    BLTouch and Duet wifi - can't seem to let it work
    Accessories and Add-ons
    631
    • Vetiundefined
      Veti
      @Cinny1988 said in BLTouch and Duet wifi - can't seem to let it work:
      M280 P7 S10 I1
      M280 P7 S90 I1
      that is rrf2 syntax.
      change to
      M280 P0 S10
      • Cinny1988undefined
        Cinny1988
        Changed the codes to
        M280 P0 S10
        M280 P0 S90
        Currently still get the error that the probe is already triggered at start of probing move.
        • fcwiltundefined
          fcwilt @Cinny1988
          M280 P0 S10
          M280 P0 S90
          Try changing
          M558 P9 C"!zprobe.in" H5 F150 T2000 A10 R0.5 S0.3
          to
          M558 P9 C"zprobe.in" H5 F150 T2000 A10 R0.5 S0.3
          • David Greenundefined
            David Green
            This works for me on V3.2.2 Duet Wifi and BLTouch .
            M574 X1 Y2 S4
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            :Z-Probe
            M558 P9 C"^zprobe.in" H5 F120 T3000 ; FW v3 BLTouch connected to Z probe IN pin
            M950 S0 C"exp.heater5"
            G31 P500 X-32 Y13 Z2.9 ; Set Z probe trigger value, offset and trigger height
            M557 X15:225 Y15:225 S20 ; Define mesh grid
            M915 X Y S5 R2
            ; Disable heaters H3-H7 to free up pins
            M950 H3 C"nil"
            M950 H4 C"nil"
            M950 H5 C"nil"
            M950 H6 C"nil"
            M950 H7 C"nil"
              Cinny1988
              Thanks everybody for helping me out with this.
              Unfortunately it's still not working. Good news is that all the errors are gone but the probe itself is not doing anything.
              When sending the G30 command it now raises the bed but the probe does nothing.
              David Greenundefined 1 Reply Last reply Reply Quote 0
                David Green @Cinny1988
                @Cinny1988 Are you on the correct pin? Your picture looks like you are not on H5. Mine is on pin 9 lower connector you look like you are on H3
                Cinny1988undefined 1 Reply Last reply Reply Quote 0
                  Cinny1988 @David Green
                  @David-Green mine is indeed on H3
                    @Cinny1988 Change it over I guess either H3 or move pin
                      Cinny1988
                      Yes it finally works!
                      I changed the pin to H5 and adjusted the config information as shared.
                      Thank you all so much for the help.
                      fcwiltundefined 1 Reply Last reply Reply Quote 2
                      • fcwiltundefined
                        fcwilt @Cinny1988
                        Glad to hear you got it all sorted.
                          Phaedrux Moderator @David Green
                          @David-Green said in BLTouch and Duet wifi - can't seem to let it work:
                          M950 H3 C"nil"
                          M950 H4 C"nil"
                          M950 H5 C"nil"
                          M950 H6 C"nil"
                          M950 H7 C"nil"
                          Freeing up pins isn't needed by default in RRF 3.1 and beyond as the pins are free to begin with. You'd only need to free them if you wanted to reconfigure one on the fly.
                          Likewise this is no longer needed in RRF3 either. M307 H5 A-1 C-1 D-1 ; unbind heater pin
                            David Green @Phaedrux
                            @Phaedrux Thanks, I will amend my config.g, not that it seems to have any impact on operation.
