    What's your fav. post-processing app?
    post-processing raspberry pi script
    506
    • o_lampeundefined
      o_lampe
      @o_lampe said in Texture mapping with feltpen carousel?:
      Today I tried to get the latest news about THE post processing app for RRF3 and eg. PrusaSlicer. But informations were sparse.
      The manual of PS mentions a way to implement scripts and guided me to a github page with 4-9 years old examples. 😲
      I'm sure there has been a development going on in the last few years, especially with the SBC-option for Duet3.
      So what's your favourite post processing app on a Raspberry?
      It should have features like finding a string, replace and insert command lines, extract numbers and convert them from string2float.
      • PCRundefined
        PCR
        ArcWelder 😉
        o_lampeundefined zaptaundefined 2 Replies Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @PCR
          @PCR
          That's a good one! 👍
          Sure is useful as standard-plugin, but even more it's a good base for learning python.
          It's made for Octoprint, but can I implement it in PrusaSlic3r too?
          • PCRundefined
            PCR
            https://www.youtube.com/watch?v=1rNEEOFOQ5k&t=5s
            made a video some months ago @o_lampe
            • zaptaundefined
              zapta @PCR
              @PCR said in What's your fav. post-processing app?:
              ArcWelder
              Does it improve print quality? How noticeable?
              The Hackaday article seems to focus on it's file size reduction aspect.
              As for the question here, I just use plain Python, based on code that I was posted on this forum. https://github.com/zapta/util/blob/main/duet3d_automesh/duet3d_automesh.py
              o_lampeundefined 1 Reply Last reply Reply Quote 1
              • o_lampeundefined
                o_lampe @zapta
                @zapta said in What's your fav. post-processing app?:
                Hard to tell, it's subjective. I resliced a very complicated part with AW and it looked better, but then again I have also played around with other parameters in slic3r...
                With a RAMPS board and Delta printer, I'm sure it takes a huge load from the MPU, but a Duet shouldn't have problems reading and digesting a straight gcode.
                Only downside is, it doesn't work with vase-mode settings. Maybe @oliof can tell more about it (he's co-author AFAIK)
                • oliofundefined
                  oliof @o_lampe
                  @o_lampe I only built an early version of the set of Makefiles to build the command line tools -- long superceded by something less awkward.
                  • o_lampeundefined
                    o_lampe @oliof
                    @oliof said in What's your fav. post-processing app?:
                    You're too humble 🙂
