    Error Parsing Response
    38
    2.5k
    • mfs12undefined
      mfs12
      Hey @dvmourik,
      i build a patched firmware image to understand your problem better. Can you test it on your device and provide the results.
      Here's the patched firmware:
      • PanelDueFirmware-3.3.0-rc3-dvmourik-5.0i-7.0i.bin
      The major change i did is an increased timeout for requests.
      Visit me on github at https://github.com/mfs12/
      dvmourikundefined 1 Reply Last reply Reply Quote 0
      • dvmourikundefined
        dvmourik @mfs12
        @mfs12
        Thank you very much, we are going to test it.
        It happens from 3.2.x up and before we used (3.1.1 which was clean/no problems)
        We even have it now on our small machines (desktop)
        We are going to install the firmware now and will report within 2 hours with a result.
        @Phaedrux resistance is in range and even much lower. We took a original cable (longest which was supplied before and meassured 3x as much restance. So this is not the issue as we think. Thanks for thinking with us.
        Bigger and bigger… sky is the limit.
        • dvmourikundefined
          dvmourik
          @mfs12
          We installed the firmware, but unfortunately it didn't solve our problems. Now we get a lot of error messages as shown in attached picture! We are currently running RRF 3.3 RC2 and WebControl 3.3.0 RC2 IMG_20210721_140124.jpg
          jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @dvmourik
            @dvmourik can you upgrade to the stable 3.3 release?
            There was a bug fix regarding "error parsing..." that was fixed between RC3 and the stable release. See here https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC#reprapfirmware-33-post-rc3
            dvmourikundefined 1 Reply Last reply Reply Quote 1
            • dvmourikundefined
              dvmourik @jay_s_uk
              @jay_s_uk
              Upgraded to the stable release, but still the same problem
                jay_s_uk @dvmourik
                @dvmourik thanks for confirming
                  dc42 administrators @dvmourik
                  @dvmourik can you confirm that it is still only during startup that you see these messages?
                  • dvmourikundefined
                    dvmourik @dc42
                    @dc42 Nope, those messages, from the picture in my previous post, keep coming up every minute or so
                    mfs12undefined 1 Reply Last reply Reply Quote 0
                    • mfs12undefined
                      mfs12 @dvmourik
                      Hey @dvmourik, I need more information to get a better understanding.
                      Can you provide the following information:
                      • which Paneldue Firmware were you running with your RRF-3.1.1 setup?
                      • please share your config.g
                      • please describe the process how to reproduce the errors
                      • dvmourikundefined
                        dvmourik
                        @mfs12 We have just uploaded 3.1.1. and 1.24 and this still seems to work without any errors. to reproduce we just turn the machine on, please see our config below:
                        ;T3D v2.5.1.1
                        M111 S0
                        M550 PTractus3D T3000 ;DO NOT CHANGE - NEEDED FOR PROCESSES
                        M540 P0x02:0x80:0xC2:0x02:0x00:0xFF
                        M575 P1 B57600 S1
                        M98 P"_UserSettings.g"
                        M552 S1
                        M555 P1
                        G21
                        G90
                        M83
                        M569 P0 S0 ;E0
                        M569 P1 S0 ;E1
                        M569 P4 S0 ;Y
                        M569 P2 S0 ;X
                        M569 P3 S0 ;Z
                        M584 X2 Y4 Z3 E0
                        M92 X80 Y80 Z80
                        M92 E290
                        M906 X1700 Y1700 Z1700 E1100 I40
                        M201 X1000 Y1000 Z1000 E6000
                        M204 P500 T1000
                        M203 X18000 Y18000 Z18000 E18000
                        M566 X300 Y300 Z300 E600
                        M665 R494.50 L1063 B500 H1660 X0 Y0 Z0
                        M666 X0 Y0 Z0 A0 B0
                        M574 X2 S1 P"xstop"
                        M574 Y2 S1 P"ystop"
                        M574 Z2 S1 P"zstop"
                        M308 S0 A"Bed" Y"thermistor" P"bedtemp" T100000 B4400 R4700
                        M308 S1 A"Hotend 1" P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
                        M950 H0 C"bedheat" T0
                        M308 S6 A"MCU" Y"mcu-temp"
                        M950 P0 C"exp.heater3"
                        M950 H1 C"e0_heat" T1
                        M950 F0 C"fan0"
                        M950 F1 C"fan1"
                        M950 F2 C"fan2" Q1000
                        M950 J1 C"e1stop"
                        M950 J2 C"exp.e2stop"
                        M201 X1000 Y1000 Z1000 E4000
                        M204 P1000 T1000
                        M566 X500 Y500 Z500 E1200
                        M106 P0 S0 H-1 C"Part cooling"
                        M106 P1 T50 H1 S255
                        M106 P2 T40:60 H2 L0.50 X1.0
                        M570 H0 P20 T20
                        M570 H1 P15 T20
                        M563 P0 D0 H1 F0 S"Hotend 1"
                        G10 P0 S0 R0
                        M140 H0
                        M307 H0 A119.9 C608.9 D1.4 S1.00 B1
                        M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                        M558 P5 C"e0stop" X0 Y0 Z0 F100 T10000
                        G31 X0 Y0 Z16.25 P500
                        M557 R400 S40
                        M208 S1 Z-0.5
                        M911 S20.5 R22.0 P"G91 M83 G1 Z3 E-3 F3000 M929 S0"
                        M579 X0.9926 Y0.9980
                        M912 P0 S2
                        M143 H0 P0 S110 A2
                        M143 H0 P1 S130 A0
                        M143 H1 P0 S300 A2
                        M143 H1 P1 S320 A0
                        M42 P0 S255
                        M42 P1 S255
                        M581 P1 T1 S1 R1
                        G28
                        • mfs12undefined
                          mfs12 @dvmourik
                          Hey @dvmourik, i put your config on my machine, but couldn't reproduce the problem. unfortunately.
                          Would RRF-3.2.x or RRF-3.3 and PD-1.24 work as a workaround for you?
                          Slowly i start to believe it might be related to the wiring.
                          Can you test the following:
                          • disconnect duet3 from network (just to be sure it's nothing on the network keeping duet3 very busy)
                          • enter M115 in the paneldue console and post reply
                          • start the duet3 and paneldue your cable (check if error continues to occur)
                          • start the duet3 and paneldue with short cable (check if error continues to occur)
