Z Homing position different by zero
I'm trying to set the machine to zero the Z axis in a non-zero position (like on the Anycubic Chiron). The limit switches are located at Z = 82 (adjustable), while the printing surface is located at Z = 0.
How do I make the firmware understand that before starting the movement of the Z axis it must make sure that it is above the sensor?
Because if actual Z is beyond the sensor, the XY plane is lowered until it meets the sensor.
If the actual Z is below the sensor, if the platen is lowered, the hotend will hit the print platen. And this doesn't have to happen! -
depending on how you shut your machine down, you could save the location of Z and then use that at power up.
other than that, the machine will have no idea where the Z is to be able to make that choice -
I could move the sensors to Z = 5 and modify the homez.g file so that the lifting of the Z axis is 7 mm initial and not 5. In this way, inserting a G92 Z5 in the file, even if I reset the Z axis when Z <5, I would have a way to overcome the sensor and correctly reset.
@bernardomattiucci sounds like that would work
I'm not sure what you are trying to do.
Hopefully you can move the Z sensor so you cannot move past it - even when at Z = 0.
If you can do that you don't need to worry about "lifting" Z prior to homing.
This is the first result. Low quality, that's true, but that's already something.
I definitely have to adjust the jerk and probably the printing temperature (195 ° C).The Z sensor, for now, I can not lower it below a certain limit.
Anyway ... I solved the problem. The zeroing takes place regularly with the Z sensor placed at Z = 10.From console:
M201: Accelerations (mm/sec^2): X: 1000.0, Y: 1000.0, Z: 100.0, E: 4000.0
M203: Max speeds (mm/min): X: 20000.0, Y: 20000.0, Z: 1000.0, E: 5000.0, min. speed 30.00
M204: Maximum printing acceleration 10000.0, maximum travel acceleration 10000.0
M205: Maximum jerk rates (mm/sec): X: 66.7, Y: 66.7, Z: 5.0, E: 25.0
M566: Maximum jerk rates (mm/min): X: 4000.0, Y: 4000.0, Z: 300.0, E: 1500.0, jerk policy: 0the values of M201 I changed them to X5000 and Y5000. I don't know why they were X1000 and Y1000.
New M201: Accelerations (mm/sec^2): X: 5000.0, Y: 5000.0, Z: 100.0, E: 4000.0
M205 and M556 set the same thing - just using different units.
I've never found a reason to use M204.
For starters you can try the default values for everything but M92 and M906.
Just comment out M201, M203, M204, M205 and M556 and re-boot.
If you wish to see the defaults just enter those commands with no parameters at the DWC console.
What material are you printing?
Do you have part cooling fan(s)?
@fcwilt said in Z Homing position different by zero:
The only reason is to have faster travels than print moves.
@Phaedrux said in Z Homing position different by zero:
Given the numerous settings in slicers for speeds, etc in practice is M204 truly useful?
@fcwilt Given it's vintage it was a good option at the time. Some people also don't want to bake settings like that into gcode files since it's not adjustable after the fact.
Goodmorning everyone
I had entered the codes M566, M203 and M201 in the config.g file to find the speed "limits" of the X and Y axes.
Now the 3 instructions in the file have been commented out.
From the Console I get this:Custom M566 ;M566 X4000.00 Y4000.00 Z300.00 E1500.00 ; set maximum instantaneous speed changes (mm/min) Original M566 Maximum jerk rates (mm/min): X: 900.0, Y: 900.0, Z: 12.0, E: 120.0, jerk policy: 0 Custom M203 ;M203 X20000.00 Y20000.00 Z1000.00 E5000.00 ; set maximum speeds (mm/min) M203 Max speeds (mm/min): X: 6000.0, Y: 6000.0, Z: 300.0, E: 1200.0, min. speed 30.00 Custom M201 ;M201 X5000.00 Y5000.00 Z100.00 E4000.00 ; set accelerations (mm/s^2) M201 Accelerations (mm/sec^2): X: 500.0, Y: 500.0, Z: 20.0, E: 250.0 I'll do some printing tests with the default values and let you know.
That is not good.
Do you have a part cooling fan or fans?
And what material are you printing?
The first thing I would work with is your extrusion settings.
That is not good.
With the old electronics the print quality was much better, even if the speed did not exceed 33 mm / s.
Yes, I have a layers fan but I fear that the flow from the duct does not come out perfectly. I'll have to improve it. But I need suggestions.
PLA, 180/185°C
I started from a print speed of 60mm / sec and am adjusting the speed of the outer walls, decreasing it by 5mm / sec each print.
I would like to avoid printing at too low a speed. But if I can't solve it, I'll start with the 30mm / sec of the old electronics.Bernardo
Can you post your whole config? Have you set the correct thermistor?
; Communication and general M111 S0 ; Debug off M550 P"Quadra 600" ; Machine name and Netbios name (can be anything you like) ;*** Networking M552 S1 ; Turn network on M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Drives M569 P0 S0 ; X Axis - physical drive 0 goes forwards M569 P1 S0 ; Y Axis - physical drive 1 goes forwards M569 P3 S0 ; Extrusor - physical drive 3 goes forwards M569 P5 S0 ; Z1 Axis - physical drive 5 goes forwards M569 P6 S0 ; Z2 Axis - physical drive 6 goes forwards M569 P7 S0 ; Z3 Axis - physical drive 7 goes forwards M569 P8 S0 ; Z4 Axis - physical drive 8 goes forwards M584 X0 Y1 Z5:6:7:8 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80 Y128.00 Z800.00 E102.16 ; set steps per mm ;Default M566 X900 Y900 Z12 E120 P0 ;M566 X1800.00 Y1800.00 Z24.00 E240.00 ; set maximum instantaneous speed changes (mm/min) ;Default M203 X6000 Y6000 Z300 E1200 I30 ;M203 X12000 Y12000 Z600 E2400 ; set maximum speeds (mm/min) ;Default M201 X500 Y500 Z20 E250 ;M201 X1000 Y1000 Z40 E500 ; set accelerations (mm/s^2) M906 X1275 Y1875 Z1875 E1275 I30 ; set motor currents (mA) and motor idle factor in per cent (60-90% of nominal current) M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X602 Y602 Z602 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"duex.e2stop+duex.e3stop+duex.e4stop+duex.e5stop" ; configure active-high endstop for low end on Z via pin duex.e2stop+duex.e3stop+duex.e4stop+duex.e5stop ;M574 Z1 S1 P"duex.e5stop" M669 K0 ; select Kinematics Y to react with X and Z ; Z-Levelling ;M558 P0; H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed ;M557 X15:587 Y15:587 S20 ; define mesh grid ;M671 X-115:-115:715:715 Y130:470:470:130 ; Z leadscrews are at Z2 (-115.130) Z2 (-115.470), Z3 (715.470), Z4 (715.130) ; Thermistors ;M140 H-1 ; disable heated bed (overrides default heater mapping) ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; A"MK8" ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 S"Estrusore MK8" ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M18 Z E0 M208 S1 Z-0.2 T0 @jay_s_uk said in Z Homing position different by zero:
Honestly, I have no idea. I used the values of the old electronics.
@bernardomattiucci
are you using stock thermistors? if so, what printer is it? -
@bernardomattiucci
are you using stock thermistors? if so, what printer is it?Thermistor 100 KΩ...
but i have no idea what it is (make / model). They gave me 3 supplied with the MK8 extruder.
Consider that, at the moment, I have no way to control the temperature of the hob. I have an electric "stove" lit under it which keeps the aluminum surface (and the glass surface) hot enough to be able to print (ambient temperature below 20 ° C).
