    Feedback wanted: conditional GCode without indentation
    Future Direction
    28
    54
    838
      The existing conditional GCode mechanisms have proved very flexible. However, the need to indent the body of a conditional or loop makes it impractical to use a while-loop to create a looping GCode file, for example for a belt printer. So I would like to provide an option for the bodies of 'if' and 'while' commands to be terminated by a keyword instead of by the end of indentation. This would also allow the Marlin M808 command to be mapped to RRF conditional GCode.
      There are a few decisions to be made:
      1. Should the keywork be 'end', or something else?
      2. Should it be permitted to mix keywork-delimiting and indentation-delimiting in the same file? If so, what problems might arise, and what restrictions should be enforced?
      3. How should the user indicate to the firmware that a loop or conditional is to be delimited by a keyword instead of by indentation? One option is to have a new command keyword (e.g. 'noblockindent') that means that for the remainder of the file, keywork-delimiting will be used. Using that keyword when already inside a block would probably have to be banned. Another option is to use different variations of 'if' and 'while' (e.g. a different keyword or some extra character) to indicate keywork delimiting for that command.
      This isn't intended to be a vote, however I will take account of opinions expressed here. Other solutions that I haven't thought of would be especially welcome.
      fcwilt tekkydave DonStauffer 3 Replies Last reply Reply Quote 0
      • Sindarius
        Sindarius last edited by
        Speaking for myself I am not the biggest fan of indented scope because font, editor, and a few other factors can make the indentation difficult to follow.
        I think 'end' is a perfectly fine keyword for the task considering 'begin' and 'end' have been used in multiple programming languages and has a very specific meaning that applies here.
        timcurtis67 1 Reply Last reply Reply Quote 2
        • jay_s_uk
          jay_s_uk last edited by
          Less indentation is probably helpful as currently, none of the slicers handle this and it means all conditional gcode needs to be macro based etc
          Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
          • fcwilt
            fcwilt @dc42 last edited by
            1 - END by itself is easy but if you don't see it in context you don't know what it is the end of. It might be better to have unique keywords - ENDWHILE, ENDIF or something along those lines.
            2 - I would make the use of the new keywords mandatory. Yes existing users would have to do a bit of work but it would keep things simple and consistent for all in the future.
            3 - While you are implementing the change I would also suggest that a REPEAT/UNTIL or a DO/WHILE loop be implemented - the type of loop that always runs once.
            zapta tekkydave 2 Replies Last reply Reply Quote 4
            • DaveA
              DaveA last edited by
              As a C & C++ programmer from around 1976 I'd love to see the Kernighan and Ritchie style with { } syntax. I hate Python indention style.
              Just my opinion since you asked.
              fcwilt lord binky 2 Replies Last reply Reply Quote 9
              • arhi
                arhi last edited by
                I loathe the use of whitespace to define the flow so removing that and moving to begin/end, {/}, if/endif ; while-endwhile; do/while; repeat/until.. syntax is appreciated 🙂
                I don't mind rewriting all my conditional g-code to the new syntax
                • garyd9
                  garyd9 last edited by
                  Can you please give an example of a gcode sequence that would impractical with the current space delimiting blocks?
                  Personally, I'm not a big fan of spaces marking blocks of code. This is especially true when a mix of tab and space characters might be allowed. If spaces will continue to be used, I'd be in favor of the interpreter disallowing a mix of space/tab characters in the same file (similar to what I've seen python interpreters doing.)
                  Using "end" type keywords comes with it's own set of problems unless you create different "end" types. "end if", "end while", etc -- or you are very strict with requiring blocks to be 'end'ed.
                  For example, in the following code, is the 'end' ending the "while" loop or the "if" conditional?
                  if conditional
                  while (iterations < 5)
                  // do something
                  end
                  Using if/while specific versions of 'end' make things a bit less confusion, but still can be confusing:
                  while (a)
                  while (b)
                  end while // is this ending while(a) or while(b)?
                  If you REQUIRE 'end'ing EVERYTHING, it tends to result in more verbose code, but is also clearer:
                  if (conditional)
                  while (b)
                  // do something
                  end // this can only be ending the while(b) loop
                  end // this can only be ending the while(iterations) loop
                  end // this can only be ending the if conditional
                  -- and if an 'end' is missing, the interpreter would generate an error.
                  This approach (requiring every single 'if' and 'while' to have it's own "end") would probably be easier to write the interpreter for, and easiest to debug.
                  As for mixing keywords and space indents, I think that would be a recipe for confusion, both for the user and for the code interpreter. The fact that RRF and DSF might handle things slightly different would only add to confusion. My suggestion is to pick one way and enforce it.
                  "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                  fcwilt 1 Reply Last reply Reply Quote 1
                  • timcurtis67
                    timcurtis67 @Sindarius last edited by
                    @Sindarius said in Feedback wanted: conditional GCode without indentation:
                    +1
                    • fcwilt
                      fcwilt @garyd9 last edited by
                      @garyd9 said in Feedback wanted: conditional GCode without indentation:
                      The issue is gcode files as generated by a slicer - not the files you would create yourself on the duet.
                      garyd9 1 Reply Last reply Reply Quote 1
                      • fcwilt
                        fcwilt @DaveA last edited by
                        @DaveA said in Feedback wanted: conditional GCode without indentation:
                        Ugh - no.
                        C++ syntax was devised by sadists.
                        DaveA MikeS 2 Replies Last reply Reply Quote 1
                        • DaveA
                          DaveA @fcwilt last edited by
                          @fcwilt Yeah, I can agree with you on C++. I'd rather stick with straight C as most of my experience was with windows device drivers. In any case, it's better than Python. 🙂
                          • zapta
                            zapta @fcwilt last edited by zapta
                            @fcwilt said in Feedback wanted: conditional GCode without indentation:
                            One option is to annotate it with comments.
                            END ; while xyz
                            BTW, I am also not a fan of white space indentation having semantic meaning. It's too fragile, event with language specific editors that support it.
                            fcwilt 1 Reply Last reply Reply Quote 2
                            • reghend79
                              reghend79 last edited by
                              I think both keyword-delimiting and indentation-delimiting should be permitted in the same file to allow for flexibility and varying degrees of clarity. I'm working on analyzing print data in Matlab to create feedback control, and I am quite fond of using both indentations and "end" statements at the same time. The indentations are not normally required in Matlab, but they're done automatically to help visualize the blocks.
                              zapta 1 Reply Last reply Reply Quote 0
                              • zapta
                                zapta @reghend79 last edited by zapta
                                @reghend79 said in Feedback wanted: conditional GCode without indentation:
                                That's a good point, END should still allow indentation for code clarity, though the indentation would have no semantic impact. E.g. these code snippet should have the same meaning
                                            IF
                                     COMMAND1
                                  COMMAND2
                                COMMAND3
                                    END
                                IF
                                COMMAND1
                                COMMAND2
                                END
                                IF
                                    COMMAND1
                                    COMMAND2
                                    END
                                IF
                                    COMMAND1
                                    COMMAND2
                                END
                                • fcwilt
                                  fcwilt @zapta last edited by
                                  @zapta said in Feedback wanted: conditional GCode without indentation:
                                  END ; while xyz
                                  True but with specific keywords I'm forced to do the "right" thing. 😉
                                  • alankilian
                                    alankilian last edited by
                                    Here's one way to "DO" it. 🙂
                                    https://www.cnccookbook.com/cnc-g-code-macro-conditions-looping/
                                    • garyd9
                                      garyd9 @fcwilt last edited by
                                      That doesn't answer the question. Without an example of the problem, it's difficult to give a reasonable opinion on a proposed solution.
                                      fcwilt dc42 2 Replies Last reply Reply Quote 0
                                      • bot
                                        bot last edited by
                                        I think removing all indentation/whitespace from the syntax is a good idea. I also think a single END keyword is best. Multiple end keywords is just unnecessary. Keep track of the ENDs the same way one keeps track of the }s.
                                        *not actually a robot
                                        fcwilt 1 Reply Last reply Reply Quote 0
                                        • fcwilt
                                          As dc42 said in his opening post:
                                          That seems clear enough.
                                            dc42 administrators @garyd9 last edited by
                                            Suppose you generate a GCode file using a slicer. But you have a belt printer and you want to print it 10 times, with a belt movement between each iteration.
                                            Using existing slicers, there is no way to use the slicer start and end scripts to achieve this.
                                            You could achieve it by editing the GCode file, but then you would have to indent almost the whole GCode file so that it became the body of the while-loop.
                                            If we offer the option to delimit if- and while-commands explicitly, then you could insert one line near the start of the file (the 'while' line), and one near the end (the 'end' line). You might even be able to put the 'while' line in your slicer start script, and the 'end' line in the end script, so that you don't need to edit the file at all.
                                            Does that make the reason for this proposal clearer?
                                            garyd9 theruttmeister OwenD 3 Replies Last reply Reply Quote 1
                                            • fcwilt
                                              fcwilt @bot last edited by
                                              @bot said in Feedback wanted: conditional GCode without indentation:
                                              '}' symbols are evil incarnate.
                                              bot zapta 2 Replies Last reply Reply Quote 0
                                              • bot
                                                bot @fcwilt last edited by
                                                @fcwilt } // they don't seem so bad to me
                                                • tekkydave
                                                  tekkydave @dc42 last edited by
                                                  @dc42 curly braces for me every time. I don't see the point of adding extra keywords that just take up space.
                                                  ~ tekkydave ~
                                                  D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                                                  FreeCAD, PrusaSlicer
                                                  • tekkydave
                                                    tekkydave @fcwilt last edited by
                                                    @fcwilt I once used a language called pl/9 that had a repeat...until. I miss it from every other language I've used since.
                                                    ~ tekkydave ~
                                                    • fcwilt
                                                      fcwilt @tekkydave last edited by
                                                      @tekkydave said in Feedback wanted: conditional GCode without indentation:
                                                      I never heard of PL/9 - I used PL/1 for a bit - it's looping syntax was flexible and consistent.
                                                      My programming language of choice is Delphi.
