    Duet 2 wifi not connecting to Paneldue 7i
    1.1k
    • 3dpnutundefined
      3dpnut @dc42
      @dc42 I'll try again:
      This is what I get after successfully running M997 S1:
      95% complete
      Upload successful
      ok
      M552 s1
      ok
      WiFi module started
      WiFi reported error: no known networks found
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      M552 s0
      ok
      WiFi module is idle
      M552 S1
      ok
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
        Ok, the no networks found means that you now need to give it a SSID and password for your wifi network using the M587 command.
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
        You should now be able to complete the getting connected guide
        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
        • 3dpnutundefined
          3dpnut
          Thanks all!! Everything is now working with the exception of a Z homing issue, which I think I can (hopefully :)) figure out. Have a great weekend!
          • 3dpnutundefined
            3dpnut
            I turned the machine on today, and it seems like I turned back the clock 2 weeks. The same thing is happening, not connecting to Wifi. I've run through the same cycles which fixed it last time, no luck. I ran M997 S1, and it re-installed the firmware fine. Then ran M552 S0, OK. Then M552 S1, OK. Then M587 S"xx" P"xx", and it says OK, then times out and says wifi module is idle. My computer is connected to the same network and is connected no problem. I double-checked the password and it's correct.
            What am I doing wrong?
              If you send M587 by itself does it list back your network details?
              • 3dpnutundefined
                3dpnut
                Sends back:
                6Dh 35h 38h 37h
                  Are those SSIDs?
                  3dpnutundefined 1 Reply Last reply Reply Quote 0
                  • 3dpnutundefined
                    3dpnut @Phaedrux
                    @Phaedrux I don't know what they are. I changed my terminal type from binary to text, and it's connected now. Previously I had to change it the other way for it to work...not sure what the correct setting is for that.
                      I'm not sure what you're talking about, but it sounds like it's working now?
                      • 3dpnutundefined
                        3dpnut @Phaedrux
                        @Phaedrux Sorry, its a setting in YAT. It is connected now, fingers crossed it stays that way!
