Need help to connect Heated bed to Duet 3
  • Hi everybody
    I don't find what I'm doing wrong...
    I'm trying to connect an heated bed to Duet 3, Thermistor on IO PIN4
    Here is the code :
    M308 S0 P"io4.in" Y"thermistor" A"Bed" T100000 B4138 C0   ; Set thermistor
    M950 H0 C"bedheat" T0                                      ; Bed heater
    M140 H0                                                    ; Add heater to bed after RRF3.01 RC10
    M143 H0 S120                                               ; Set temperature limit for heater 0 to 120C
    I get -271°C on DWC
    I checked the thermistor (about 120k ohm at room temp).
    Thanks by advance
  • you can't use IO's for temperature measurement.
    you need to use a proper temperature input such as temp0
  • Ok, thanks.
    Tried this without success after changing pin sensor to temp0 :
    M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B4725 C7.06e-8    ; Set thermistor
    M143 H0 S100
  • that code looks find to me. I assume you've moved the connection to the temp0 input?
  • Yes I changed to temp0 on board...
  • Hi,
    Where's the M307 command?
  • Fiannly it worked with :
    M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8
    M950 H0 C"out0" T0 ; create heater and map sensor 0
    M140 H0
    M143 H0 S100
    Thanks !
  • @duetlover
    Are you sure that's the correct thermistor for your bed? Also looking at my config.g set up via the online config tool it appears your missing a commands.
    M308 S0 P"temp0" Y"thermistor" A"Keenovo Bed" T100000 B3950           ; configure sensor 0 as thermistor on pin temp0
    M950 H0 C"out0" T0                                     		  		  ; create bed heater output on out0 and map it to sensor 0
    M307 H0 B0 S1.00                                       		 		  ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                               		  		  ; map heated bed to heater 0
    M143 H0 S120                                         		   		  ; set temperature limit for heater 0 to 120C
