Random underextrusion Problem
@Frederik said in Random underextrusion Problem:
but when no print is running the temp is stable
Yes, because when no print is running, the cables are stationary.
@Phaedrux definetly not the cables
i resetted the Toolboard with the 2 knobs and restarted the same file:
absolute stable, nothing touched on the cables
@Phaedrux but what i can tell about the under extrusion, it seems that the artefacts are gone
after this i will print the same Led_Bar.gcode from the last time,
where the Problem occured.But it seems that the Print Quality is restored
This is a Picture where the Problem is better visible. It was switching between under and over extrusion in always the same intervals
M122 at the end of the Print,
I have to print a bigger object to check if the Problem is gonem122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3beta (2021-01-21 11:34:37) Bootloader ID: SAMC21 bootloader version 2.2 (2021-01-16b1) Never used RAM 3692, free system stack 0 words Move 90 HEAT 91 CanAsync 66 CanRecv 74 CanClock 66 TMC 56 MAIN 205 AIN 62 Last reset 00:35:43 ago, cause: software Last software reset time unknown, reason: OutOfMemory, available RAM 15632, slot 1 Software reset code 0x01c0 ICSR 0x00000000 SP 0x20003578 Task MAIN Freestk 747 ok Stack: 20000d10 00011ceb 20000d10 0001df61 00000000 00004008 20000d10 0001ded5 20000d0c 00004000 a5a5a5a5 a5a5a5a5 00000000 0001dd9d 00004000 00018b21 a5a5a5a5 00018b3d a5a5a5a5 00011b39 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: position 450451, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 14, reads 831, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0 Moves scheduled 9915, completed 9915, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 3, peak Rx sync delay 183, resyncs 0, no step interrupt scheduled VIN: 23.5V MCU temperature: min 48.7C, current 69.2C, max 74.0C Ticks since heat task active 57, ADC conversions started 2139229, completed 2139228, timed out 0 Last sensors broadcast 0x00000002 found 1 64 ticks ago, loop time 0 CAN messages queued 52, send timeouts 0, received 23, lost 0, free buffers 36, min 36, error reg 0 dup 0, oos 0, bm 0, wbm 0 === Filament sensors === Interrupt 4 to 8us, poll 28 to 181us Driver 0: pos 5.54, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT Used output buffers: 1 of 40 (13 max) === RTOS === Static ram: 149784 Dynamic ram: 60768 of which 80 recycled Never used RAM 140040, free system stack 139 words Tasks: Linux(blocked,145) HEAT(blocked,299) CanReceiv(blocked,880) CanSender(blocked,346) CanClock(blocked,326) TMC(blocked,16) MAIN(running,922) IDLE(ready,20) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:35:46 ago, cause: power up Last software reset at 2021-01-31 18:05, reason: User, none spinning, available RAM 139964, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 47.4, current 50.1, max 50.5 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 111650, standstill, reads 1676, writes 23 timeouts 0, SG min/max 0/852 Driver 1: position -9570, standstill, reads 1676, writes 23 timeouts 0, SG min/max 0/1023 Driver 2: position 15080, standstill, reads 1677, writes 23 timeouts 0, SG min/max 0/868 Driver 3: position 0, standstill, reads 1677, writes 23 timeouts 0, SG min/max 0/862 Driver 4: position 0, standstill, reads 1677, writes 23 timeouts 0, SG min/max 0/877 Driver 5: position 0, standstill, reads 1686, writes 14 timeouts 0, SG min/max 0/0 Date/time: 2021-01-31 19:12:16 Slowest loop: 60.63ms; fastest: 0.03ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 640640ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [1, 0, 70], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "M190 S100" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0: no data received === CAN === Messages queued 18772, send timeouts 22, received 26574, lost 102, longest wait 6ms for reply type 6029, peak Tx sync delay 16884, free buffers 48 (min 45) === SBC interface === State: 4, failed transfers: 0 Last transfer: 2ms ago RX/TX seq numbers: 17148/17148 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2d584 Buffer RX/TX: 56/1312-0 === Duet Control Server === Duet Control Server v3.2.0 File: Buffered code: M104 S250 Buffered code: M109 S250 Buffered code: M82 ;absolute extrusion mode Buffered code: G1 Z15.0 F6000 ;Move the platform down 15mm Buffered code: G1 X50 Y380 F3000 Buffered code: G92 E0 Buffered code: G1 F200 E35 Buffered code: G92 E0 Buffered code: M83 ;relative extrusion mode Buffered code: G1 F2100 E-0.6 Buffered code: ;LAYER_COUNT:47 Buffered code: ;LAYER:0 Buffered code: M107 Buffered code: G0 F3600 X138.176 Y161.255 Z0.3 Buffered code: G1 F2100 E0.6 Buffered code: G1 F1500 X138.735 Y160.865 E0.03128 Buffered code: G1 X139.335 Y160.543 E0.03125 Buffered code: G1 X139.968 Y160.294 E0.03122 Buffered code: G1 X140.627 Y160.121 E0.03127 Buffered code: G1 X141.301 Y160.026 E0.03124 Buffered code: G1 X141.77 Y160.007 E0.02154 Buffered code: G1 X147.626 Y160.007 E0.26878 Buffered code: G1 X148.306 Y160.047 E0.03127 Buffered code: G1 X148.976 Y160.166 E0.03123 Buffered code: G1 X149.628 Y160.363 E0.03126 Buffered code: G1 X150.252 Y160.635 E0.03124 Buffered code: G1 X150.84 Y160.979 E0.03127 Buffered code: G1 X151.384 Y161.389 E0.03127 Buffered code: G1 X151.851 Y161.837 E0.0297 ==> 1228 bytes Code buffer space: 2784 Configured SPI speed: 8000000 Hz Full transfers per second: 25.02 Maximum length of RX/TX data transfers: 3092/1456 File /opt/dsf/sd/gcodes/4x_glass_Bed_holder.gcode is selected, processing
When you pid tuned the bed, did you put B0 in the result?
The new tuning hint leaves it off, so if you just copied that rather than using M500, it will default to bang bang.
Wouldn't have thought it'd affect that high up the print and you should see a cyclic temp variation, but worth checking. -
@OwenD Thanks for the tip. I checked it, in my config was the old version, but in config.override there was the new Version with B0 at the end.
But i have this Parameter normal in a additional Line
LikeM307 H2 B0 S1.00 ;PID Parameters Bed for 110°C M307 H0 R0.585 C805.600:805.600 D2.90 S1.00 V24.1
Regards
Frederik -
Yesterday i did some testprints with the extruder connected to the Toolboard, then to the Mainboard.
The first row of test was a disaster when connected to the Toolboard Driver.
Again Massive Underextrusion and other artefacts.
The Heatertemp jumped around and the LaserFIlamentSensor was constantly reporting to little movement (30:130,3mm)
i had to abort the print at around 50% , after restarting it from Pause around 8 Times.
The same Print connected to the Mainboard Driver 5: No Heater or Filament Sensor Errors! The Print Finished as expected.
Today i changed the Toolboard Firmware to the Version Previous Januar16, that is also in the 3.3Beta Folder.
I running the same Prints again to check if it is better.
since Updating to 3.3 i have no BLTouch Probing Errors the last 2 Days.
Regards
Frederik
