issues connecting to wifi on duet 2 wifi
  • good evening I am having trouble getting connected to wifi. i have installed the new firmware but i cant seem to get the wifi to come on. When I install the IABe.BIN file it says the file is too large, i then switched to IAB.BIN and it doesnt want to work. here's what i got so far.
    WiFi reported error: no known networks found
    WiFi module is idle
    WiFi module is idle
    WiFi module is idle
    WiFi module is idle
    WiFi module is idle
    WiFi module is idle
    WiFi module is idle
    M552 S0
    SENDING:M552 S0
    WiFi module is idle
    ok T0:2000.0 /0.0 B:2000.0 /0.0
    M587
    SENDING:M587
    Remembered networks:
    TNCAPF2FD81 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
    DJWARP IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
    M587
    SENDING:M587
    M115
    SENDING:M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
    any help will be greatly appreciated.
  • Well the remembered networks must not be one of the WiFi "networks".
    What are the WiFi SSIDs available to you?
  • Moderator
    Please post the results of M122.
    Then use M552 S1 to see if it will enable and connect.
    Use M587 to see a list of currently saved SSIDs
    use M588 S"*" to clear all curently saved SSIDs
    and then use M587 S"networkname" P"password" to readd your SSID
