    Ringing on prints
    28
    500
    • RAM
      RAM last edited by
      Hi guys wondering if someone could give me any ideas as to what could be causing this strange pattern that is happening when I print.
      I thought it was because my z axis lead screws were unsupported at the top but I have since added bearing supports to the top and it hasn't made any difference.
      I have calibrated the extruder and X Y axis steps and it hasn't made a difference.
      My printer is a Hypercube evolution with X & Y MGN rails that are smooth to move. I have also checked that the belts are running true without rubbing on the idler pulleys.
      I have also tried printing in PLA and PETG to see if it was the filament and did a vase mode print too which came put like this.
        That's not really ringing/ghosting. It's more z banding.
        Have you PID tuned your heaters?
        RAM 1 Reply Last reply Reply Quote 0
        • RAM
          RAM @Phaedrux last edited by
          @Phaedrux yes I did both the bed and hotend. Just can't work out why it is in a perfect pattern after about the 1st inch.
          • Dad003
            Dad003 last edited by
            since that pattern happen always the same distance it probably your Z axis bending i had same problem on my 3d printer
            • o_lampe
              o_lampe last edited by o_lampe
              @RAM can you give me the link to the pacman ghost you've printed in vase mode, please?
              The banding reminds my of my Prusa i3, before I replaced the crappy linear bearings with IGUS drylin bearings.
              • RAM
                RAM @o_lampe last edited by RAM
                @o_lampe https://www.thingiverse.com/thing:557527
                There is a few different ones on that site. All I did was printed it in vase mode for a test.
                The bearings were really smooth as I tested them when I 1st built it and it probably has done less than 100 hours of printing. But on another print I did that was bigger the banding is a lot more pronounced like it is increasing with the size of whatever is printed.
                o_lampe 1 Reply Last reply Reply Quote 1
                • o_lampe
                  o_lampe @RAM last edited by
                  @RAM said in Ringing on prints:
                  An overheated print, like a small single wall part, printed without part-fan would sink in. But in your case it is the opposite.
                  Still the PID tuning of the hotend is in question.
                  After the tuning, did you store the new hotend-parameters with M500 and also read them with M501 in config.g?
                  Can you look at the hotend temp while printing and tell us what the biggest temperature swing is? (A screenshot of DWC will work too)
                  • ZipZap
                    ZipZap last edited by
                    Could it be, that the Bed runs in BANG-BANG-Mode instead of PWM?
                    If yes, i recommend changing that by using a SSR.
                    /Julien
                    Most important guide -> Triffid Hunter's Calibration Guide
                    HyperCube EVO (derivate) in 250x250x300 - enclosed for ABS - Duet2WiFi - custom watercooling
                    • RAM
                      @o_lampe said in Ringing on prints:
                      Yep definitely used the M500 after doing the PID tune. I will run another print and do a screenshot of the DWC.
                      I don't have a SSR on the heated bed as to be honest I wasn't sure how to set one up or wire it in. So I would assume that it is running in Bang Bang mode if running it in PWM requires it to have a SSR
                        Phaedrux Moderator @RAM last edited by
                        No, if you have gone through a PID tuning and saved the values, it will be running in PID/PWM mode. With or without an SSR.
                        What kind of heated bed is it? Normally an SSR is used if the bed heater is AC powered. The relay lets you control the flow of power to the bed on the AC side by sending a control signal on the DC side from the control board. This would be a AC-DC SSR. But there are also DC-DC SSR, which could be used to control a separate DC power supply that is solely used for the bed. That way a high current doesn't have to flow through the Duet itself. It just sends the control signal.
                        Bang-bang means it's turned on full power until it reaches temp and then turns on and off to try and keep that temp. This is why it can lead to some Z banding artifacts because the control isn't very smooth. PWM control with a PID algorithm allows for much finer control and smoother temps.
                          While printing, are the hot end and bed temperatures flat in the temperature graph displayed by DWC, or are there is oscillations?
                          • hackinistrator
                            hackinistrator last edited by
                            print 2 cylinders (like you did in your images) while one is twice in diameter .
                            compare the pitch distance on both cylinders .
                            if its the same - you have problem with your leadscrews , probably one of them bent .
                            if the pitch is different for the larger cylinder then you have temp / extruder issue .
                            • RAM
                              RAM @dc42 last edited by
                              @Phaedrux @dc42 said in Ringing on prints:
                              My heated bed is a 24v version that runs directly from the Duet 2 wifi board and when looking at the DWC as it is heating up on the graph it climbs up to the commanded temperature has a very slight deviation at the end where it overshoots by a few degrees then levels out nice and flat and both the hotend and bed stay flat whilst printing.
                              I will do 2 cylinders to see what is happening as suggested later.
                              • RAM
                                RAM last edited by RAM
                                This is how they look and to me they look exactly the same.
                                The small cylinder is 20mm which when measured using digital calipers measured 19.85 - 19.77 when being rotated and the 40mm cylinder measured 39.59 - 39.66 so they are very similar in measured dimensions with the variations. I have done all the axis calibration and the extruder calibration before this started to happen. But does this mean I need to redo the calibrations again ? Or could this be something else that is throwing the prints out ?
                                One thing I did notice when I was running this print is that it does seem to pause at the end of each layer for a moment unlike my Sidewinder X1 which is almost completely seamless with movements as it is printing.
                                • hackinistrator
                                  i think your slicing settings are way off .
                                  what slicer are you using ?
                                  • RAM
                                    RAM @hackinistrator last edited by
                                    @hackinistrator said in Ringing on prints:
                                    Simplify3D.
                                    hackinistrator 1 Reply Last reply Reply Quote 0
                                    • pkos
                                      pkos last edited by
                                      I remember having similar quality issues on my hevo back in the day.
                                      I can't remember what exactly fixed the problem, but first thing I did was to check my belt tension and replaced my belts (I used those white reinforced belts, which was a big nono).
                                      Then I made sure they were tight, but not so tight you can't really push them out and more importantly - they have to be equal length (down to the tooth) and equal tension.
                                      Then I made sure prints were square (using a calibration slat) and finally, I made sure the extruder was calibrated and also the filament itself (things like extrusion multiplier, pressure advance, destring).
                                      And then, the printer started printing amazingly well 😉
                                      Maybe one of these hints will help you if you haven't done them yet.
                                      Just in case, here are the tools I used:
                                      https://www.thingiverse.com/thing:3306430
                                      https://www.thingiverse.com/thing:3993559
                                      Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron 0 (Duet 3 mini 5+ standalone)
                                      • hackinistrator
                                        hackinistrator @RAM last edited by
                                        @RAM
                                        Can you share your factory file please
                                        • RAM
                                          RAM @hackinistrator last edited by RAM
                                          @hackinistrator here is the S3D printer profile I have.
                                          S3D Hypercube Profile
                                          @pkos thanks for the suggestions. I cant work out what it is. I have checked the belt tensions and I am not using them reinforced white belts with metal strands as I had read that they give problems.
                                          I have even gone back over the mounting points to make sure that nothing had come loose and that the idler pulleys were all freely spinning to the point I even printed new idler pulley mounts and changed them over.
                                          only thing I haven't done yet on the calibration things that you mentioned is the pressure advance tuning and the calibration slat.
                                          I will try the calibration Slat but I am still trying to get my head around the pressure advance tuning thing before I even attempt it.
                                          • pkos
                                            pkos last edited by
                                            Right, then first make sure you do the slat - that makes sure you are printing square.
                                            Then, do extruder calibration, extrusion calibration and only once you have that - then attempt PA 🙂 If you have a direct drive, PA won't help much.
                                            • hackinistrator
                                              hackinistrator last edited by hackinistrator
                                              HyperCube-CoreXY.TXT
                                              I slightly changed your profile , can you test it ?
                                              (rename file to .fff instead of txt)
                                              please print the cylinders one at a time , not both at the same time .
                                              for some reason your speed is set very slow at 20mm/s , why ?
                                              i changed it to 45mm/s and reduced acceleration , if you have some kind of issues . if its a problem set speed back to 20mm/s
                                              other changes should not effect your printer . the profile seems very old.
                                              RAM 1 Reply Last reply Reply Quote 1
                                              • RAM
                                                @hackinistrator Oh damn it exported the TPU testing profile I was setting up and not the PLA. Sorry that was my fault I didn't realise it had done that.
                                                If you would prefer to look at how the PLA profile is for the printer it is here.
                                                HyperCube-CoreXYPLA.txt
                                                what makes you say the profile is old ?
                                                • hackinistrator
                                                  are you using the latest s3d version ? (they didnt update in years and probably dead , but still your profile config looks like it was created before the latest version)
                                                  if you have time try my profile for single cylinder .
                                                  • RAM
                                                    @hackinistrator yep I am using v4.1.2 which is the latest. I am more than happy to try a different slicer even though I am not familiar with other slicers. I did used to use Cura years ago when I 1st got my Hictop in clone but ended switching over to Simplify3D as I found I was getting better prints using it.
                                                    I am doing the 20mm cylinder now and I will do the 40mm after to see what the difference is. So far it is looking really good. Haven't a clue what you changed but it seems to be doing the trick so far. Fingers crossed and it will have solved the issue.
                                                    • RAM
                                                      RAM @RAM last edited by
                                                      @hackinistrator whatever you changed seems to have worked wonders. I will delete the other profile and run with what you have done for me.
                                                      Only thing that I would like to do is try and minimise the seam line a bit more but if that is all I have to contend with I will gladly put up with that.
                                                      If you have any other suggestions to improve it further I would be very grateful.
