Need help diagnosing bad stepper output signal on Duet 3
I just setup a brand new duet 3 board with a Pi.
I have X,Y,Z1,Z2,Z3 on drivers 0,1,2,3,4 and the extruder on the last driver #5. I have tried 3 different motors and then switched the extruder motor around with a Z motor by just swapping connectors from one of the 3 Z motors at the board. When the extruder motor is plugged into driver #4 it runs perfectly, and on the same cable just plugged into a Z motors driver when I manual raise or lower the bed.
So the motor and cable is definitely working fine. I am wondering if the brand new board I have just happened to come with a bad driver or something?
I have tried many many amp settings and accel and step settings... not matter what any motor I connect to driver #5 just makes a faint hummm and rarely will even start to rotate. If I help the shaft along while it humming it will go.basic config:
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode; Drives
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5 ; set drive mapping
M671 X-30.109:146.1:322.309 Y-10.413:317.797:-10.413 S50
M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
M92 X160.00 Y160.00 Z1600.00 E1600.00:1600.00:873.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z30.00 E30.00:30.00:1800.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z1800.00 E1800.00:1800.00:3000.00 ; set maximum speeds (mm/min)
M201 X1600.00 Y1600.00 Z100.00 E100.00:100.00:2000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z800 E800:800:950 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X315 Y315 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
M574 Y1 S1 P"io0.in" ; configure active-high endstop for low end on Y via pin io0.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H15 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X26.5 Y-37 Z1.44 ; set Z probe trigger value, offset and trigger height
M557 X40:190 Y15:195 S40 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp0
M950 H0 C"out0" T0 ; create nozzle heater output on out0 and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H0 S460 ; set temperature limit for heater 0 to 460C
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create bed heater output on out1 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M140 H1 ; map heated bed to heater 1
M143 H1 S160 ; set temperature limit for heater 1 to 160C
M308 S2 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp2
M950 H2 C"out2" T2 ; create chamber heater output on out2 and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
M141 H2 ; map chamber to heater 2
M143 H2 S150 ; set temperature limit for heater 2 to 150C; Fans
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M106 P0 S0.5 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M106 P1 S0.5 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H0 F0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M911 S22 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first toolM122 RESULTS
2/13/2021, 1:57:52 PM M122
RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956BA-NA3TJ-6JTD2-3SD6M-9B9YT
Used output buffers: 1 of 40 (20 max)
Static ram: 149788
Dynamic ram: 62956 of which 40 recycled
Never used RAM 146048, free system stack 126 words
Tasks: Linux(ready,95) HEAT(blocked,297) CanReceiv(blocked,927) CanSender(blocked,348) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1069) IDLE(ready,19)
Owned mutexes: Telnet(MAIN)
Last reset 00:18:28 ago, cause: power up
Last software reset at 2021-02-13 12:38, reason: User, none spinning, available RAM 146048, slot 1
Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
MCU temperature: min 40.1, current 40.4, max 40.6
Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
Driver 0: position 10480, standstill, reads 23950, writes 4 timeouts 0, SG min/max 0/149
Driver 1: position -6160, standstill, reads 23950, writes 4 timeouts 0, SG min/max 0/163
Driver 2: position 50304, ok, reads 23950, writes 4 timeouts 0, SG min/max 0/111
Driver 3: position 0, ok, reads 23950, writes 4 timeouts 0, SG min/max 0/111
Driver 4: position 0, ok, reads 23950, writes 4 timeouts 0, SG min/max 0/112
Driver 5: position 0, standstill, reads 23954, writes 0 timeouts 0, SG min/max not available
Date/time: 2021-02-13 13:57:53
Slowest loop: 173.93ms; fastest: 0.03ms
=== Storage ===
Free file entries: 10
DMs created 125, maxWait 49750ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 29, completed moves 28, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
=== AuxDDARing ===
Bed heaters = 1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
Heater 0 is on, I-accum = 0.0
Segments left: 0
Movement lock held by HTTP
HTTP* is idle in state(s) 47 8, running macro
Telnet* is doing "M122" in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 254, send timeouts 566, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
=== SBC interface ===
State: 4, failed transfers: 0
Last transfer: 1ms ago
RX/TX seq numbers: 39110/39110
SPI underruns 0, overruns 0
Number of disconnects: 0, IAP RAM available 0x2c8a8
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.2.2
HTTP:
Buffered code: G30 ; home Z by probing the bed
==> 24 bytes
Executing macro homeall.g, started by G28Next stack level
Code buffer space: 4096
Configured SPI speed: 8000000 Hz
Full transfers per second: 36.46
Maximum length of RX/TX data transfers: 4924/860
ok
This stands out to me a little... I have no clue what any of it means. I just notice irregularities on driver 5 compared to the others
The first thing that stands out is you have defined multiple E factors in your config but you only have one Extruder, I think you meant to set multiple Z factors.
Ie
@Noah said in Need help diagnosing bad stepper output signal on Duet 3:
M906 X1200 Y1200 Z800 E800:800:950 I30 ; set motor currents (mA) and motor idle factor in per centCan you remove the multiple E values from this section? You only have a single extruder, so there should only be a single E value.
Can you send M98 P"config.g" and report the results?
The rrf config tool originally gave me that setup
When I manually moved things from
M350 X16 Y16 Z16 E16:16:16 I1 to M350 X16 Y16 Z16:16:16 E16 I1
and so on for all the motor settings the bed would no longer home and the printer wouldn't function so I had to switch everything back
@Phaedrux said in Need help diagnosing bad stepper output signal on Duet 3:
P"config.g"
M98 P"config.g"
Error: in file macro line 21: M350: array too long, max length = 1
Error: in file macro line 22: M92: array too long, max length = 1
Error: in file macro line 23: M566: array too long, max length = 1
Error: in file macro line 24: M203: array too long, max length = 1
Error: in file macro line 25: M201: array too long, max length = 1
Error: in file macro line 26: M906: array too long, max length = 1
Warning: Macro file config-override.g not found
I just tried putting back these settings
M92 X160.00 Y160.00 Z1600.00:1600.00:1600.00 E873.00
M566 X1200.00 Y1200.00 Z30.00:30.00:30.00 E1800.00
M203 X18000.00 Y18000.00 Z1800.00:1800.00:1800.00 E3000.00
M201 X1600.00 Y1600.00 Z100.00:100.00:100.00 E2000.00
M906 X1200 Y1200 Z800:800:800 E950 I30
M84 S30Same result again. The triple Z bed no longer homes or responds to G32
If you run M98 P"config.g" again and it gives the same result as before, I think it's because you have multiple factors when you don't need them. If you tell the firmware the Z is 0.2:0.3:0.4 it knows to use one setting for all 3 steppers.
The Z axis only needs a single entry as well. It's only when you have multiple extruder axis that each axis needs to be defined. The other axis with multiple motors all use the same settings since they aren't independent.
So remove the multiple Z values as well.
@Rushmere3D JYNX again!
@Phaedrux haha
ok, haha
thank you so much for dealing with the noob over here. I corrected all of the lines after m671 to show only one value for X,Y,Z,E
I was just copying what the RRF config tool gave me for the multiple E motors since it did not have any option to add extra Z motors.
Z homing and G32 working perfect again, and I only have one data point for motor 5 now
Fingers crossed.
as soon as the hotend heats up and it will let me send extrude and retract commands, I'll let you know if the ext motor is behaving any differently now
Hahahaha Phaedrux & Rushmere You guy are amazing!!!
wish I had asked a little sooner for someone to review my code... I really caused myself a couple of days of grief over here... I have good motor function on all motors now.
Now, I am off to tune my extrusion steps and try a print!|Thank You both soooooo much
Noah
Proper config for others refernce
M350 X16 Y16 Z16 E16 I1
M92 X160.00 Y160.00 Z1600.00 E873.00
M566 X1200.00 Y1200.00 Z30.00 E1800.00
M203 X18000.00 Y18000.00 Z1800.00 E3000.00
M201 X1600.00 Y1600.00 Z100.00 E2000.00
M906 X1200 Y1200 Z800 E950 I30
M84 S30
Glad you got it sorted.
I still do have the
Error: in file macro line 21: M350: array too long, max length = 1but only for the M350 line
That's strange... what doesn't it like about my M350 X16 Y16 Z16 E16 I1
Please upload your actual config.g file
