    Mini IR Z probe Nightmare
    96
    • Tpmoses
      Tpmoses last edited by
      Hello all,
      I have a large format cartesian printer that I inherited at work. I was not the one who built this printer, so I was more just going along with what was there. Last week on a print that was running overnight, I came in the next morning and the printer had stopped and had kicked the surge protector. When I started it back up the Z probe was broken, the IR receiver C1 was just gone. I ordered a new one and put it on yesterday and aside from the print bed having weird spikes ( the signal wire was getting interference) it ran fine, and started printing another overnight part. This morning I came in and the printer was ruunning, however it was printing air as it had an error that no tool was selected, and after investigation the IR probe was broken again C1 and D1 gone.
      Now my question is, is this an issue from a power surge? is it just that the IR Probe is just not for my application? Would it be a bad Idea to switch to a bl touch? Any help would be greatly appreciated.
      Thanks,
      T
      • Veti
        Veti last edited by
        post a picture of your hotend assembly with the ir probe
        what temperature are you printing at?
        is it in an enclosure?
        • Tpmoses
          Here is where the probe is.
          Running carbon filled abs, at 270c hotend, 110c build plate (doesn't get up to temp well, average around 95c-103c.
          The printer is inside of a pop up canopy with walls because of size
          • Veti
            Veti last edited by
            how hot does the metal plate get during printing that the ir sensor is attached to?
            Tpmoses 1 Reply Last reply Reply Quote 0
            • Tpmoses
              Tpmoses @Veti last edited by
              @Veti The plate doesn't get that hot, the bored itself is mounted to a piece of poly tooling bored so there isn't a lot of heat transfer between the sensor and the plate.
              • Veti
                Veti last edited by
                c1 is not supposed to be fitted. so thats not the problem.
                d1 falling of is.
                • Tpmoses
                  Tpmoses @Veti last edited by Tpmoses
                  @Veti here is a picture of the bored itself,
                  C1 was gone in both cases, this time the diode was gone.
                  • jay_s_uk
                    jay_s_uk last edited by
                    C1 is not populated so it won't have gone
                    Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
                    o_lampe 1 Reply Last reply Reply Quote 0
                    • o_lampe
                      o_lampe @jay_s_uk last edited by
                      @jay_s_uk
                      It's Q1 that fell off, but C1 is also written close to the pads and can easily lead to confusion.
                      jay_s_uk 1 Reply Last reply Reply Quote 2
                      • jay_s_uk
                        jay_s_uk @o_lampe last edited by
                        @o_lampe I was just commenting on where @Tpmoses said C1 was missing in both cases. It can't be missing if it was never fitted.
                        Therefore, it would be interesting to see the first IR Probe as his comments would indicate nothing was in fact missing
                        • Tpmoses
                          That was my mistake, Q1 is what was missing in both cases.
                          o_lampe engikeneer 2 Replies Last reply Reply Quote 1
                          • o_lampe
                            o_lampe @Tpmoses last edited by
                            @Tpmoses
                            The PCB to the right looks very toasty. The shrinktube of the large capacitor seems burned? Maybe you could use some silicone to seal the PCB against heat. (don't cover the optics) 🙂
                            • Tpmoses
                              Tpmoses @o_lampe last edited by
                              @o_lampe on the first board there was silicone on the board, that was the bored that went bad after a power surge. My main question is if you guys think I should keep with the IR bored or just cut my losses and buy a bl touch.
                              • o_lampe
                                @Tpmoses
                                I can't comment on the BLtouch, but talking about losses Add a USV to your printer or a big battery to avoid power-issues.
                                • alankilian
                                  alankilian last edited by
                                  The left-hand board also has the lens of D1 knocked off.
                                  If you are crashing into something, a BLTouch is likely going to get banged up also.
                                  What do you think is going on?
                                  Can you run a camera and take a video of a print to see where things are going wrong?
                                  • Tpmoses
                                    My Plan as of right now is to reorder the board, then mount it higher on the printer and recalibrate the target sensing distance. Then as I am waiting on it to be delivered I was going to go through the wiring with my meter. I unfortunately didn't build this printer, and the person who did no longer works here. He also didn't leave any specs for it so I am flying a little blind.
                                    • Veti
                                      Veti last edited by
                                      the bottom of the mount looks like heat damage as well.
                                      • engikeneer
                                        engikeneer @Tpmoses last edited by
                                        @Tpmoses do you still get the lights flashing on the IR board on startup as expecting? If so, it suggests the chip on the IR board is fine and the power surge itself hasn't damaged the board. Most likely the damage has come from the sensor hitting something, so as the the others have said swapping to a BLTOUCH won't solve your issue.
                                        I'd suggest going through your wiring, but maybe also look at the failed prints to see what went wrong with them. I'm guessing thrbdamage came from the board hitting the print? In which case, either there is a printing issue that has caused the print to lift up, or there is a config/slicing/hardware issue that has caused the nozzle to drop down.
                                        i3 clone with a bunch of mods
