    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.9k
      Ok, firmware version is good. Wifi server should be good. And it says it is in access point mode with the correct IP. You can connect to the wifi, but when trying to reach 192.168.1.1 in your browser you get an error message in your browser saying "enable to connect"?
      Have you tried these suggestions from earlier yet?
      @Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
      Try clearing your browser cache.
      And if that doesn't work, I would check the /www folder on the SD card and replace the files there with a fresh copy of DWC.
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
      What url are you trying to reach exactly?
      http://192.168.1.1/ ?
      Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
      • Hélder Rochaundefined
        Hélder Rocha
        M552 S2
        ok
        WiFi module is providing access point DuetCr10, IP address 192.168.1.1
        when this was working properly, i use to have this same message repeatedly. Now just shows one time!
          Hélder Rocha @Phaedrux
          @Phaedrux allready clean my cache and the problem remains. About the replacement of the 3.2, im going to do it now
            Phaedrux Moderator @Hélder Rocha
            @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
            Alright, replace the contents of /www with the contents of this zip file.
              @Phaedrux didnt change the problem. When this was working ok, usualy i had to eject M552 S2 twice. Pist an error appear, but at the second time, usualy the message shows pepeatedly. Now, whem i send the comand, goes strait to the message saying the module is providing access point!
                Hélder Rocha @Hélder Rocha
                could it be an error from firefox?
                  Well you are running newer firmware on both the duet and the wifi module, so the behaviour may be a bit different looking than you're used to.
                  Can you post a screen shot or photo of what the firefox error message is saying?
                  control-shift-K will open the dev console in firefox which may show any errors.
                    Hélder Rocha
                    cant uload the image!!!! gives me an error.... looks this day is a complete error. 😞
                      Hélder Rocha
                        Hélder Rocha
                        wait...to small
                          Hélder Rocha
                            Its trying to use HTTPS. Change the url to use only http
                              Hélder Rocha
                              the same appens on chrome!
                                Going to check how that is done...
                                  Just change the url.
                                  HTTP: instead of HTTPS:
                                    it changes again to HTTPS...i erase the "s" but doesnt work
                                      @Hélder-Rocha I don't know if that's a problem or just what it normally does when it can't reach the site.
                                      Are you able to connect the duet to your home wifi?
                                        Hélder Rocha
                                        even if i try the duettest.local... it changes to the https followed by the ip number
                                          no... i am trying by the access point given by the board
                                            Hélder Rocha
                                            the blue led on the board is lit... the duet is working fine... after dinner ill try a different computer
