for the hotend up 2 degrees how do i do that? I dont see a option for pt100.
                      Phaedrux Moderator @radcad
                      Where are you looking?
                      cd60763a-08c2-41ed-87f1-07a2567d299a-image.png Screen Shot 2021-01-31 at 10.16.12 PM.png
                      I'm not sure what you're saying.
                      • radcadundefined
                        radcad @Phaedrux
                        @Phaedrux oh ok, now im not sure which to pick.
                          Which port on the daughter board are you using? RTD1 or RTD2? Those coincide with SPI.CS1 and SPI.CS2 in the drop down.
                          • radcadundefined
                            radcad @Phaedrux
                            @Phaedrux
                            im not sure i havent wired it up yet
                              Well those are your two options. RTD1 would be the most logical.
                              https://duet3d.dozuki.com/Wiki/PT100_temperature_sensor_daughter_board
                              • radcadundefined
                                radcad @Phaedrux
                                  Look in the i/o mapping page.
                                  Did you select firmware version 3.0+ at the start? You are on 3.2 now right?
                                  • radcadundefined
                                    radcad
                                    it does not five me a option for that
                                      Phaedrux Moderator @Phaedrux
                                      @Phaedrux said in duet3d sd not detected, rejects http, com5 denied:
                                      • radcadundefined
                                        radcad @Phaedrux
                                        @Phaedrux I installed all the file you gave me. the config im still unsure on some options to choose.
                                        Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          @radcad Can you be more specific?
                                          • radcadundefined
                                            radcad @Phaedrux
                                            @Phaedrux
                                            If this is what you mean, then yes.
                                            sorry im a newb at all thius thank you for helping me out with this.
